Dealing with a spot of rust
CornishDes
PostPosted: 21:21 - 11 Nov 2018    Post subject: Dealing with a spot of rust Reply with quote
Hi all, picked up an XR125 as a bit of a winter hack today and while it runs sweetly, it's a tad rustier than it looked in the photo's. Think it's all superficial but the swingarm is a bit more so. It will be treated to some ACF50 but in the first instance do I need to get in there with a wire brush, steel wool and some rust remover? Any advice welcome. Thanks, Dave
https://farm5.staticflickr.com/4872/45832489531_4587cb9665_k.jpg
pepperami
PostPosted: 22:55 - 11 Nov 2018    Post subject: Reply with quote
Looks like you’re going to have to start unbolting bits before you can get to the worst Sad
I used a length of dowling with a small bit of Emery cloth/wet & dry on the end to get to the tight corners and those hard to get to places.
PostPosted: 23:03 - 11 Nov 2018    Post subject: Reply with quote
You can either spend hours working on removing as much rust as possible and then painting the cleaned up metal.
Or you can cover it in ACF50 and then forget all about it as it gets hidden by a protective layer of road dirt /grime / filth. Wink
flearider
PostPosted: 23:38 - 11 Nov 2018    Post subject: Re: Dealing with a spot of rust Reply with quote
remove the shit covering it ..get in there quick sand repaint cover in afc50 grease great for winter ..
cb1rocket
PostPosted: 01:13 - 12 Nov 2018    Post subject: Reply with quote
just glob a shit load of grease all over the rust.
proper way is to take swingarm off and have shotblasted and treated and powdercoated
Sister Sledge
PostPosted: 08:19 - 12 Nov 2018    Post subject: Reply with quote
As above but I'm surprised it doesn't have a sheet of tough plastic between it and the wheel to stop this type of thing?
It mostly looks superficial (for now) but personally I'd be more concerned about that rear shock and linkages - they're in the firing line of crud being thrown about by the rear wheel.
CCM 404 DS
CornishDes
PostPosted: 10:22 - 12 Nov 2018    Post subject: Reply with quote
Thanks for the feedback. I've ordered some jenolite and will put a bit of elbow grease in and see how things clear up before treating with grease/ACF50 and/or getting some fresh paint in places.
BenR
PostPosted: 00:08 - 13 Nov 2018    Post subject: Reply with quote
Jenolite as with most "rust removers/preventers" are shit & pretty pointless to be honest as they're acid based & require cleaning off with water in order to neutralize the surface before it can be painted over. Unfortunately once rust has got in it's unlikely you'll ever get rid of it. Shotblasting it & powder coating would be the way to go.
MCN
PostPosted: 11:11 - 13 Nov 2018    Post subject: Reply with quote
Wire Brush and Detol.
You need to get clear and unobstructed access to the rusted areas.
The rust will be 'invisibly' working it's kind of magic under any paint or between fitted parts.
Rust converters work.
Rust removers work.
Protecting sound surfaces works.
Bad preparation is not related to the above points.
Your machine has contracted Oxidation and electrolysis.
The prevention is/was easier than the cure.
You could slather it in acf50 and batter on regardless or deal with it in a more aggressive manner.
If you are in love then it will be a big undertaking, if it's just a brief and lustful fling over the darker months of winter then spray away.
Remember to not spray the brakes/breaks, the seat, the pegs, the grips, the ends of the levers where your hands will be.
CornishDes
PostPosted: 00:59 - 14 Nov 2018    Post subject: Reply with quote
Thanks MCN. I'm going to try the hard route but will no doubt reach a 'that'll do' point. Keen to post back on here so that should give me some motivation too.
Robby
Dirty Old Man
PostPosted: 09:14 - 14 Nov 2018    Post subject: Reply with quote
It only takes 20 minutes to remove the swingarm. Do the job right.
While you have it apart, you can clean and re-grease the swingarm pivot points and the suspension linkage.
The last post was made 7 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 67.82 Kb
