| JackDG |
 JackDG Renault 5 Driver
| bikenut |
 bikenut World Chat Champion
| JackDG |
 Posted: 15:44 - 12 Dec 2018 Post subject: |
Unsure about the bike running when it got picked up as somone else did it. While the bike did dump all its oil, the oil left over in the flywheel housing seemed free of metal.
Yeah I'm fine, it was back in sept but just getting to it now, it has its own thread somewhere
I didn't think there was anything useful in the photos but I'll post them in case.
https://i.imgur.com/SxKZ6V4.jpg
https://i.imgur.com/ZFd0tVq.jpg
https://i.imgur.com/GDC3IBq.jpg ____________________ 1992 GPZ 500 |
| bikenut |
| Sister Sledge |
 Sister Sledge World Chat Champion
| stinkwheel |
| bikenut |
| P.addy |
 P.addy Red Rocket
 Posted: 18:55 - 13 Dec 2018 Post subject: |
What possibly reason would require you to see the sprocket? its well hidden likely under a thick layer of shit.  |
| Riejufixing |
 Riejufixing World Chat Champion
| JackDG |
| Sister Sledge |
| JackDG |
| BanditsHigh |
 BanditsHigh Worse than a woman
 Posted: 21:09 - 16 Dec 2018 Post subject: |
^^^ I hope you have a new cover ... if you use that one you'll get oil everywhere
Looks like you were lucky the engine didn't get damaged ... been in a similar situation myself a few times  |
| JackDG |
| Sister Sledge |
| Riejufixing |
| bikenut |
| bikenut |
| bikenut |
 Posted: 14:52 - 17 Dec 2018 Post subject: sprocket |
Seen that set up for the front sprocket very recently, i wonder where.
Thanks for the pics.
As a matter of interest, does the front sprocket wobble on the g/box output shaft, and, does the sprocket rotate freely, even just a few mm, relative to the g/box output shaft, meaning that the "play" is designed in, or wear on the splines, to clarify a possible problem with a very recent post on this set up.
Does the set up shown "clamp" the front sprocket tightly to the gearbox output shaft so there is no relative movement between the front sprocket and output shaft on drive and over run conditions ?
Gear selection foot pedal broken.
Cant see the connection to the gear selection rod to the short front selection shaft arm.
The short arm may need re positioning relative to the selection "shaft", a spline or 2 so the short arm comes back into better "mechanical advantage".
Have you been having some gear selection problems due to this ?
The rod is adjustable for length, which will effect foot pedal height. ____________________ nuts about bikes |
The last post was made 7 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
