Problem??
sPeJ
PostPosted: 15:20 - 02 Nov 2002    Post subject: Problem?? Reply with quote
When on a interstate i drive very normal.. The bike just dies...
I put on the reserve and it's starts...
Then during a climb. A loud hhhrrrmamambbba!!!!!
from the engine.
What is it???
it happend two times until i got home..?
4+4=3
Freshstart
PostPosted: 15:33 - 02 Nov 2002    Post subject: Reply with quote
what bike do you have what model year and any other details then someone may help you
sPeJ
PostPosted: 15:37 - 02 Nov 2002    Post subject: Reply with quote
a nsr 125 - 91
4+4=3
Freshstart
PostPosted: 15:45 - 02 Nov 2002    Post subject: Reply with quote
when you say it happened two times you mean, you changed it over to reserve and back two times or im guessing it made a loud bang twice. it could be backfiring i suppose but im not technically minded as some of the other lot may tell you!. it could be the piston miss-firing or something else i expect Keith may be the man with the plan
Robby
Dirty Old Man
PostPosted: 16:08 - 02 Nov 2002    Post subject: Reply with quote
could be a silly question, but i dont know if your a muppet or not.
was there any two stroke oil in the tank?
could also be the plug, once my CB did a backfire like a shotgun and the choke cable was dodgy. got it home and the plug was fucked from an over rich mixture, blistered to buggery.
PostPosted: 20:04 - 02 Nov 2002    Post subject: Reply with quote
Strange for it to die just like that, and then come back to life when you turn to reserve (assuming you have plenty of petrol). Check the fuel filters inside the tank. Also check the breather into the tank, but that would not explain it working on reserve.
Not sure about the noise. Nearest I can make out you are describing the noise of blipping the throttle on a 2 stroke.
sPeJ
PostPosted: 09:37 - 04 Nov 2002    Post subject: Reply with quote
i think i know what had happened.....
In some corny way the reserve tank didn't get any oil.
so now it's a scratch in the cylinder...
I think it's a stop in the oil tank.
4+4=3
craigT19
Jolly Green Giant
PostPosted: 15:00 - 04 Nov 2002    Post subject: ... Reply with quote
there reserve tank didnt get any oil???
howz that work....ive never seen a 91 nsr but doesnt the two stroke oil mix with the petrol in the carb??
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Guest
PostPosted: 19:36 - 04 Nov 2002    Post subject: Reply with quote
Yes, the oil is mixed in with the fuel / air mix in the carb. There is no difference in the oil supply between running on the normal fuel supply and running on reserve.
The last post was made 23 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 56.73 Kb
