Suzuki Bandit 600
struan80
PostPosted: 19:40 - 10 Jan 2019    Post subject: Suzuki Bandit 600 Reply with quote
Has anyone owned a Suzuki Bandit 600? I'm thinking of getting myself a cheap 400/600 and this seems to fit the bill. I also like the Honda Hornet but they seem a bit pricey'
If you had a grand for a 400/600 what would you go for and why?
Thanks guys.
PostPosted: 19:57 - 10 Jan 2019    Post subject: Reply with quote
Bandits are heavy and underpowered. I'd rather have an SV personally because although you lose 10bhp, you also lose about 30kg which is not to be sniffed at.
Out of the four cylinder 600's from that era, the Hornet is pretty decent value, although it does have quite a short range. Out of the three, the Hornet is the best bike, but the SV can be had for pennies and so is possibly better value.
I used to want a Bandit when I was 18, but nowadays I realise they are big heavy bikes that are under powered, and they do suffer from rust. However, they are the most tuneable of the three by a small margin, and can fit GSXR1100 motors and things. The SV can be bored out safely to about 800cc if you feel inclined, but the suspension and brakes would need upgrading. The SV has the most handling potential IMO, but is hamstrung by cheap damper rod forks.
Kentol750
PostPosted: 21:22 - 10 Jan 2019    Post subject: Reply with quote
+1 for hornet. Sv has much more of a 'sporty' riding position than bandit or hornet.
If I had a grand I would wait until I found the best condition anything rather than pinning my hopes on 1 model.
Some bikes.
redeem ouzzer
PostPosted: 21:49 - 10 Jan 2019    Post subject: Reply with quote
I wouldn’t have an SV for free. Bandit 600 with a 750M or 1100 powerscreen lump shoehorned in. Cheap speed and BHP is always king.
Be a REAL MAN!
PostPosted: 22:00 - 10 Jan 2019    Post subject: Reply with quote
We know your SV proclivities. But they can be sorted cheaper than buying a 750M or 1100 lump. Just need cartridge emulators on the forks, and bob's your uncle. There might even be some decent internals that can be swapped from other bikes. I reckon people in Minitwin racing would know about it...
struan80
PostPosted: 22:07 - 10 Jan 2019    Post subject: Reply with quote
I've spotted an XT660R that's just about in the price range and only 7 miles away. I was never going to keep to my budget, no point trying to kid myself.
https://www.gumtree.com/p/yamaha-motorbikes/yamaha-xt-660r/1325874747?fbclid=IwAR1pkzgcm1nsLQ42XJiGhIcYBvNJ4AEXwkihvwRokAeJsqyGxep1gpkF6CA
M.C
PostPosted: 23:10 - 10 Jan 2019    Post subject: Reply with quote
More fun than a Blandit Smile
Bhud
PostPosted: 23:33 - 10 Jan 2019    Post subject: Re: Suzuki Bandit 600 Reply with quote
I'd stick to the 90s or early 2000s as that's my preference. Just pissing about and not giving definitive answers here, as the only ones I'm sure about are choices 1 and 2, and only for me, not for everyone as general advice...
OK, my first choice would be split between the Yamaha FZR600 or XJ600 (pre-Div).
Why? Because I prefer old bikes, and these two are mechanically simple, genuine performance bikes made to a very high standard of quality. Fun to ride. You can still get a reasonable one (although not a good one) for under a grand if you look hard, and parts are standardised and cheap. Modification is easy but not necessary.
Second choice: XJ600S/N (Div) because I know them well. There are basically 2 versions in the UK: pre-'97 and post-'97. Mechanically simple bikes of adequate power, made to a very high standard of quality. You can get a good, low mileage one in good condition for less than a grand because they were considered undesirable. And the advantage is you can stock up on spare everything (incl. engines) for not much money. Very easily modified (just as well because you'll want to uprate brakes and shocks at the very least).
Third choice: Fazer 600, because these are good quality all-round bikes bought with the brain. You won't get a low-mileage for less than a grand though so maybe I shouldn't have mentioned them.
Fourth choice: Bandit 600 (first version) because in standard form these are ready to roll if you don't want to modify your bike to bring the performance and handling up to par. Like the others, easy to maintain and modify. Moderate build quality and finish by 90s standards. Should be able to get a moderate mileage one in otherwise reasonable cond for just under a grand.
Jewlio Rides Again LLB
PostPosted: 01:52 - 11 Jan 2019    Post subject: Reply with quote
I did have a Mk1 B6, did what I needed it to, was ok. But I've had one, wouldn't have another unless it was cheap or special.
Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems
PostPosted: 09:24 - 11 Jan 2019    Post subject: Reply with quote
Nah I'd rather go SV I reckon.
inline4
PostPosted: 11:56 - 11 Jan 2019    Post subject: Re: Suzuki Bandit 600 Reply with quote
Thanks guys.
I commuted on a Bandit 1250 (not a 600 but I have ridden a 600 many times) all year for a number of years. Bandits are generally very reliable, cheap to maintain, engines are smooth, brakes are crap but can be fixed with EBC pads.
Just like any bike clean it now and then and use ACF50 in the winter and they will be fine.
The only issue I had and this would exist even with a Hornet is that naked bikes are truly hard work in the winter because of lack of wind protection.
The 600 has some top end power that makes it entertaining but the 1250 does not. What the 1250 have is train like torque from pretty much idle which makes it an excellent commuter. Both engines are bullet proof.
If you can get the half faired version of the 600/1200/1250 you should be fine. If I bought one today I would get the fully faired GSX 1250.
PostPosted: 12:08 - 11 Jan 2019    Post subject: Re: Suzuki Bandit 600 Reply with quote
1250 is a different proposition to a traditional oil boiler like a 600 bandit or a 1200 Bandit. The 650 Bandit is also water cooled I think.
inline4
PostPosted: 12:21 - 11 Jan 2019    Post subject: Re: Suzuki Bandit 600 Reply with quote
Yes the 650 was water cooled also so the GSX650F could be an option.
nowhere.elysium
The Pork Lord
PostPosted: 12:24 - 11 Jan 2019    Post subject: Reply with quote
I've owned a Bandit 6 and still own an SV650.
The Bandit 6 is heavy; hilariously so. The suspension and brakes are rudimentary at best. The SV has similar failing with regards to suspension and brakes, abut the chassis is signifcantly lighter and is much more responsive. The bandit engine is a nice lump though: there's a lot that can be done to them without danger of it grenading.
I know that it's traditional to rag on SVs here, but I like mine - with a GSXR shock and properly maintained brakes, it's not a bad bike at all. I still need to put the funds together for a proper suspension upgrade at some point, but in the here and now, it does what I want, and can still be fun.
I don't buy into the whole 'moar BHP' mantra that others do, and am usually quite happy with ~70bhp. I've ridden significatly more powerful bikes, and while the initial 'holy shit' moment of cracking the throttle open is always fun, it generally feels wasted if it's on the road.
Tdibs
PostPosted: 13:37 - 11 Jan 2019    Post subject: Reply with quote
For commuting or just for enjoyment?
I'd be looking at a mk1 bandit 12 rather than the 6. Otherwise SV/Fazer/thundercat/Zx6r.
For a grand though, condition over model 100%. Whatever was in the best nick, with the least amount of work doing for the price.
garth
PostPosted: 14:27 - 11 Jan 2019    Post subject: Reply with quote
I've got an sv you can have for under a grand
Faired one, new fork seals and overhauled brakes, new pads etc, 25k
Got a set of scrubs for it too
Confusion
PostPosted: 14:37 - 11 Jan 2019    Post subject: Re: Suzuki Bandit 600 Reply with quote
05/06 (K5/K6) Bandits had the air/oil cooled engine. Later models
had the new liquid cooled engine.
Bandit 650SA, ZZ-R1100
chickenstrip
PostPosted: 16:11 - 11 Jan 2019    Post subject: Reply with quote
Hey struan80, buy any bike, you can't go wrong - you're coming from a cruiser Thumbs Up Laughing
M.C
PostPosted: 16:42 - 11 Jan 2019    Post subject: Re: Suzuki Bandit 600 Reply with quote
I actually thought the 650 was nicer, the 600 felt like an old bike. Both were ludicrously heavy though, I'd only have one if it was extremely cheap and I was desperate. They're a bit like pulling a fat bird, ideally you'd end up with something else Razz
struan80
PostPosted: 21:35 - 11 Jan 2019    Post subject: Reply with quote
I don't like to hang about so have narrowed it down to two bikes, the XT660R that I posted before and a clean looking BMW F650GS. Going to see both tomorrow and it's most likely that I'll be coming home with one of them. I think I prefer the XT but only if my feet can touch the ground.
https://i794.photobucket.com/albums/yy224/struan80/_86_zps048tewic.jpg
Or
https://i794.photobucket.com/albums/yy224/struan80/58899a0a1ca6462cb6e5170799c98397_zps5ndg6zxw.jpg
PostPosted: 21:44 - 11 Jan 2019    Post subject: Reply with quote
Decisions decisions!!!
Which one are you seeing first?
M.C
PostPosted: 21:46 - 11 Jan 2019    Post subject: Reply with quote
If you get the BMW you can be fwends with Rogerborg Wub
struan80
PostPosted: 22:00 - 11 Jan 2019    Post subject: Reply with quote
I'm going to see the BMW first, it's got a low seat so maybe better for me.
PostPosted: 22:05 - 11 Jan 2019    Post subject: Reply with quote
Ugh, singles. No. Not as an only bike.
rhys99
PostPosted: 22:18 - 11 Jan 2019    Post subject: Reply with quote
There isnt even 10hp in it, i've had two Sv's which have both made 73~whp, friend has a bandit which made 74whp on the same Dyno.
21:16:02 Fin: I got a girl to believe I have a huge dick today, she's going to be so disappointed
K̶5̶ ̶S̶V̶6̶5̶0̶S̶ K3 SV650N
The last post was made 7 years, 213 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 134.43 Kb
