crf250 r 2005 blowing out the side of headgasket??
merky369
PostPosted: 18:06 - 14 Dec 2018    Post subject: crf250 r 2005 blowing out the side of headgasket?? Reply with quote
hi all . im new to the forum and thanks for having me..
ive rebuld my crf 250 r from the ground up as it dropped the big end bearing out on me. anyway i went to start it today and started fine. sounded fine. but when i went to rev the bike putting it under load. i could hear a loud cracking as though there was a blow direct from the exhaust manifold so i looked down the side of the engine to confirm but it was not coming from the exhaust it was spitting out the side of the bore where the headgasket is.... baring in mind a brand new headgasket kit was fitted..
has anyyone seen anything like this before?
do the heads have to be skimmed prior to a new gasket fitted? both surfaces were thouroughly cleaned.....
theres no oil or water leaks ....
no mixing of fluids...
any help would be greatly appreciated
thankyou for reading
hear the ping? see the smoke? youve been passed, by a two stroke!
pepperami
PostPosted: 21:07 - 14 Dec 2018    Post subject: Re: crf250 r 2005 blowing out the side of headgasket?? Reply with quote
Firstly I’d be thinking, did you muck up when you put the new head gasket on? Ie nip it or crease it somehow?
As you mentioned a bearing going pop, and now this, I’d be looking to check there is not a blocked oilway somewhere.
merky369
PostPosted: 21:20 - 14 Dec 2018    Post subject: Reply with quote
i did get some oil on the coating of the facing of gasket but i wiped all clean before bolting up. i was extremely careful not to nip or crease the gasket.....
hmmmmm???
jaffa90
PostPosted: 01:30 - 15 Dec 2018    Post subject: Reply with quote
All mating surfaces should be flat, the head warps more, on low revved engines i have used a tile or a glass panel with a sheet of fine ????
(age thing) and rotated the head surface upon it.
bikenut
PostPosted: 10:49 - 15 Dec 2018    Post subject: single Reply with quote
What torque did you torque the cylinder head hold down nuts to ??
A picture of the area of the blowing would also help
nuts about bikes
doggone
PostPosted: 11:38 - 15 Dec 2018    Post subject: Reply with quote
Torquing the bolts evenly from each side is important, it shouldn't need skimming unless perhaps it somehow got very hot beforehand.
I can't see that happening on a bike though, more likely on cars, trucks, tractors with drivers good at ignoring developing issues.
merky369
PostPosted: 11:39 - 15 Dec 2018    Post subject: Reply with quote
39nm on each head nut. in criss cross formation taking 3 or 4 steps to reach desired setting.
heres a pic of where blow is . im pointing to it with my feelers. litereally if im on the rev fire is coming out lol.
bikenut
PostPosted: 12:02 - 15 Dec 2018    Post subject: flame Reply with quote
Nice green oe gaskets, you see flame coming from there??
cmsnl not toooo clear but is there a dowel on the rear head stud area on that side??
If flame coming out then either head and gasket not nipped enough or gasket damaged, may be warpage but did bike overheat in the past??
https://images.cmsnl.com/img/products/gasketcylinder-h_big12251KRN731-01_1b1f.jpg
This one yours form cmsnl list ?
When cold re torque and run again, else its head off and examine more closely.
If there is a dowel on that side, is it sitting in the holes deep enough or is it "bottoming" and or "topping" before enough nip between head and barrel for some reason?
Gasket looks as if it may be a laminated steel or metal type ? It would be very very difficult to fit upsidedown or the wrong way round.
nuts about bikes
merky369
PostPosted: 14:35 - 15 Dec 2018    Post subject: Reply with quote
flame is coming from head gasket. directly where i am pointing the feeler gauge..
ill take your advice and double check tourque.
if same ill rip head off and get more pics see what you guys think?
thanks for input so far much appreciated
Robby
Dirty Old Man
PostPosted: 14:40 - 15 Dec 2018    Post subject: Reply with quote
Well something is wrong. You're only going to diagnose it from taking it apart and looking.
It could be an easy problem - head gasket was bent or broken, mating surfaces weren't clean enough (I really, really hate cleaning mating surfaces). It could be a bigger problem, like a warped head. Easy to check - put it on a sheet of glass and measure with feeler gauges.
Of course, to split flames out the side, it needs to be quite a big hole. Not something as simple as using the wrong torque settings.
merky369
PostPosted: 15:33 - 20 Dec 2018    Post subject: Reply with quote
seems head werent touqued down enough. destoryed head gasket in process. what using a crap torque wrench gets ya !
anyway sorted that issue and fell into another. thanks for the input guys
bikenut
PostPosted: 11:36 - 21 Dec 2018    Post subject: TOOLS Reply with quote
Good tools always helps as does the correct torque values. Always a good idea to check torque after an engine run and allowed to cool right down, except for the modern dam stretch bolts.
nuts about bikes
The last post was made 7 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.74 - MySQL Queries: 13 - Page Size: 71.42 Kb
