Painting Galvanised Steel
Renton
PostPosted: 19:40 - 29 Nov 2018    Post subject: Painting Galvanised Steel Reply with quote
Father in law is restoring a Series 3 Land Rover and he’s just got the chassis back from galvanising.
His usual method of spraying (using etching primer) works well in the summer, but last weekend it hasn’t taken so well and has basically fallen off.
Chassis is stripped back to galv and ready to go again.
Any suggestions on what sort of paint he should be using to spray with?
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
Riejufixing
PostPosted: 20:01 - 29 Nov 2018    Post subject: Re: Painting Galvanised Steel Reply with quote
Everbuild 901.
andy_uk
PostPosted: 21:24 - 29 Nov 2018    Post subject: Reply with quote
When he used the etching primer, did the galv go black?
If not, then de-grease and etch it again.
Renton
PostPosted: 08:49 - 30 Nov 2018    Post subject: Reply with quote
Yes, it coated the chassis black and looked the job. It wasn't until he started fitting the leaf springs and the hubs etc that the paint started chipping off as soon as it was knocked. He took the pressure washer to it and the whole lot came off Confused
Sister Sledge
PostPosted: 09:06 - 30 Nov 2018    Post subject: Reply with quote
A couple of things: Does application of paint to galvy metal not depend on whether it was hot or cold dipped? With some galvy metal are you not supposed to leave it to settle for 6 months before applying paint??
I honestly don't know and would like to!
CCM 404 DS
andyscooter
PostPosted: 11:17 - 01 Dec 2018    Post subject: Reply with quote
needs to be warm to spray properly
either have to wait until its warm again or paint inside a warm unit
we used to gave days we couldn't paint where I used to work if it was too cold
even with the space heater on
The last post was made 7 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 48.04 Kb
