Re-proofing trousers - worth it?
Northern Monkey
PostPosted: 22:22 - 11 Nov 2018    Post subject: Re-proofing trousers - worth it? Reply with quote
I've got a pair of AlpineStars Andes trousers that I've had for about 3 years now, and if I ride in the rain, after about 10 miles I get a wet knob. Looking like you've pissed yourself isn't the ideal look for working in the office.
Has anyone had any success with re-proofing sprays or washes, or should I just chuck them and buy something better?
PostPosted: 22:31 - 11 Nov 2018    Post subject: Reply with quote
You are Neverleak Panties and I claim my five ponds.
Freddyfruitba...
PostPosted: 22:31 - 11 Nov 2018    Post subject: Re: Re-proofing trousers - worth it? Reply with quote
Well. As it happens I saw this in Aldi today, and at £1.99 it's gotta be worth a punt at least?
Northern Monkey
PostPosted: 22:37 - 11 Nov 2018    Post subject: Reply with quote
It's a fair cop
PostPosted: 22:51 - 11 Nov 2018    Post subject: Reply with quote
£780 pledged of £105,796 goal
Looks like you're going to have to settle for the £1.99 can of waterproofing stuff Freddyfruitbat found at Aldi.
flearider
PostPosted: 23:29 - 11 Nov 2018    Post subject: Reply with quote
no reproofing does not work ...
but gore tex does .. i've had a pair of Austrian army gore tex pants for must be 8 yrs treat them once a yr never leaked .. just keep them away from the radiator (really bad for them)
best £100 I ever spent .. use them for sea fishing also (quick wash there fine )
textile can not be reproofed unless you add the micro plastic coating .. which you cant .....
go gore tex
Islander
PostPosted: 23:48 - 11 Nov 2018    Post subject: Reply with quote
Yes it does work as long as the trousers are in reasonable condition. I'd recommend Nikwax TX direct - it's excellent stuff. Thumbs Up
MCN
PostPosted: 01:01 - 12 Nov 2018    Post subject: Reply with quote
This.
And read the instructions carefully.
Dirt is the main cause of clothing wick-ing water.
Remove the dirt and that blocks the water migration.
(Must be capillary action or something.)
Nikwax doesn't like some detergents so their detergent should be used unless you know what their stuff is made from.
Wonko The Sane
PostPosted: 17:44 - 12 Nov 2018    Post subject: Reply with quote
nikwax tech wash and tk direct wax in the washing machine has sorted my hein gerik kit that I'd stopped using due to it not being waterproof anymore and keeps my Halversons kit waterproof.
The way I've had it explained to me is the wash gets rid of dirt that allows the water to sit in the fabric helping it soak through, the wax helps it bead to run off instead of soak in.
usually can just wash at Christmas then wash and wax in November and I'm waterproof for the year's commuting.
stirlinggaz
PostPosted: 21:29 - 12 Nov 2018    Post subject: Reply with quote
Hi,
Ive used nikwax a few times & i dont get the dreaded wet crotch, even on the old, cheap textiles.
cheers,
GAZ
PostPosted: 21:38 - 12 Nov 2018    Post subject: Reply with quote
I was listening to a motorcycle podcast today that suggested simply washing the textiles. Remove the armour and lining and stick it in the washing machine. Apparently dirt gets in the gore tex pores and keeps them open for water to get through.
Not sure how accurate this is, but it's worth a go before spraying it with some unknown gunk though, right?
Freddyfruitba...
PostPosted: 00:44 - 13 Nov 2018    Post subject: Reply with quote
Hmm. My understanding is that by using regular detergent, rather than the special stuff, you're likely to remove what remaining proofing agent is there, and make the situation worse
PostPosted: 09:47 - 13 Nov 2018    Post subject: Reply with quote
Don't use detergent then I guess!
MCN
PostPosted: 11:49 - 13 Nov 2018    Post subject: Reply with quote
I normally only wear leather troos on the bike rain or shine. They have been cleaned with nikwax leather cleaner and waterproofed with nikwax leather waterproofing and never let water in. They look just like they did when not proofed. The compound lives under the surface.
talkToTheHat
PostPosted: 20:09 - 13 Nov 2018    Post subject: Reply with quote
If the seam tape/weld has failed then no kind of aftermarket profing will help. I destroyed two sets of IXS trousers because the seam taping was poor.
Tech wash and then TX wax (or similar process) helps rain bead off the outer alyer of textiles and stops the outer layer saturating as fast, so can restore some performance to old kit.
Bandit. does. everything.
BTTD
PostPosted: 10:08 - 14 Nov 2018    Post subject: Reply with quote
I've found this to be true, once the seams leak it's game over and on trousers they are the weak link.
Freddyfruitba...
PostPosted: 11:13 - 14 Nov 2018    Post subject: Reply with quote
You need.... NappyPal Thumbs Up
UncleFester
PostPosted: 18:43 - 14 Nov 2018    Post subject: Reply with quote
That's exactly what goretex does - wash and gently tumble dry. I do treat mine with nikwax as the washing agent but you don't need to.
2017 Z1000SX
talkToTheHat
PostPosted: 19:55 - 14 Nov 2018    Post subject: Reply with quote
I've not noticed a big difference in liner performance after washing kit with cheaper goretex-like waterproof liners, but maybe less breathable cheap stuff suffers less?
Powderhead
PostPosted: 21:15 - 14 Nov 2018    Post subject: Reply with quote
I have the same gear, and I can confirm that all the Nixwaxing products in the world can't save you now.
Buy new gear.
Sorry.
"Now at inspector level!"
ScottT
PostPosted: 21:25 - 14 Nov 2018    Post subject: Reply with quote
I've got the same problem as a last resort before buying new gear i've been tempted to apply the wax thats used on wax cotton jackets, it works on old Belstaff and Barbour jackets, anyone else tried this?
If not i'll report back later once i've tried it.
MCN
PostPosted: 23:55 - 14 Nov 2018    Post subject: Reply with quote
You probably will not see much of the Gortex part of a Gortex garment.
The Gortex membrane is a thin sheet of ptfe material. It is protected from abrasion and tears between layers of fabric. The outer fabric will habe a water repellent quality that can be compromised by dirt.
The dirt simply wicks moisture into the garment or becomes saturated and the evaporative pressure between you and the outdoors is defeated.
When the dirt is washed out using a detergent (which loosens and then keeps dirt in suspension to be rinsed away) the waterproof quality goes out with the water and therefore must be replaced.
I use nikwax products as they work well and they have the most comprehensive range of products that will treat materials from wool, cotton, nylon to leather.
Was that a punt or wot?
Wonko The Sane
PostPosted: 18:30 - 19 Nov 2018    Post subject: Reply with quote
You need to clean out the washing powder drawer and run a rinse cycle before washing the gear as most washing powder contains some form of bleaching agent which gets rid of waterproofing and can affect the waterproof membrane
my hein gerrike stuff I'd stopped wearing as it was as waterproof as a towel despite hand washing it in the bath with nikwax tech wash and tk direct.
I gave it a go in the washing machine and it did the job, it's not heavy downpour waterproof but another run through would probably get it towards that.
As has been said, it's worth a punt
MCN
PostPosted: 21:47 - 19 Nov 2018    Post subject: Reply with quote
https://www.gore-tex.co.uk/gore-tex-wash-instructions
WASH
Machine wash on a warm permanent press cycle (105°F/40°C) using a small amount of liquid detergent. Rinse twice, and minimize spinning to reduce creasing. Don’t use powder detergents, fabric softeners, stain removers, or bleach. Don’t wash with heavily soiled clothing.
DRY*
Line dry your garment, or tumble dry it on a warm, gentle cycle. Once it’s dry, tumble dry the garment for 20 minutes to reactivate the durable water repellent (DWR) treatment on the outer fabric. You can do this anytime you notice the water repellency needs a boost.
* Do not tumble dry GORE-TEX SHAKEDRY™ garments
DRY CLEAN*
We recommend home laundering. But if professional dry cleaning is necessary, request that the cleaner use clear distilled hydrocarbon solvent (a bit of a mouthful, we know) for rinsing, and then spray DWR on the garment’s outer fabric before drying.
* Does not dry clean GORE-TEX SHAKEDRY™ garments.
natefz6
PostPosted: 17:36 - 20 Nov 2018    Post subject: Reply with quote
I use Nikwax tech wash and TK direct for mine then treat the outside with the scotchgard to increase the water repellency. I currently have a jacket that's 10 years old and its still working well.
"no I didn't steal it that's just the way I ride"
The last post was made 7 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 131.28 Kb
