| Cookiemonster... |
 Cookiemonster... Renault 5 Driver
| MarJay |
 MarJay But it's British!
| G |
 G The Voice of Reason
| Cookiemonster... |
| MarJay |
| Cookiemonster... |
| Kawasaki Jimbo |
 Posted: 21:40 - 04 Jan 2019 Post subject: |
| Cookiemonster... |
 Posted: 21:51 - 04 Jan 2019 Post subject: |
damn, another clever idea- this piston is dead anyway, what do I have to lose luckily I have something like that but I didn't think of it. |
| virus |
 virus World Chat Champion
 Posted: 01:31 - 05 Jan 2019 Post subject: |
If you dont understand that brake master cylinders are brake master cylinders, nor understand that putting water in a brake system at any time is a bad idea then I suggest you dont work on brake systems.
top tip, google the word 'hygroscopic'. ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| bladerunner |
| bikenut |
 bikenut World Chat Champion
 Posted: 11:53 - 05 Jan 2019 Post subject: stuck caliper piston |
You can use water, hot water, but not how you suggest.
Refit caliper and hose to bike. The hose will allow the caliper to reach a bucket of very hot water I am sure.
With the system containing fluid being pumped, with the caliper placed in the very hot water and expanding like mad, pump away and watch the piston move. If its possible, pump the piston right out.
Then, removed from water and dry all wetted components within 5 minutes. You could dry off and then cover with fluid, then examine and go from there.
Then you can examine the piston ( corroded and deeply pitted no doubt ) and caliper bore. The area between the hydraulic seal and outer dust boot will be corroded and also pitted no doubt, the probable cause of the piston sticking badly and "siezing".
I assume the caliper has just one piston ??
If it has 2 or more, same principle but do not let the other pistons come out at all. Use g clamp or similar to keep them in place.
"Excersize" one piston at a time, pump out as much as you dare, lube and g clamp back in, repeat until piston is "free", Repeat with all the others. When all pistons are free, strip down. Give your self the time to do all pistons in the same "session", do not leave wetted with water and come back to it a week later!!!!!!!!
post some pics......do you have a compressor? ____________________ nuts about bikes |
| Robby |
 Robby Dirty Old Man
 Posted: 12:37 - 05 Jan 2019 Post subject: |
To answer the original question, if the rear master cylinder can't be used then just connect it up to the front brake and pump it out there. It helps to pour some brake fluid into the caliper before putting in the banjo bolt, takes less time to bleed the air up the line then.
Otherwise, as it looks like you have now realised, the best thing to pump out a brake piston is the existing brake system. If the caliper is so seized that it can't be pumped out, buy another caliper.
As for water, whilst you can technically use it, it means stripping and cleaning the whole system afterwards to get it dry, then flushing through with brake fluid, then doing another brake fluid change after a week or so. Use brake fluid and buy some gloves. The Ed China tigergrip gloves are surprisingly good, they last all day. |
| Cookiemonster... |
| Robby |
 Robby Dirty Old Man
| Cookiemonster... |
 Posted: 21:28 - 05 Jan 2019 Post subject: |
Pre filling the caliper with fluid to the top flush with where the banjo ring would sit and pre filling the master cylinder to the top flush with where the ring on the other end would sit as well as filling the resevoir makes the amount of air so tiny- don't know where I saw that advice about a year ago but it's worked miraculously ever since as well as now.
However getting fluid back into the system with no air still didn't work. Piston still seized. So I drained the system again
And resorted to grease gun. Worked beautifully. Need to jet wash grease out now and get new piston after the abuse it's received. It's ok the whole caliper is getting rebuilt so the water is fine at this point.
Yes I know what hygroscopic means already and that brake fluid is that exactly. That's why I asked if it would be ok if I got rid of the water.
At one point I even tried dremeling a notch and hitting with flathead to shimmy it around and out. I'll edit and post some pics in a bit.
I don't want to spend much money on a single piston but a rear piston set costs 20 quid. A brake disc piston is just a cylinder with an open top after all- is there a resourceful way I can get the exact size and get something that will do the job for like a fiver? |
| kramdra |
 kramdra World Chat Champion
 Posted: 23:13 - 05 Jan 2019 Post subject: |
What the shitting fuck are you doing?!?!?
A used rear calliper and master assembly, with hose and good piston and as-new pads, can be under 30 quid delivered. This is what I'd suggest. What bike is it?
A master cylinder makes a shit hydraulic pump for piston removal, the displacement volume is too low combined with the non-valved ports, prevent building pressure on multiple stokes. No good for tokico 6 pots..
https://www.ebay.co.uk/itm/273630490371 This would do it, but expensive. |
 Posted: 01:15 - 06 Jan 2019 Post subject: |
If the whole system is being flushed and cleaned there's no harm in using water, most people don;t realise how far they are injection it into their system when they get turn the jetwash on their bike but cooking oil will do just as well to pump out a stuck piston and it's cheap, easy to get and totally non-harmful.
2/10 for trashing the piston must try harder  ____________________ a.k.a 'Geri'
| Cookiemonster... |
 Posted: 06:28 - 06 Jan 2019 Post subject: |
| Cookiemonster... |
 Posted: 14:52 - 06 Jan 2019 Post subject: |
I'm youtubed and googled the uses of the tool in your link- I can't see how someone would apply it to get a seized piston out- it's for punching holes isn't it? would you care to explain please?
I get we're exploiting the hydraulic function but what would be attached to where? |
| kramdra |
 Posted: 20:23 - 06 Jan 2019 Post subject: |
| Cookiemonster14 wrote: |
You'd disconnect the punch and attach your calliper to the hose. There are cheaper options, like modifying a bottle jack, but this requires just disconnecting a hose. I could find a use for the punch, so I might get one. |
| Cookiemonster... |
| kramdra |
| Cookiemonster... |
 Posted: 12:25 - 08 Jan 2019 Post subject: |
All the cheap ones seem to be sold out everywhere now cheapest I can find is roughly £100. Not that I need it right now- just seems like a useful tool if can be found cheap. |
| bikenut |
The last post was made 7 years, 295 days ago. Instead of replying here, would creating a new thread be more useful? |
