2001 cg125 engine into xl125 1976 frame is it possible
Holadog
PostPosted: 17:23 - 09 Jan 2019    Post subject: 2001 cg125 engine into xl125 1976 frame is it possible Reply with quote
I have an xl125 1976 and wondered if I can fit cg125 2001 engine with electric start in it. Any advice please.
Teflon-Mike
tl;dr
PostPosted: 17:53 - 09 Jan 2019    Post subject: Reply with quote
Why would you want to?
AFAIK most of the small honda's share a common bolt-pattern, derived from the original OHC single used in the, CB/SL 125 single of the early '70's that went on to be evolved into the OHC lump used in the, oooh... XL125, CB100, CB125RS, and many others.
The CB125 'twin' was derived of that motor, and shares frame mounts, as was the push-rod CG engine, retro-engineered for lower maintenance (and performance... sort of an engineering limbo exercise), for developing country markets to compete with the vertially no-maintenance two-smokes.
So, a CG motor 'aught' drop into an early XL frame, bolt-for-bolt, easy as pie.... it's pretty much what Honda did to make the later XR125 road bike....
Problems, might arise around the exhaust and carb/air-box, but most head scratching will likely be found trying to match the electrics.
Old XL125 was 6v points, later model CG's were 12v CDI ignition. Some ingenuity will likely be required to match the wrigglies and make stuff work.
Plenty of bits available on the bay and in the scrap-yards, and plenty of interchangeability, its eminantly do-able... but not necesserily the most easy... and btt... other than CG's and clones being three a penny, why would you want to degrade an EX that probably had around 12bhp, with a motor that at best, likely only makes about 10?.
There's some sense in doing it for an every-day rider, to make it that bit more every-day maintainable with more easily obtained bits.... but as a genuine forty odd year old classic? Turning it into a hybrid would rather throw away much of its classic worth and value, as well as oomph... and 20% on a bike that struggles to NSL is a lot to sacrifice...
But, your call.
Nobby the Bastard
Harley Gaydar
PostPosted: 20:01 - 09 Jan 2019    Post subject: Reply with quote
Ooooh, a good hard teffing as the first reply to your first ever post.
My commiserations. If its any consolation, it was only a quarter of the standard teffing.
Triumph Sprint ST 1050
WD Forte
PostPosted: 01:12 - 10 Jan 2019    Post subject: Reply with quote
Possible?
Yes of course
I'd do it
A good working 2001 CG lump trumps a knackered 1976 XL one
anyday of the week
12 Vs 10bhp?
I doubt you'd know the difference
Classic my arse but there's no reason you couldn't do it in such way as to make the process reversible.
It aint rocket science, pretty straight forward in fact,
the only caveat is the mechanical and electrical skills of the modder.
bikers smell of wee
blurredman
PostPosted: 10:53 - 10 Jan 2019    Post subject: Reply with quote
I had an XL125 from 1978. Which had a same period CG engine put in it. Either that or the electrics were swapped back over for 6v. Anyway.. The only problem was lack of 6th gear that the XL125's have meant it barely topped at 50mph. I didn't think much of it. I presumed someone had blown the original engine up in the past. Which wasn't a surprise given it was such an old '125'. As I could see, the mounting locations were identical.
This is a picture of what I had.
https://cloud.leparking-moto.fr/2018/04/26/02/55/honda-xl-honda-xl-125-s-1983-moto-e-scooter-usato-in-vendita-pesaro-e-urbino_86761663.jpg
bladerunner
PostPosted: 00:28 - 12 Jan 2019    Post subject: Reply with quote
wont notice much difference between 12 and 10hp....you'll bloody well notice a 20% drop in power for sure Laughing but then again I suppose you can drop a 160cc kit and carb on the CG motor and all is good with forward progress again
steve the grease
PostPosted: 03:02 - 14 Jan 2019    Post subject: Reply with quote
The old cb/sl/xl 125 OHC engines used to wear out the cam bearings in the head in no time at all. which is why they are all knackered. like the guy said a good cg beats a knackered XL any day
terrytibbs
PostPosted: 17:57 - 20 Jan 2019    Post subject: Reply with quote
..but as a genuine forty odd year old classic? Turning it into a hybrid would rather throw away much of its classic worth and value,
Do you ever read what you type before posting or are you too busy trying to sound self important? To spell it out for you, if it's a bolt in swap it can be un-bolted can't it
No it doesn't, ever tried It? Rear crank case mounts are wider by a fair margin
The last post was made 7 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 60.08 Kb
