| 27alan |
 27alan L Plate Warrior
| bikenut |
 bikenut World Chat Champion
| rs700 |
 rs700 Derestricted Danger
 Posted: 12:19 - 26 Nov 2018 Post subject: |
check the magnets on your flywheel. If they have hit the magneto your ignition will no longer work.
unfortunately i cant load pictures on how to check the magneto on here.
Dont know why, the picture number wont load, not telling me why.
(message me with your email by message and i ll send pictures)
there are aftermarket options ( a good oe sem magneto costs £200 p!us, most ebay crap ones are broken !)
https://www.hpi.be/item.php?item=ST5525L |
| 27alan |
 Posted: 21:00 - 26 Nov 2018 Post subject: af1 sintesi stator help |
Thanks for the reply, i have a wiring diagram, and the bike is wired the same, the bike just cut out, was not down on power.
The cdi is part of the coil, which has 4 wires, The stator has 5 wires 2 go to the regulater and the other 3 to the coil, The cutout woks on the ign switch and stop switch on the bars, all seem to work ok with a continuity test.
Am i right thinking that the stator must be in 2 parts, one part for charging and the other part to power coil/cdi ? if so how do i check the part that powers coil /cdi
thanks in advance, Alan |
| rs700 |
| rs700 |
 Posted: 01:30 - 29 Nov 2018 Post subject: |
hpi do direct replacement for the stator, you use the original flywheel.
They list ....
https://www.hpi.be/sem.php
direct replacement for the sem stator. |
| 27alan |
| Nobby the Bastard |
| Nobby the Bastard |
 Posted: 21:35 - 29 Nov 2018 Post subject: Re: af1 sintesi stator help |
| 27alan wrote: | Thanks for the reply, i have a wiring diagram, and the bike is wired the same, the bike just cut out, was not down on power.
You seem to be using magneto and stator interchangeably. A magneto generates ac for lights. A stator works in conjunction with a Reg/rec to make 12v dc (actually nearer 14v) to charge a battery.
I've never come across a case where magnets on a flywheel have either twatted something or come loose except immediately after a badly done rebuild or when the crank bearings have failed.
If its the later of those two the lack of spark is the least of your problems. ____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Triumph Sprint ST 1050 |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:31 - 08 Dec 2018 Post subject: |
The Sintesi uses a basic SEM ignition system. There is no separate cdi unit, just the stator and coil. It doesn’t rely on the battery at all. There are only 3 wires to the rest of the electrics. One from the coil, and earthing that acts to kill the sparks , and two from the stator carrying AC to the regulator/ rectifier.
First check is to disconnect the wire from the coil to the kill switch. If it then sparks the fault is in the main wiring to the ignition or kill switch.
The stator can fail, as can the coils. But think Electrex sell replacements of these. Flywheels are the difficult bit as they crack and lose the magnets. They are also pretty much unavailable. There is a company who makes replacement flywheels, stator sand coils, but it has no provisions for a starter motor.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| Robby |
 Robby Dirty Old Man
| 27alan |
| 27alan |
| bikenut |
| 27alan |
 Posted: 21:06 - 10 Dec 2018 Post subject: |
here are some photos, sorry about quality,
for some reason it wont let me upload the wiring diagram
its the standard af1 sintesi diagram from the net
https://cdn.bcf.44bytes.net/files/wiring_554.jpg
| bikenut |
| Meatybeaty |
 Meatybeaty World Chat Champion
| rs700 |
| 27alan |
| Nobby the Bastard |
| 27alan |
| rs700 |
| bikenut |
The last post was made 7 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
