rattling clutch lever
talkToTheHat
PostPosted: 14:12 - 14 Dec 2018    Post subject: rattling clutch lever Reply with quote
metallic rattle at 8000rpm? no likely. Thought It was super-bas until it went away when i put a finger on the clutch lever. How can I stop the fucker rattling noisily? Still with the K2 GSF600S.
Bandit. does. everything.
bikenut
PostPosted: 14:22 - 14 Dec 2018    Post subject: shims Reply with quote
shims ??
nuts about bikes
WD Forte
PostPosted: 17:30 - 14 Dec 2018    Post subject: Reply with quote
thin rubber washer/s or O rings and dab of grease
bikers smell of wee
jaffa90
PostPosted: 00:26 - 15 Dec 2018    Post subject: Reply with quote
Ear plugs or maybe balance them wheels!
Robby
Dirty Old Man
PostPosted: 14:44 - 15 Dec 2018    Post subject: Reply with quote
Find out which bit is missing or worn out. I've seen all manner of things to act as a washer on a clutch lever, which invariably get lost and bodged on old bikes.
Could be as simple as a nylon washer which is a bit worn. The important thing is to make sure that the lever is fitting its bolt well, rather than packing out above and below the lever. That can make your clutch misbehave when the seasons change, and is a pain in the arse.
The last post was made 7 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 42.36 Kb
