ER5 'laid down' while running = low oil pressure...
andy_uk
PostPosted: 16:17 - 15 Jan 2019    Post subject: ER5 'laid down' while running = low oil pressure... Reply with quote
So... the wife had to lay her bike down earlier due to a pillock going the wrong way down a one way street. (wet leaves on a greasy road etc...)
Minor cosmetic damage (smashed indicator & scratched stator cover).
My main issue is that while she was trapped under the bike, the engine was running for around 30s or so.
It took a while to start it afterwards and both the oil & coolant temp lights were lit. (she can't remember if they were on while the bike was on its side)
I shut it down after a few seconds when I realised they weren't going out.
I then tested the oil pressure switch with a multimeter to see if there was a difference in readings with the engine off and when running.
There was a slight difference so I thought it may be an air lock.
I loosened the oil filter until a bit of oil came out, tightened it back up and ran the engine again. Both lights still on.
Left it for a while and tried again and the lights went off after around 30s.
Would this be enough to damage the engine? (bearing in mind I did blip the throttle to around 4K rpm a couple of times while the lights were on)
PostPosted: 16:24 - 15 Jan 2019    Post subject: Reply with quote
If there is no noise then I'd say it's OK. If the engine ran at idle, and the oil light eventually went out, then what else can you do? Write off the bike on the offchance the engine is damaged? Nah, I'm sure it will be fine. Check the oil level, take it gingerly for a little while and you'll be grand I reckon.
nowhere.elysium
The Pork Lord
PostPosted: 16:46 - 15 Jan 2019    Post subject: Reply with quote
Does the ER5 have a tip-over sensor? If so, then it sounds like it's been triggered.
I'd be tempted to disconnect the battery for a minute or so, and see if that resets it.
If there's oil present, and it's not making hideous noises, then it could just be that for the lack of a specific light to say it's tipped over, then going full retard on the rest of the dash would be a sufficient 'Danger, Will Robinson!' sort of response.
PostPosted: 18:55 - 15 Jan 2019    Post subject: Reply with quote
Did you inspect the pressure switch itself? If the bike went over onto its left hand side, the left exhaust header can be pushed against the pressure switch, thereby activating it. It will eventually garner enough pressure to force it out again and the light will go off.
Had this happen on my KLE500 (same engine), oil pressure light was on at low revs and gradually flickered out but went out when you removed the sump bash guard. It was pushing the header into the switch.
Another one to check is if the wire to the pressure switch has become damaged/pinched and is shorting. Especially if it passes under any bodywork.
As a quick and dirty test, the oil in the sight glass should vanish immediately when you push the starter if it's picking up oil properly.
EDIT: Just noticed the overheat light is also on. If the bike isn't physically so hot you'd burn your hands on the engine, it's a wiring fault.
andy_uk
PostPosted: 19:57 - 15 Jan 2019    Post subject: Reply with quote
Thanks for the replies!
It sounded normal at idle, got a bit noisier when blipping it to 4K (although the engine was cold by then and both our ERs sound like a bag of spanners until they're warmed up!!)
It was due an oil change anyway so I did that while replacing the indicator and straightening out the gear lever. Smile
Nah, it's not that advanced unfortunately.
No, although if the light hadn't gone out then that was next on my list.
Due to being used daily for short runs in the winter the sight glass is never clear at this time of year...too much condensation in the oil Neutral
Weirdly, when the pressure light went out, so did the temp light.
I need to check mine to see if it does the same.
Anyway...after an oil change, she took it for a short ride and it appeared to behave itself.
The last post was made 7 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 49.53 Kb
