Gaming monitor advice
M.C
PostPosted: 16:03 - 18 Nov 2018    Post subject: Gaming monitor advice Reply with quote
I'm in the market for a new monitor. I had a 4k 60hz IPS screen before but I'm interested in possibly buying a 1440p monitor with a higher refresh rate. I mainly play racing games, ultrawide monitors made for 'sim racing' all seem to be 100hz, unless I'm missing a technical reason as to why they aren't higher?
Questions:
IPS or TN? Can't say I noticed a difference with my last (IPS) monitor, TN panels seem to have lower input lag?
Hz? 144hz seems to be really expensive, I've noticed a lot of 75hz panels but overclocking monitors seems to be hit and miss. My last monitor went up to 72hz (from 60), my old 1080p OC by a measly 6hz Smile
HDR? Are there enough games on PC to justify it?
ULMB etc.? It sounds interesting but seems to be only found on top-end monitors: https://www.blurbusters.com/faq/motion-blur-reduction/
Budget: I'd love to spend £250ish, I'd probably go up to £300, or maybe £400 for an uber monitor. Any thoughts/suggestions?
Loui5D
PostPosted: 16:21 - 18 Nov 2018    Post subject: Re: Gaming monitor advice Reply with quote
Questions:
IPS = Better quality picture & colours disaply, more expensive & generally lower refresh rates - also higher response times.
TN = Cheaper & higher refresh rates also have a lower response time
HDR isn't really supported at the moment for PC.
I bought a Benq XL2411T around 6 years ago for £320, still works as good as it did when I bought it - a high refresh rate & low response time was what I bought it for.
Really depends on your rig as well, if it can't maintain 60 fps then there's no real point in having a 120Hz + monitor - interpolation isn't a good thing.
Something else to factor in is what display ports you have on your GPU & what GPU it actually is.
M.C
PostPosted: 16:50 - 18 Nov 2018    Post subject: Reply with quote
It's a GTX 1070. I did run some games at 1440p as at 4k you get drops below 60fps, you seem to get a 25-30fps gain at 1440p. That was the idea of getting a 100hz monitor, to get 144fps you'd have to turn too much down IMO.
dydey90
PostPosted: 08:25 - 19 Nov 2018    Post subject: Reply with quote
I'm using a 40" Sony tv as my monitor. It can only do 1080p at 60Hz, but I doubt I'd get much more than that, I rarely see modern games go over 70fps.
The last post was made 7 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 41.84 Kb
