Peugeot Tweet 125 won't start
tweetard
PostPosted: 10:27 - 20 Nov 2018    Post subject: Peugeot Tweet 125 won't start Reply with quote
Hi,
My Peugeot Tweet 125 won't run. Initially the electronics on the screen were lighting up but I got no response when I turned the ignition, then the screen faded and wouldn't turn back on. The fuel tank is half full and the killswitch is on so it ain't either of those. Any advice?
Sometimes you hit the bar and well... sometimes the bar hits you.
jaffa90
PostPosted: 10:57 - 20 Nov 2018    Post subject: Reply with quote
What is the condition of the battery and when was it last serviced?
tweetard
PostPosted: 11:00 - 20 Nov 2018    Post subject: Reply with quote
it was last serviced two weeks ago and I have no idea about the condition of the battery. Can I check for any telltale signs?
bikenut
PostPosted: 11:47 - 20 Nov 2018    Post subject: battery Reply with quote
Post a pic of the battery out of the bike, is it a sealed type, this is the time of year that failing batteries die.
nuts about bikes
jaffa90
PostPosted: 11:49 - 20 Nov 2018    Post subject: Reply with quote
The telltale signs are in your first post.
tweetard
PostPosted: 12:02 - 20 Nov 2018    Post subject: Reply with quote
Here's a photo
jaffa90
PostPosted: 12:06 - 20 Nov 2018    Post subject: Reply with quote
That battery looks nice and clean, do you know of an electrician who can test the voltage or somebody with jump leads and a good battery?
tweetard
PostPosted: 12:29 - 20 Nov 2018    Post subject: Reply with quote
I know someone with jump leads and a good battery yeah
jaffa90
PostPosted: 12:50 - 20 Nov 2018    Post subject: Reply with quote
This site is showing a kick start for your scooter.
tweetard
PostPosted: 12:53 - 20 Nov 2018    Post subject: Reply with quote
Which site?
Riejufixing
PostPosted: 12:59 - 20 Nov 2018    Post subject: Reply with quote
tweetard wrote:
battery probs?
Get a piece of wire and a 12v bulb. See if you can make the bulb light up by connecting it across the battery terminals.
If you haven't got a bulb, get a shortish piece of wire, and hold one end on a battery terminal pressing it on with your thumb. Brush the other end of the wire briefly and quickly across the other battery terminal. If you get a crackly spark, your battery is OK. If you don't, it's not.
If it's not OK, buy another battery and fit it. I recommend Tayna.
Monkeywrenche...
PostPosted: 16:05 - 20 Nov 2018    Post subject: Reply with quote
tweetard wrote:
Which site?
The adverts at the bottom of the page, It's the fold out black thing on the side of the engine, have you tried using it?
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
tweetard
PostPosted: 16:21 - 20 Nov 2018    Post subject: Reply with quote
yeah i tried using it and got no response
Riejufixing
PostPosted: 16:54 - 20 Nov 2018    Post subject: Reply with quote
Does your battery work?
WD Forte
PostPosted: 17:21 - 20 Nov 2018    Post subject: Reply with quote
HTH
https://www.firstgroup.com/uploads/node_images/usetts.png
bikers smell of wee
tweetard
PostPosted: 18:30 - 20 Nov 2018    Post subject: Reply with quote
battery works just fine yeah, I tested it before
Riejufixing
PostPosted: 19:30 - 20 Nov 2018    Post subject: Reply with quote
Any power to anything? Fuse somewhere?
jaffa90
PostPosted: 21:22 - 20 Nov 2018    Post subject: Reply with quote
"I have no idea about the condition of the battery."
How did you test it?
Riejufixing
PostPosted: 21:59 - 20 Nov 2018    Post subject: Reply with quote
Well spotted. The sparky wire test is a certain test. I wonder what was done to test, and whether there's any other missing information. Tweetard?
bikenut
PostPosted: 15:36 - 21 Nov 2018    Post subject: pug Reply with quote
Ask santa for an early xmas present, a digital multi meter, even a cheapo one, a tool that will soon pay for its self and can only help you fix this bike and others.
Perhaps the give away is the blue tape ??
Remove the battery and check on the electrolyte in the battery and give it a charge whilst its out. A pic of the battery when its out will show more as it may be a "sealed" battery, post a pic.......
Get a wiring diagram and post, also check on here for a manual......
nuts about bikes
Robby
Dirty Old Man
PostPosted: 16:17 - 24 Nov 2018    Post subject: Reply with quote
Ignition switch. The contacts rotate a bit in the bottom of the switch.
Turn the key to ON. Then turn it just a tiny bit to the left, and see if the dash lights up and it lets you start the bike.
Two ways of fixing it:
1. Get a new ignition barrel.
2. Dismantle the current barrel, rotate the contact switch into its proper position, then glue it in place so it can't slip out of alignment again. I did that. Took longer than expected. Make sure you strip it down carefully on a bench with plenty of light, there are one or two spring loaded bits that like to ping off into a dark corner of the garage.
The last post was made 7 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 102.57 Kb
