CBR tacho stopped working randomly
bigdom86
PostPosted: 11:04 - 08 Jan 2019    Post subject: CBR tacho stopped working randomly Reply with quote
Hi All
my 02 cbr f4i tacho and speedo stopped working today on my ride into work, not a massive issue. I have read a few threads and looks like I will need to take apart the front end of the bike quite a bit to get into the circuit board and clean things up (apparently most likely culprit is rusted screws?) - no haynes manual or tools currently, how much of an issue would it be just to ride the bike for the next few months without the tacho or speedo? I am just doing London commuting so don't need to worry too much about speeds Laughing
ThunderGuts
PostPosted: 17:05 - 08 Jan 2019    Post subject: Reply with quote
If the speedo is mechanical, check the cable is connected into the speedo and into the mechanism on the wheel; mine dropped out the back of the speedo recently and killed the speedo. Not sure about the tach though and seems a bit odd that both would go simultaneously. Is your odometer still working?
TG.
Nobby the Bastard
Harley Gaydar
PostPosted: 22:47 - 08 Jan 2019    Post subject: Reply with quote
If the speedo and tacho aren't electrical you've been very unlucky to lose both simultaneously.
Working on the principle that it's electrical as a result, the common wiring would be the earthand depending on the deeign, a 12 volt constant power supply.
Check the earth is working first, and then investigate power supplies to the clocks.
You have check that a plug hasn't come loose or a fuse hasn't blown?
Triumph Sprint ST 1050
PostPosted: 00:39 - 09 Jan 2019    Post subject: Reply with quote
My VFR once did that right before it cut out due to a cooked battery (duff reg/rec) so worth putting a meter over the battery as a precaution.
In 02 honda still had a habit of using flexible PCBs to back their clocks. Corroded tracks are a common fault. This is probably what it is. You'll see it when you get to it (enjoy dismantling your entire motorcycle).
Most bikes wouldn't bother. SOME bikes have the CDI tied into the rev counter (mostly kawasakis) and expect a resistance on the end of it or they won't run. Some grey import japanese bikes have the CDI tied into the speedo and will only run on two if it's disconnected.
The fact it's running normally suggests this isn't an issue with your bike.
bigdom86
PostPosted: 13:44 - 10 Jan 2019    Post subject: re Reply with quote
getting my odo and tacho mixed up, it was my odometer (distance travelled) and speedometer which both went at the same time - have been riding all week with no issue. looks like a big job taking apart the whole front end to get to it so don't know if I will be bothered to be honest for now, although I do want to sell the bike for something more comfy so might have to just get it done
ThunderGuts
PostPosted: 13:46 - 10 Jan 2019    Post subject: Re: re Reply with quote
Is it mechanical? Check the cable - you'll get those symptoms if the cable drops out at either end and I suspect you can access both without taking anything off the bike
TG.
DrDonnyBrago
PostPosted: 14:24 - 10 Jan 2019    Post subject: Re: re Reply with quote
Hi, if you have no power to the speedo unit at all then follow other people's responses.
If it is just the speed reading on the speedometer which isn't showing a speed (and consequently the odo/trip counter don't work as it's not measuring speed/distance) but the rest of the speedo unit is working properly (i.e. you have you have the lights, clock, temp etc showing but no speed reading) then it is likely your speed sensor that is on the blink.
Same thing happened to mine years ago, so I wrote a howto. It is DIYable, simple but fiddly. In my case I replaced it with a used unit from a breaker (was about £30 iirc):
https://cbrforum.com/forum/how-mechanical-40/how-f4i-speed-sensor-swap-110034/
bigdom86
PostPosted: 14:45 - 10 Jan 2019    Post subject: Re: re Reply with quote
Cheers Donny, I found your thread which is the one which I said might take me a while Razz I will give it a go when I can be bothered/when I need to sell which should be in the next couple of months.
as you say everything is working fine, still have power to display and everything else is working fine, just displays 0 for speed and the mileage doesn't move, I still get all the numbers when I switch on ignition and the rpm needle goes up and down
DrDonnyBrago
PostPosted: 14:51 - 10 Jan 2019    Post subject: Re: re Reply with quote
Yeah that sounds very much like the VSS. It's not that bad, just very fiddly.
Some people remove the throttle bodies but it isn't necessary and on a bike of that age you may have issues with the intake rubbers being hard/perished.
The last post was made 7 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.16 - MySQL Queries: 13 - Page Size: 63.57 Kb
