| dransy |
 dransy World Chat Champion
| stinkwheel |
 Posted: 22:55 - 28 Dec 2018 Post subject: |
Bit more of an idea what the setup is on your bike would be handy, there are a few ways of fitting fuel taps. Make and model would probably suffice so we can look at a fuel tap on ebay.
Did the original bolt go all the way through or was it a blind hole?
What size did it start as and what size is it now?
The answer is probably either JB weld or a solid rather than coiled thread insert (or a combination of the two) but it's possible something funky and simple could be achieved with o-rings or dowty washers depending on the setup. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Islander |
 Islander World Chat Champion
| Riejufixing |
 Riejufixing World Chat Champion
| dransy |
| stinkwheel |
 Posted: 01:36 - 30 Dec 2018 Post subject: |
If the fuel is only leaking out past the head of the bolt, you could fit a dowty washer under the bolt head in place of the usual spring washer.
Or is it also leaking round the helicoil? Is the drilled out section now bigger than the area encompassed by the o-ring? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dransy |
| Pjay |
 Pjay World Chat Champion
| Tankie |
 Tankie Crazy Courier
The last post was made 7 years, 260 days ago. Instead of replying here, would creating a new thread be more useful? |
