Bullit Spirit running fault
alanrstanton
PostPosted: 14:47 - 20 Nov 2018    Post subject: Bullit Spirit running fault Reply with quote
Hi, I have a Bullit Spirit 125 EFi which has done about 5,000 miles.
I've had one or two issues with it, but am really stuck with the current running fault.
The bike when started cuts out straight away, you start for a second time and it runs, sometimes needing throttle to keep it going.
Once you set off and approach the first two junctions/stopping points it cuts out unless you throttle. from then on it doesn't cut out for the rest of the journey.
Coupled with this, the bike hesitates when you ease of the throttle and then throttle on again, almost feeling like someone has held onto the bike and after a few seconds then lets go. This has now been happening for approximately 500 miles.
the Lambda sensor has been replaced, it's been serviced including the clearances being set-up, I've put several fuel treatments through also.
Does anyone have any idea what this may be? I ordered the bike from a company several hundred miles away and so taking it back is difficult, they have in fairness to them sent me the parts that have gone wrong without any fuss.
I have an ignition coil/HT lead on the way as I feel it could be that.
again any help would be greatly appreciated.
Thanks in advance
bugeye_bob
PostPosted: 14:54 - 20 Nov 2018    Post subject: Reply with quote
Has the coolant temp sensor been checked at all ?
alanrstanton
PostPosted: 15:01 - 20 Nov 2018    Post subject: Reply with quote
The engine temp sensor has, the bike is air cooled.
jaffa90
PostPosted: 16:02 - 20 Nov 2018    Post subject: Reply with quote
Has this problem come about since the colder weather/temp.
alanrstanton
PostPosted: 16:09 - 20 Nov 2018    Post subject: Reply with quote
Hi, no it started maybe 2 months ago, maybe 3. The bike was running fine, then one day it just started playing up with this fault overnight.
jaffa90
PostPosted: 16:19 - 20 Nov 2018    Post subject: Reply with quote
From what you say / state it is showing signs of a weak mixture.
If the air filter and exhaust are standard then it`s back to the supplier.
alanrstanton
PostPosted: 16:21 - 20 Nov 2018    Post subject: Reply with quote
Yeah they're standard. Ok thank you, I'll find a dealer closer to me.
The only other thing I've thought of and that was just now, is the exhaust is wrapped. I wonder if it's damaged/holed underneath the wrap?
jaffa90
PostPosted: 16:28 - 20 Nov 2018    Post subject: Reply with quote
Wrapped exhaust on a newish bike????!!!!!!!!
Needs checking if not standard.
Also check at the engine.
A100man
PostPosted: 22:48 - 20 Nov 2018    Post subject: Reply with quote
Not seem this brand before - looks chinko... Crying or Very sad
cb1rocket
PostPosted: 10:40 - 21 Nov 2018    Post subject: Reply with quote
sounds like the throttle position sensor has moved from the symptoms you describe.
alanrstanton
PostPosted: 10:46 - 16 Dec 2018    Post subject: Fault found and fixed Reply with quote
Hi all,
I've found and fixed the fault yay. So the misfire, running fault, cutting out and hesitation were all caused by the clutch level button on the handle bars.
I have a new one coming, but for now have connected the two wires with a bridging wire.
Thank you all for your suggestions. Chuffed i found this one out after a couple of hours of fault finding 👍🏼
Evil Hans
PostPosted: 16:08 - 16 Dec 2018    Post subject: Reply with quote
I can see that affecting the starting but can't see why it would make the bike cut out.
alanrstanton
PostPosted: 16:18 - 16 Dec 2018    Post subject: Reply with quote
When I pulled the clutch in to change gear whilst slowing down it was cutting the circuit. Bridged the circuit cutting the switch out and it's all good
jaffa90
PostPosted: 17:51 - 16 Dec 2018    Post subject: Reply with quote
I agree. Neutral
alanrstanton
PostPosted: 20:28 - 16 Dec 2018    Post subject: Reply with quote
It's cured it 🤷🏻
Evil Hans
PostPosted: 09:48 - 17 Dec 2018    Post subject: Reply with quote
What you could have is something like a dodgy sidestand cut out switch, and shorting the clutch switch has "cured" that.
Do you mean replacing it cured it, or shorting it cured it?
alanrstanton
PostPosted: 09:51 - 17 Dec 2018    Post subject: Reply with quote
Cut it out cured it. So put a new one on which has also cured it.
linuxyeti
PostPosted: 10:27 - 17 Dec 2018    Post subject: Reply with quote
Fair play, although, if it was my bike, I would also, remove/blank the side stand switch, if it has 1, or is the side stand on these, one of those that spring back as soon as pressure is lifted?
Beware what photos you upload, or link to on here, especially if you have family members on them
Sister Sledge
PostPosted: 10:51 - 17 Dec 2018    Post subject: Reply with quote
This ^^
Just takes the odd bump in the road to affect a sidestand switch and temporarily cut out an engine.
CCM 404 DS
Evil Hans
PostPosted: 10:56 - 17 Dec 2018    Post subject: Reply with quote
Weird.
The clutch switch goes on every time you pull in the clutch, so it shouldn't affect anything (except starting*) any more than pulling the clutch in and out would.
Your bike is clearly haunted
* The one my Bandit is currently shorted out as otherwise I have to jiggle the switch to get it to start.
The last post was made 7 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 100.1 Kb
