| Qucartwd |
 Qucartwd L Plate Warrior
 Posted: 15:52 - 17 Dec 2018 Post subject: Full suspension E-Bike for touring? |
Hi,
This is a discussion, for the optimum electric propulsion for a heavy touring bike, assuming big grade slopes (positive and negative) along the way.
I wish not only to drive on roads (and cars), but also to cross countries by off road trails. (4x4 gravel roads at worst - not single tracks, drops, jumps...)
I did such a touring across Estonia by using Google Earth to locate forest roads. It was amazing. I didn't have a motor (it was just flat anyway), but some forest roads were quite bumpy to my back, hands, and to the equipment I was carrying. (I used a rigid touring bike)
First, I wonder if there exist a full suspension bicycles for touring:
Probably with shorter suspensions, but with geometry that allows standard front&rear racks to be used, so they located in the SPRUNG zone of the bike https://mechanicfaq.com/shocks-for-harley-touring/?
There are solutions to regular full suspension bikes, but those racks are attached to the unsprung parts - for example on the fork beneath the shock absorber.
I would also like to use 700c tires, and not small 20inch or so.
I was considering, however, the option of taking my full-suspension E-Bike that has two motors, and attach a trailer behind it for the equipment. This adds a significant drag, and it would be impossible to use it outside of well paved asphalt roads.
Now about electricity:
I see two optimum options:
1. Front DD motor and rear geared motor: The front works alone during flats where it's more efficient and low power is needed, and also regen during downhills. The geared joins at takeoffs (to pass as fast as possible the low efficient speed zones), and works continuously with the DD during uphills.
I have such configuration, and compared to just a single front DD - I save 40% of the energy during uphills.
The location is also optimum for each motor - More weight and traction is needed on the rear wheel during ascents, and more weight and traction is needed on the front during descents.
The downside is that only one motor is working during regen (and it's significant with touring weight), and the geared-motor wouldn't live long with the added equipment weight above while off-roading.
2. Two identical DD motors - For example two H3540's, which exists both as front and both as rear. This increases regen recovery compared to a single H3540 but it's less than two-fold power increase like on forward propulsion - in the order of 20-30% increase from the regen of a single DD. It does however let you regen more slowly, and powerfully, especially if you go down very steep roads with sharp turns - and add some rain to make the scene more interesting. As you slow down on a 2x2, you are much more weather resistant against slippery. It simplifies the use of a single throttle and CA, but still requires two controllers. (Phaserunners).
The downside is the much higher weight (15Kg for 2xH3540, compared with 10.5Kg for H3540+Ezee250), and a double cogging torque in case you have to pedal alone if there is a flat battery or other malfunction.
What is your opinion?
| Ste |
 Ste Not Work Safe
| Riejufixing |
 Posted: 16:48 - 17 Dec 2018 Post subject: |
| Evil Hans |
 Evil Hans World Chat Champion
| G |
 G The Voice of Reason
 Posted: 17:27 - 17 Dec 2018 Post subject: Re: Full suspension E-Bike for touring? |
https://endless-sphere.com/forums/ is where you want to be.
But, seeing that wit the right system you can have more power than a lot of small motorcycles...
I'd go for a mid drive personally - that way the wheels stay light, so you can take the luggage off and have some fun.
However, plenty do fine with direct drive and the big names like Stealth use them of course.
I have panniers that connect to the wheels on a full suspension bike - though they aren't setup to work with an electric motor as it works with QR spindle wheels.
Look for 29" bikes - they can take 700c tyres. However, you'll be losing out on grip if you go for road biased wheels.
You could also consider a 'pusher trailer'. I've got a mountain bike trailer that can take 200kg or so and be pulled by a normal push bike or my direct drive hard tail bike.
I've since added 2x1kw or so low geared geared hub motors with wide 20" unicycle rims show with 16" (they are measured differently) motocross tyres for loads of grip.
It can be used as a 'pusher trailer', or just to help move the load.
However, it was made for taking big loads short distance, not small loads big distances. |
| Teflon-Mike |
 Posted: 03:09 - 19 Dec 2018 Post subject: Re: Full suspension E-Bike for touring? |
| Evil Hans wrote: | | Qucartwd wrote: | What is your opinion? |
I am of the opinion that you have come to the wrong forum. But we're pleased to meet you, anyway. |
I am sort of sanguine on that, and ACTUALLY since to LEGALLY ride an electric push-bike that's any faster and more powerful than the things they flog at Toys-R-Us for toddlers to bruise school-run-mums shins with..... it needs to be registered as a motorbike, and be subject to the same tax, MOT, insurance and rider licence as something powered by petrol..... HE JUST might have actually stumbled through the right door into here!!!
Idea that adding a motor to a push-bike to go longer distances might be a good idea, isn't anything particularly new or novel.... and the conclusion for the best part of a century has been the 'Motorcycle'.... which begs conundrum... what's the 'advantage' of an e-bike?
Take on board, the fact that if it can actually do the job hoped of a motorcycle, it needs to comply with motor-vehicle law, have a number-plate, tax and insurance, and the rider must have a licence and wear an approved 'motorcycle' crash hat... it's starting to loose the attraction as far as cost and convenience goes; chuck in the little niggle of what to do when the batteries go flat, compared to topping up a petrol tank... to my mind, its a camel of an idea, before you chuck in the red-tape-gymastics surrounding trailer laws, and the fact that you aren't allowed to tow one with a motorcyle beneath A2 licence regs......
It's entire merit, as a start point would seem to be flawed.... add a motor, its no longer a push-bike; it's NOT some-sort of eco-mental salvation.... fossil fuels still have to be burned 'some-where' to make the electric it uses.... and the rider not pedaling, cant even look smug and make mutterings about endorphins and muscle tone.... while they try dodge road-traffic law, riding something that should have tax, test, licence and a crash hat, without!!!
And ultimate answer to the OP's conundrum, would ultimately be something like:-
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcTw3X4CTp4q88SBZvNpXdkh1rT9WnWuwIU1U_ipn4ALcjdM9Aby
Which brings us back-around.... he possibly HAS stumbled, unwittingly into the 'right' forum!!!
He needs introduce himself in the New-Bikers section; ponder CBT and the routes to a motorcycle licence, then look at the touring and adventure section for further inspiration!!!!
The Long-Way-Round... by e-bike...... I suppose there's lots of sun in the Gobi...... how heavy are solar charging panels....... I wonder if you could mount them on the side of the rack to charge as you go? Hmmm... part push-bike, part hang-glider!I wonder whether you'd need a private-pilot's licence as well as a motorbike licence? Lol..... Could be fun, filing a flight-plan to go to Sainburies!!! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| G |
| BusterGonads |
 BusterGonads Trackday Trickster
| barrkel |
 barrkel World Chat Champion
 Posted: 12:21 - 20 Dec 2018 Post subject: |
| BusterGonads wrote: | The 12 miles an hour maximum electric bike speed allowed by law here is a joke. It should be ignored as should all stupid, interfering crap foisted on us by meddling arseholes in those comedy circuses at Westminster |
The reason they foist this on you is the NHS. Can't have a nationalized health service without making public health in the public interest, otherwise you're potentially wasting the public's money on injuries caused by particularly reckless members of the public.
If you could opt out of the NHS with some proof or evidence of private health care, and that private health care gave you extra rights or relief from restrictions; or there was insurance mechanisms to guarantee that the reckless paid for their tomfoolery, things might be better.
(Brussels is more likely to introduce legislation to avoid mockery of per-country regulation on the continent, where you can simply hop over the border into another country in your now illegal vehicle. International legislation for minimum standards is unavoidable in integrated economies.) ____________________ Bikes: S1000R, SH350; Exes: Vity 125, PS125, YBR125, ER6f, VFR800, Brutale 920, CB600F, SH300x4
Best road ever ridden: www.youtube.com/watch?v=s2MhNxUEYtQ |
| Baffler186 |
 Baffler186 World Chat Champion
| Ste |
 Ste Not Work Safe
| G |
| Sister Sledge |
| G |
The last post was made 7 years, 270 days ago. Instead of replying here, would creating a new thread be more useful? |
