Blackbird Waterpump Shenanigan
tokai
PostPosted: 10:01 - 19 Jan 2019    Post subject: Blackbird Waterpump Shenanigan Reply with quote
Hello BCF,
Had some overheating issues with an '04 bird.
Found a clear gel like residue under the rad cap which google says is possibly due to different types of coolant mixing?
Stupidly decided to check water pump for gunk but the topmost bolt was rusted, siezed and snapped off.
Drilled out the remains and inserted a helicoil but when refitting the pump there is now a gap of about 4mm on each bolt between the pump casing and the engine mounting hole.
The pump feels well seated, bolted on hand tight. The driven shaft is inserted all the way into the engine with the small rubber seal tight against it but the gap remains between the engine and the pump.
Would be simple enough to add couple of washers to negate any slack but before bodgery, does anyone know what I'm missing here?
Thanks.
Sister Sledge
PostPosted: 10:04 - 19 Jan 2019    Post subject: Reply with quote
Pics??
Photos help us big style.
CCM 404 DS
bikenut
PostPosted: 11:13 - 19 Jan 2019    Post subject: pump Reply with quote
pictures, also check cmsnl for the exploded views, maybe the drive shaft arrangement is partially "out" of its drive mechanism. Does what ever drives the water pump turn freely now, cos its part way out perhaps??
post a link to cmsnl for your exact bike....
nuts about bikes
tokai
PostPosted: 12:12 - 19 Jan 2019    Post subject: Reply with quote
Pictures will be forthcoming...
https://www.cmsnl.com/honda-cbr1100xx-superblackbird-2004-4-englandasv-mkh_model2078/partslist/E__1001.html
The shaft that drives the waterpump has a notch in the end which slots into the rotating bit in the engine.
It feels like its seated correctly as the fins on the pump don't turn freely once its in, it may be that is only partially seated but then the pump housing is tight up against the engine with the bolts hand tight and the gap on each bolt remains...
Will report back with pics.
jaffa90
PostPosted: 12:57 - 19 Jan 2019    Post subject: Reply with quote
Have you tried again after turning the shaft 180 degrees just in case there might be a lip on the drive end.
tokai
PostPosted: 13:53 - 19 Jan 2019    Post subject: Reply with quote
This is a pic of the pump minus the cover, seated but not bolted in.
You can see the gap between the bolt hole and the pump housing.
The rubber seal is also just visible. To get it to seat i rotated the pump fins until the notch slots into the bit the drives it, then the pump is fully seated in the hole.
It doesn't turn once seated although there is a slight bit of side to side movement it does feel like its seated properly.
2nd pic shows the hole with the square bit that drives the pump.
https://imgur.com/a/MGePcdr
With the upper an lower bolts in, tightened incrementally the gap remains at both bolt holes.
tokai
PostPosted: 14:06 - 19 Jan 2019    Post subject: Reply with quote
Ah.
Just removed the seal around the pump and test fit it. Slots all the way in now, once positioned correctly. No gap bolt holes...
bikenut
PostPosted: 11:38 - 21 Jan 2019    Post subject: pump Reply with quote
visit cmsnl and figure out how the dog inside the engine is driven, by an other dog perhaps.
Perhaps the shaft inside the engine sticking out that drives the water pump is sticking out and not fitted properly, visit cmsnl and post a link to the water pump of your exact bike......
any tell tails marks to suggest the shaft in the engine is sticking out tooooo far?????
cmsnl link
is the water pump dog driven via the oil pump dog??
https://images.cmsnl.com/img/partslists/honda-cbr1100xx-superblackbird-2004-4-englandasv-mkh-oil-pumpoil-pan-oil-filter_bigecatv41e__1200_e60b.gif
part number 3??
if so are the dogs ( flat drive "plate" on oil shaft and its water pump "slot" ) in line??
nuts about bikes
bikenut
PostPosted: 11:37 - 24 Jan 2019    Post subject: pump Reply with quote
see above
nuts about bikes
sickpup
Old Timer
PostPosted: 02:21 - 25 Jan 2019    Post subject: Re: Blackbird Waterpump Shenanigan Reply with quote
This is your probelm. The o ring seal needs to be inside the engine not up against it. Lubricate with a small amount of red rubber grease, make sure the fork is line uo and push hard.
tokai
PostPosted: 09:30 - 25 Jan 2019    Post subject: Reply with quote
Yeh, I was just being a fud.
Test fitting the pump after removing the seal allowed it to slot in all the way home with no gap.
Refitted with a lubed seal and its all good now.
Cheers for the help Thumbs Up
bikenut
PostPosted: 10:59 - 25 Jan 2019    Post subject: pump Reply with quote
Always better to be safe than sorry, remember a picture is worth a 1000000 words.
A picture of the problem usually says it all.
Glad you are all running again.
nuts about bikes
The last post was made 7 years, 259 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 73.25 Kb
