| TheMadWelshma... |
 TheMadWelshma... Two Stroke Sniffer
| MarJay |
 MarJay But it's British!
| TheMadWelshma... |
| Riejufixing |
 Riejufixing World Chat Champion
| Riejufixing |
| TheMadWelshma... |
| MarJay |
| TheMadWelshma... |
| bikenut |
 bikenut World Chat Champion
| TheMadWelshma... |
| MarJay |
| TheMadWelshma... |
 Posted: 15:03 - 17 Dec 2018 Post subject: |
My thoughts exact mate.
And the court took my licence away from me while I was there so didn't have a chance to keep it. Wanted to keep it had a good picture of me on it.
Never shit happens so they say. Not to well at the moment to work too much so hopefully in the new year I can start saving and get my full licence back. Till then I'll sort this little one out and get back on the road. That will be a buzz in its own tight. The bike has already had extensive work done to change it into a bobber type bike. Looks quite good to be fair. |
| Evil Hans |
 Evil Hans World Chat Champion
| Evil Hans |
 Posted: 17:12 - 17 Dec 2018 Post subject: |
But all that aside, AJS used to do a 350 Regal Raptor and for a time sold a conversion kit for the 125. Totally illegal on an L plate, but ... meh.
There is a facebook (yuck) group for Modern AJS Owners - see if anybody has any ideas there: https://www.facebook.com/groups/NAJSOG/ ____________________ Triumph Sprint ST 1050. And it's Red. |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:43 - 17 Dec 2018 Post subject: |
Licence status asside..... The AJS-Regal, Raptor DD125; see webby links at the bottom, that was what wound me up with the Snowie sat in the corner there.......
ACTUALLY not a bad bike.... slow... and trying to do much about that is as much an exercise in elevated frustraion and futility as trying to knit spagetti!
It is, in it's oldest incarnation a bolt-for-bolt chinese copy of the Honda CM125 Rebel, with the little Benly twin engine.
From memory, it is only a couple of kilo's lighter than her-nibs Bludi-750-Guzzi; it aint no fly-weight-light-weight! So your 16 stone shoudln't make much odds!
For note; I tooled about a bit two-up on Snowies, with her on the back, when she was looking for another bike. That put's close to double your lard on top of the thing, and it still shifted..... so it shouldn't struggle any with just you on board!
It is, from the off a slug. Her's was black, adding to the allusion, but still. That's 10bhp for you. It's enough to do about 55mph, which was as much as I ever got out the dang thing; solo, two up, down a steep hill.... it just wont go any faster.... which is probably no bad thing, given the cruisery styling..... it aint no road-burner!!!
Have to mention the tyres.... they are horrible, cheapo last for ever things, that dont inspire confidence. They do grip.... just.... and I would regularly be scraping chrome round the bends on them.... mostly cos having got up some road-speed I was loath to loose any to corner, and it had eff-all ground clearance to lean before chrome started scraping!
I have to say that they 'sort'; of felt more planted when ridden hard and loaded up like that, but it was always a sphincter twitching time tipping in, whether they'd bite or not. I never had them step out on me, but Snowie going solo did.
And that's sort of it; it's a cruiserette; something with that sort of styling is never really meant to go round corners with much aplomb, and anything with just a 125cc motor, is going to be doubly disadvantaged; just be glad it goes, A-N-D console yourself that for all the missing oomph, you get plenty of miles for your gas-money....
That little 10bhp twin is ultra-smooth for a four-stroke 125; it doesn't make enough power to wast any shaking! But on its single carb, it sips petrol like a 15 year old in the pub with thier pocket money!
I think in just over a year, Snowie, using the thing as every-day commuter, plus the odd jaunt to go look at other bikes, or go to meets she wanted, she had to fill that not-so small peanut tank about half a dozen times! I think she had to change the oil more often!
Perking it up?
Forget it.
It's a derivative of the 125 Benly motor. The most powerful of that genre was the 1977 CB125T 'Twin', that chucked out a claimed 17bhp, as much as it' contemprary two-stroke twin rivals.... NO you cannot endow your engine with that power just fitting the 'T's biog twin carbs. The crank in the 125Twin, was 180 Degree timed, ie one up one down pistons; the other Benlys, inclucing the Chinky Derivatives have the 360 timed crank, both pistons rising and falling together, and most of the power the 125T offered was thanks to a much more lumpy cam-shaft. Most Benleys have a much softer cam, and it's timed for pistons riding and falling together; the Chinky derivatives, generally have an even softer still cam profile, derived of the last of the line CB125TD-J engines, with hi-vo, toothed rather than roller cam-chain, and cranks cast with a gear to suit, rather than a sprocket; simple substitutions are not on the cards here; and you have the niggles of the ignition, which on the 180 motor has twin triggers for the one-up-one-down piston timing, compared to the 360 timed motors that have simple single trigger 'lost-spark' systems, putting a fire in both holes at the same time, relying on the fact one will be on compresion with chage to set fire to, the other blowing smoke, and when it's done one full crank rev beyond, they swap over.
In effect, you would from the crank-cases up, have to get the right bits to build a CB125T spec 'full-power' motor.... and best of British trying to get the critical bit of the 309 camshaft..... they are rare as rocking-horse (well, I have a couple... but BOY were they hard to come by!)
Far simpler and easier to simply chuck in one of the 'big-bore' benly engines. They are pretty much a bolt-for-bolt swap. BUT you are STILL not exactly looking at enormous power.
The most common motor is probably the CD200 lump. That claimed the audacious output of 15bhp.... it would still be near enough 'learner-legal' were it not that it got too many cc's! Does have a chunk more low-down grunt, though, and 50% more power than the DD125 does 'as stock'... just don't expect it to be much if any quicker for it.....
I briefly stuck a 200 Benley motor in a CB125 Super-Dream; frame. It manged about the same 'just' 70mph top-wack... slightly nicer than the 13bhp S-D on hills, and it actually had some grunt on the throttle to accelerate through bends a bit; but the difference was pretty negligible, certainly on the top-end.
The CB 'Two-Fifty', is a little pokier, that provided a claimed 19bhp. But even in that, its only 'just' a 70mph motorcycle, rather loath to be coaxed much if any above that very often.
Compared to the 55mph out the DD125 as is... this may seem worthy... but.... its 'just' enough to get you out the gutter and 'think' you can cut it on the duelie, with blitzen-bimmers trying to give you an Audi-Enema the whole while...... ie, let you go 'just' that bit fast enough to change your mind-set from being resigned to the 'slow', finding the fun NOT wasting speed for corners, and enjoying the economy, to just being terrified, NOT just having one twit up your chuff trying to get past, but every single one, just before they do!!!
You then get into the arena of modded bikes; and as some-one has already pointed out, at 125cc it's learner-legal, with all the ramifications, particularly of being reletively easy to flog-on... modded bikes tend to be money-pitys anyway, and taking a 'cheap' Chinky 125, and doing the dispicable to one, spending money to make it even less valuable, is perversion layered on perversion.... just send ME your money if you have that much to 'waste'!!! lol.
Snowie's was a 2004 registration; she bought it in 2007 for less than £500, 1/3 the dealer price on the invoice in the docs that came with it. A-N-D for a low rent chink, it was actually better than most.... fact she';s a Solvol-Freak probably helped, but it didn't look too bad and held up reasonably well to the elements it lived in.
Getting bits was a tad harder. Hayned don't do a specifric manual; you sort of have to make-do-and-mend from the Haynes book of Chinky Bikes, and the Honda CB 125 Super-Dream, CD125 Benlet and CM125, possibly a 'Rebel' book, and CMSL micro-fishe schematics... then.... 'bits'? Well, AJS main website was great if you wanted to buy a whole bike, or a pair of tassled paniers.... NOT so wonderful if you wanted a set of brake pads..... question of knowing what biots, like handle-bars are 'sort' of standard and taking a chance on the rest off e-bay from description and guesstimate of what fits CB125's and the like!
BUT, on a bike like this, that will NEVER be worth, much more than the dead-metal weigh-in weight, spending ANYTHING on the darn thing, even on basic routine maintenance, like oil changes, and the proper £10 tappet key and lock-nut spanner (that really do make an awful lot easier BTW), is suck-in-your-teeth time, whether its worth it... let alone spending anything on 'mods' whether cosmetic or performance!
Having mentioned the big-bore benlys; if you were to go try source a motor from one, the likelihood is that you would get a whole bike cheaper than you would an engine..... especially as they are now 20+ year old miser-mile commuter hacks oft run into the ground, and not learner-legal.
But STILL... if you were to contemplate that 'mod'.... you would be as well or better off, spending your time effort and money, fixing up the donor CB-Two-Fifty, or whatever, as you would the Raptor.... even the unloved 20 year old commuter hack, in working order would be worth as much cash value as the less loved Cheap chink, and stand better chance of being worth more of whatever £ you sunk into it, as well as easier to do, and to live with, as a known 'Japanese', in the data-bases, in the parts-listings, quantity.
In your shoes?
Well, with Snowies, first MOT fresh Raptor, I didn't have a renovation project on my hands! Just some niggles to try find a Chain & Sprocket set and a guess at what the tappet clearances should be, and a 'little' damage to replace the bars where she dropped it cos of that stupid concrete back tyre, and the perverse seating position, with wide bars demanding that little-lady with T-Rex arms, lean the wrong way to turn!
As a ground-up, 'Project'? I WOULD not touch one with a very very long barge pole! And I am used to chucking money away renovating 125 Super-Dreams! Call me crazy... but tackling a Raptor is an altogether different level of delusion!!!
Depending on how bad the base is.... it COULD be a 'fun' little project to scrub one up enough to get through an MOT and spend as little money to get there as possible... BUT.... if there was anything majorly missing, or damaged or knackered, it REALLY would be a non-starter from my perspective, and even just trying a slippery slope of delusion compounding!!!!
So, I would be VERY VERY sanguine over taking this on as a project.....
And hint that former owner, possibly multiple owners, plus your lad, have all tried and so far failed, AUGHT be a pretty big hint, that no matter HOW cheap the thing, you are likely onto a very big looser before you begin......
But hey... go for it.... maybe when your done I can interest you in an apple-crate 125 Super-Dream Lol! Yoi MIGHT just be mentally deficient enough to go for it! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
There is a gap of 1 year, 113 days between these two posts... |
| TheMadWelshma... |
 Posted: 10:18 - 09 Apr 2020 Post subject: |
I'm so so sorry I never replied sooner. Had a lot of things happen in my life and went tits up. Started ggogling again today for info and this old post of mine came up.
I feel really bad you went to so much bother typing all that up and I never replied. Really sorry mate.
And thank you.
Tony
| Teflon-Mike wrote: | Licence status asside..... The AJS-Regal, Raptor DD125; see webby links at the bottom, that was what wound me up with the Snowie sat in the corner there.......
Perking it up?
Forget it.
In your shoes?
But hey... go for it.... maybe when your done I can interest you in an apple-crate 125 Super-Dream Lol! Yoi MIGHT just be mentally deficient enough to go for it! |
| MarJay |
The last post was made 6 years, 155 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 120.09 Kb
