Ground Anchor
Huarachedevil
PostPosted: 17:11 - 06 Dec 2018    Post subject: Ground Anchor Reply with quote
Hi,
I want to put a ground anchor in my back garden.
I have some paving slabs and not much else.
Which of these sounds best?
A anchor into slabs
B change area of grass or slabs into concrete to attach anchor to - cost?
C tub of concrete to attach to
D something else?
Ideally I'd have an Asgard shed but as the garden has a slight incline, I'm told to concrete it level would cost thousands.
Ideally don't want to spend much over 200 altogether.
Here's an example anchor, below. Would a different one be better suited to the location?
https://www.ghostbikes.com/1126-oxford-anchor-force-extra-strong-anchor.html?istCompanyId=afe640d6-8de8-42e7-8d54-69f4d3462c7b&istItemId=xpapiiaqwl&istBid=tztx&gclid=Cj0KCQiArqPgBRCRARIsAPwlHoV1mXvGO2ap-1pKmHkKAaOisKLKZAmuXsMmvrM3NM0YCOW8IaH1tEUaAiapEALw_wcB
Freddyfruitba...
PostPosted: 17:26 - 06 Dec 2018    Post subject: Re: Ground Anchor Reply with quote
No question. Cheapest and also the most secure of your options.
Make it as big and heavy as you can. When you pour in the concrete, put a length of pipe through it first that you can thread your bike security chain through; then no need for any form of expensive anchor (which would otherwise be the most likely attack point anyway.)
Riejufixing
PostPosted: 17:33 - 06 Dec 2018    Post subject: Reply with quote
Stitch-drill a 150mm hole into one of your paving slabs, make a suitably-wide-and-deep hole under it a bit wider at the bottom than the top using a garden trowel. Mix some concrete (a bag of "ready mixed just add water and stir" from a DIY place like Wickes or whoever), tip it into the hole, push in one of those long ground anchors with an eye at the top, finish the concrete at slab top level, job done, looks nice, trip hazard.
If you don't want to make a hole in a paving slab, just lift one, make a hole, fill the hole and the place where the paving slab was, push in the ground anchor, finish the concrete surface, job done, trip hazard.
If you want to use the ground anchor you mentioned, remove a slab, make a hole/fill with concrete/finish the surface, let it set for a couple of weeks, drill & fit your ground anchor (trip hazard).
Protect new concrete from frost by putting something over it.
Edit: If you're doing this on a grassy area you can see what you need to do....
owl
PostPosted: 17:44 - 06 Dec 2018    Post subject: Reply with quote
you could also drop the tub of concrete into the ground if you so desire and don't mind digging a bit
Observation is the greatest source of wisdom.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:18 - 06 Dec 2018    Post subject: Reply with quote
Or you could jus dig a hole and fill it with concrete.
Triumph Sprint ST 1050
Riejufixing
PostPosted: 19:25 - 06 Dec 2018    Post subject: Reply with quote
That's what I did. Mind you, I haven't got his swanky patio.
grr666
PostPosted: 20:01 - 06 Dec 2018    Post subject: Reply with quote
Why not attach that anchor to the house? They are pretty heavy last time I checked.
pepperami
PostPosted: 20:35 - 06 Dec 2018    Post subject: Reply with quote
HEADLINES: Bike thieves steal house! Shocked
Don’t put it past them if your bike is a nice one Laughing
Huarachedevil
PostPosted: 14:20 - 09 Dec 2018    Post subject: Reply with quote
Thanks for your advice guys.
With help, I'm going to lift a slab, dig, fill with concrete and level off against the height of other slabs, with the anchor bolted in.
In terms of the house thing, I worry someone might take a sledgehammer to the anchor and put a hole in the house wall. I could imagine that. Here, they can mess up the concrete as much as they like so long as the house is standing and structurally sound 😁
PostPosted: 18:09 - 09 Dec 2018    Post subject: Reply with quote
It's not a rented property?
If you take a sledgehammer to a paving slab then the slab will break very easily.
Dig a hole and fill it with concrete with a ground anchor set in it. Thumbs Up
ThunderGuts
PostPosted: 15:55 - 12 Dec 2018    Post subject: Reply with quote
As bigger a hole as you can dig (watch out for any buried services though as you dig!) and fill it with concrete. Not a bad shout incorporating a heavy chain into it to function as the anchor, but non-security chain even when massive can be quite soft and vulnerable to attack (although it's likely to put off a casual thief). If you're drilling 16mm holes (probably this size) for an off-the-shelf anchor, borrow an SDS drill from someone.
You want to be putting 100kg of concrete in really, that's about 45 litres ish - borrow a cement mixer if you can, it'll make it easier and make the finished concrete better. Don't skimp on the cement, it'll make a weak mix which anything you screw to will more easily break apart on. Getting concrete proportions correct is important - simple but vital.
Assuming the house is bricks or blockwork, don't bother with the idea of attaching it to the house, it's dead easy to loosen a few bricks and they weigh nothing.
I know it's been said time and time again, but layers are the best deterrent; a decent anchor arrangement, very heavy chain (16mm proper security chain) and corresponding padlock, decent disc-lock(s) and a good cover will go a long way to making any thief look for an easier target, unless it's an uber-desirable bike in which case they'll probably find a way!
TG.
owl
PostPosted: 16:32 - 12 Dec 2018    Post subject: Reply with quote
you can get anchors that you can set directly in concrete, rather than setting then drilling
like this....
https://www.ultrasecuritycentre.co.uk/media/catalog/product/cache/1/image_lst_9c5cc5a64a1071ae2d8a1bfa280f96dd/400x500/9df78eab33525d08d6e5fb8d27136e95/p/j/pjb552-pjb-ground-anchors_2.jpg
Nobby the Bastard
Harley Gaydar
PostPosted: 16:38 - 12 Dec 2018    Post subject: Reply with quote
The only trouble is all these options are that I keep my bike in my garage which has a variety of power tools that would make short work of all of these.
owl
PostPosted: 16:44 - 12 Dec 2018    Post subject: Reply with quote
Don't leave your toys lying around, lock them up Razz
They'd make quite a racket I'm sure if you're home, motion triggered cameras for when you're not.
The last post was made 7 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 81.69 Kb
