Adrenaline 125 NO SPARK Chinese junk
dudejb46
PostPosted: 21:08 - 15 Nov 2018    Post subject: Adrenaline 125 NO SPARK Chinese junk Reply with quote
2013 pulse adrenaline 125
New plug
New cap
New lead
New coil
New cdi
NO SPARK. it turns over fine with new battery and jump pack. when key is on no lights are on but the gear indicator, is that right? Been so long since I had it running I can't remember.
Is there any common faults anyone knows of?
Or any standard electrical tests I can do?
Joined clutch and side Stand switch wires together still no joy.
tested frame earths, OK.
2002 zip 2002 bandit project 2004 fzs1000 2009 883r
bikenut
PostPosted: 14:41 - 16 Nov 2018    Post subject: chinese junk Reply with quote
Not to a chinese peasant and his family !!
Get or make your own wiring diagram, you have the bike in front of you so it won't be that difficult or rocket science even.
Start at the battery and go from there. A multi meter would be good.
Is the ign system battery dependent for it to work, some are, some are not and are self contained, only needing a battery to whizz the engine over, if they don't have a kick start.
Undo your work around with the side stand etc. so the bike is as original and work your way from there.
With the ign on I would expect the horn, brake lights and inds to work, maybe a fuse somewhere, there will be somewhere.
Some chinky bikes have the earth wire rivetted to the engine, not that brilliant, but the engine whizzes over well on the battery, so that part of the electrics are good.
Make a new dedicated earth wire from the engine to the frame, to rule that out.
Take your time and be methodical, enjoy, its character building and you will learn.
nuts about bikes
bikenut
PostPosted: 10:47 - 17 Nov 2018    Post subject: non runner Reply with quote
Any luck yet ?
Was it a fuse and did you find a wiring diagram ??
nuts about bikes
bikenut
PostPosted: 11:48 - 17 Nov 2018    Post subject: cdrap Reply with quote
So, a very quick google search and if the parts supplier pictures are correct, its a cdi ign 12v coil reg/rec seems to have honda convention on wiring, 3 yellows from charging system genny/stator, a red to battery and a black sensor. Not bad for a technophobe old fart, so you my lad should have no problems, other than its gunna take more than a few presses of a button the magic your bike back to life.....
What colour wires has your bike, to say horn ( picture please ) left and right indicators ( pics ) stop and tail lights etc.....
nuts about bikes
bikenut
PostPosted: 11:56 - 17 Nov 2018    Post subject: lex Reply with quote
the lexmoto site seems reasonably good but could be better........fuel injected your bike ????
nuts about bikes
Teflon-Mike
tl;dr
PostPosted: 14:52 - 17 Nov 2018    Post subject: Re: Adrenaline 125 NO SPARK Chinese junk Reply with quote
Well the number one common cause of 'no-sparks' is folk taking the spark plug out, putting on the HRT cap and not earthing the plug to the engine-frame.....
Personally, I like to use a car jump-lead, put the plug ion the crock-clip one end, it both holds it where you can see it, and you can get a good earth on the other end direct on the battery neg.
Next... you need a good supply of volts to get a spark... if you got no lights on the dash, how you trying to get it to turn over?
If there's no lights on the dash, is there any juice in the battery to use e-starter? If not it aint going to turn motor over fast enbough to make volts for sparks.... a-n-d if you are trying to do it on the kick-starter, if it has one.... it tends to be quite tricky to jump up and down on the kicker, keep balence, and keep the spark-plug in sight... let alone resting on a cylinder fin to get earth... a-n-d you will likely only get a very weak spark, off it at best anyway.....
So there's your top 'common faults'......
bikenut
PostPosted: 11:25 - 19 Nov 2018    Post subject: chikky Reply with quote
Nice one mike, well put.
The red neon plug caps I bang on about are a good cheap visual real world HT indicator at cranking conditions and engine running conditions.......all with the plug in the engine, but you may have to make an adaptor so it fits the plug ( just use the "nipple", the plug one not your own !!! depending how "kinky" you are of course ) and the plug cap ( make that end so it looks like the top of your spark plug, and will fit into the oe plug cap, and make it so it will fit onto the top of the red neon plug cap, sadly that has a non detachable "nipple" ).
nuts about bikes
The last post was made 7 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 55.82 Kb
