| Magnaman |
 Magnaman L Plate Warrior
 Posted: 21:20 - 22 Dec 2018 Post subject: 1984 v30 magna carb idle issue , i need help please |
what would cause idle to be 4500 on v30 magna? i got some carbs
off ebay, cleaned the carbs with carb cleaner, installed new low jets, could see thru main jets and tubes, ive cleaned every hole i could find, with carb cleaner, i put carbs back on, bike starts up first or second time turning over,. but it goes strait to 4500 rpm. ive tried lowering rpm with idle knob ( between #2 and #4 carb but turning it doesnt have an effect on the idle, whats up with this think now? thanks, ____________________ Magnaman:) |
| jaffa90 |
 jaffa90 World Chat Champion
| .Chris. |
 .Chris. World Chat Champion
| Sister Sledge |
| Robby |
 Robby Dirty Old Man
| Magnaman |
 Posted: 23:29 - 23 Dec 2018 Post subject: |
Thanks guys for all those possibilities.
ive checked cables,
i have even loosened cables up and checked to make sure they wasnt hangin up... i assume they are routed right, ..ive never honestly ever seen a diagram of how theyre suppose to be routed, other than the way they are routed. ive had the carbs rebuilt back in 2010 , theyve worked fine the way ive hadem routed since then. but i will double check the routing.
2) Yes Robby, the screws are 2 1/2 turns out
3) i did not rev the motor, as its only spose to idle at about 1200, i started it and when it went to 4500 rpms i shut it off.so not to damage the motor or overheat it. . ..since the black idle screw wouldnt let idle back off any
4) .. now one thing i DID notice when i was cleaning these carbs is one of the diaphrams was slower to drop then the rest of them when i raised them with my finger.
id hafta look at them again to see which 1
is it possible the outside of the vacuum slides need cleaned ?
i wiped them off when inchecked diaphrams for holes but i did see any pblm with rubber on diaphrams but i didnt know what to do about the slides. other then wipem off.
well im gonna take them off one more time but if i cant see whats wrong then i am about ready to just find someone i can afford, who wont gouge me too much and just sendem off an letem clean them professionally an go over them and make sure everythings set right so when i getem back they ll just be boltngo thatd be nice..thats where i gotem rebuilt before was a guy named keenan out in california and they was actually called boltngo
wish i could locate him again....
thanks e1 for your input. an Merry Christmas!! |
 Posted: 00:12 - 24 Dec 2018 Post subject: |
I presume you put the airbox and filter back on over the stacks before trying it? Haven't tried it but I'd imagine it would run like a bag of shite without the airbox on.
But yes, I'd also be looking for air leaks, those V4 carb banks take a bit of force to clunk back in and a magna isn't exactly new so the rubbers wil be stiff.
So did they go back into place with a final, satisfying clunk? If not, they might not be seated in the stubs properly. I generally apply a light smear of red rubber grease to the inside of the inlet rubbers on my VFR750 to get the carbs back in properly.
Choke mechanism can also get sticky, make sure it's returning to off properly. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| jaffa90 |
| Robby |
 Robby Dirty Old Man
| .Chris. |
The last post was made 7 years, 262 days ago. Instead of replying here, would creating a new thread be more useful? |
