Do indicators need to flash?
adengtg
PostPosted: 18:17 - 27 Dec 2018    Post subject: Do indicators need to flash? Reply with quote
Flasher relay just gave out a few days ago and ive managed to bypass it so the indicators just stay lit when i turn them on while i wait for a new relay to arrive in the next few days. Ive not ridden the bike since but would it actually be safe to ride with it set up like this or would it be better to just use arm signals or not ride at all?
Thanks very much.
PostPosted: 18:29 - 27 Dec 2018    Post subject: Reply with quote
Safe? Yes. Legal? No.
I would use hand signals.
I have no flashers fitted to my 350 bullet (I should do but I rely on police ignorance) but I wonder if seeing a bike with flashers fitted using hand signals would be an excuse for a tug.
If you get satopped by the police, you are comitting a construction and use offence UNLESS it is an offroad bike with only one seat.
adengtg
PostPosted: 18:31 - 27 Dec 2018    Post subject: Reply with quote
Ok, i would only be using for quick necessary journeys anyway. Thanks very much for the help!
M.C
PostPosted: 19:52 - 27 Dec 2018    Post subject: Reply with quote
What if you used your solid indicators but also did the universal left your indicators on hand signal? Smile
Sister Sledge
PostPosted: 19:54 - 27 Dec 2018    Post subject: Reply with quote
Switch on and off twice every second??
CCM 404 DS
adengtg
PostPosted: 20:49 - 27 Dec 2018    Post subject: Reply with quote
Haha, could do!
Fin
PostPosted: 22:48 - 27 Dec 2018    Post subject: Reply with quote
I've got rear indicators but used hand signals for about 2 months now (because the front aren't on and the fuse occasionally blows if I use the back without the front connected).
Haven't been tugged although I haven't seen any police, possibly due to having no mirrors and having earphones in all the time. I likely wouldn't hear the police if they were right behind me and beeping the horn at the same time, I make sure to look for the blue reflection of other objects though so I got out the way of an ambulance the other week.
PostPosted: 13:38 - 28 Dec 2018    Post subject: Reply with quote
My American import Goldwings had the indicators on 'dim' while running. I can't ever remember a car thinking I was turning.
I wouldn't trust any driver to take a blind bit of notice if they aren't flashing.
Hand signals Thumbs Up
Triumph Trophy Launch Edition
M.C
PostPosted: 13:56 - 28 Dec 2018    Post subject: Reply with quote
Sounds pretty normal Smile Very occasionally indicators will help you get into a different lane, although drivers are just as likely to see it and accelerate to close the gap Rolling Eyes
Just out of curiosity how do you hand signal when you're turning right on a mini roundabout? Black power salute?
https://www.buzzle.com/images/hand-gestures/riding-hand-signals/right-turn.jpg
PostPosted: 15:57 - 28 Dec 2018    Post subject: Reply with quote
You stick out your right hand. Once at the point where you'd normally do your rearward obs and put the flasher on and once as you are about to move away from or cross the roundabout threshold, just before your final lifesaver.
Of course, if it isn't going to provide other road users with useful information (like if there is noone waiting to join the roundabout), then don't bother, same as with flashers. if you think an extra one will help understanding at any point, throw it on in there.
If you can't cope with the slight deceleration or absence of braking caused by momentarily removing your right hand from the bars, you probably aren't planning far enough ahead. The only time I find RHS hand signals an issue is when changing up a lane on the motorway. That said, if someone needs to change what they are doing on the basis of that signal (which I generally ommit) then my obs weren't good enough.
M.C
PostPosted: 16:08 - 28 Dec 2018    Post subject: Reply with quote
Imagine the yellow car's coming from the top exit turning right, despite red car having full view of my indicators, yellow cars position in that picture is about the time I've normally started braking as I'm not sure if Mr Car has seen me and/or plans to stop.
https://www.drivingtesttips.biz/wp-content/uploads/2014/05/mini-roundabout.jpg
You'd either be doing a hand signal and still moving into their path, or not doing a hand signal in which case they'll likely enter the roundabout if they haven't worked out which way you're going.
I appreciate the standard of driving might be better in other parts of the country.
PostPosted: 16:17 - 28 Dec 2018    Post subject: Reply with quote
In which case, stop anyway. He shouldn't be driving onto an occupied mini roundabout anyway so if you're worried he's going to go, stop.
Or be more assertive with your road positioning.
It strikes me, if he's there, he'd have been in a position to see your signal as you crossed the threshold onto the roundabout. I've never seen a mini roundabout an anything but a 30 limit. So he will either pull out, or he wont, hand or light signal notwithstanding.
M.C
PostPosted: 16:31 - 28 Dec 2018    Post subject: Reply with quote
In my experience especially if the mini roundabout isn't just painted on (does that make it a proper roundabout? Smile) they tend to see signals pretty late. It's the same when cycling, if you don't use a hand signal that late (yellow car position), you're likely going to get run over or have to take avoiding action. It's a similar scenario on a bicycle as obviously you'll only have control over your rear and not front brake, but you have a bit more control of your speed with the pedals.
The last post was made 7 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 81.77 Kb
