Kawasaki ER6F-burning oil
pky1
PostPosted: 23:41 - 19 Jan 2019    Post subject: Kawasaki ER6F-burning oil Reply with quote
i have a ER6F,
2016 plate
1600 miles on the clock,
all of a sudden it as starting burning oil after a service or leaking some where,i cannot see any oil on the floor or around the filter,
oil was on the 2 marks in the window on your oil indicator,i done 60 miles the day later i checked the oil and it had dropped below the marks by about 4 mm in the window,
3 times i have topped the oil to the marks and it as dropped,
some help would be nice,
many thanks
PostPosted: 00:28 - 20 Jan 2019    Post subject: Reply with quote
Quick sanity check. Check the manual to see if the bike is supposed to be upright or on the sidestand when you check the oil level. If you're topping it up on the sidestand when it's supposed to be level, you're probably overfilling it (assuming sight glass is on the right) and it could well be breathing/burning the excess.
If it's not that and oil isn't dripping out then it's either coming out of the breather or burning it. Check your airbox as most modern bikes would dump breathed out oil in here.
Get someone to follow you and look for blue smoke. Smoke under acceleration suggests worn/broken rings. Smoke on the overrun suggests valve stem oil seals.
pky1
PostPosted: 08:15 - 20 Jan 2019    Post subject: Reply with quote
Thanks bud
i will look at the manual today and check,
i am checking oil when bike is on paddock stands,
i will also check the airbox
jaffa90
PostPosted: 12:05 - 20 Jan 2019    Post subject: Reply with quote
"""all of a sudden it as starting burning oil after a service or leaking some where,"""
Who serviced the bike and which oil has been put in?
pky1
PostPosted: 23:19 - 20 Jan 2019    Post subject: Reply with quote
serviced by Kawasaki main dealer,
oil
Silkolene Super 4 10w-40 semi-synthetic 4-Stroke Motorbike
jaffa90
PostPosted: 23:27 - 20 Jan 2019    Post subject: Reply with quote
The bike has done nowt, tell the dealer about it.
Also does the bike perform ok? (i`m thinking somebody may have
screwed the bollocks off it).
MCN
PostPosted: 23:28 - 20 Jan 2019    Post subject: Reply with quote
Can you remember how to find the dealer?
Take it back there.
Shocked
MCN
PostPosted: 23:30 - 20 Jan 2019    Post subject: Reply with quote
It is not likely that human intput would hurt a new-ish engine.
I used to hammer an ER6F to get it to move.
Ed Case
PostPosted: 00:11 - 21 Jan 2019    Post subject: Reply with quote
Sounds like they over-filled the engine.......not unknown !.
pky1
PostPosted: 07:29 - 21 Jan 2019    Post subject: Reply with quote
going back to main dealing this week,
oil as always been checked when bike is up right,
not been overfilled,
i can't understand why it just started
Robby
Dirty Old Man
PostPosted: 09:56 - 21 Jan 2019    Post subject: Reply with quote
It would be odd for a bike to suddenly start burning oil, and a tiny change in the angle of the bike makes a big change in the oil level in the sight glass.
If it was burning enough oil to get through half a litre in 60 miles, the exhaust would be noticeably smoky. It would mean you're burning about 90% petrol, 10% oil.
sickpup
Old Timer
PostPosted: 11:33 - 21 Jan 2019    Post subject: Reply with quote
If you are checking the level on a paddock stand you probably are over filling it.
pky1
PostPosted: 18:17 - 21 Jan 2019    Post subject: Reply with quote
i should of said
i put the bike on paddock stands front and back
to check the oil
MCN
PostPosted: 20:57 - 21 Jan 2019    Post subject: Reply with quote
Almost all bikes I have used are parked on 'Level' ground on side stand.
Most require the engine to be cold as it also drastically affects the oil level reading.
Some use a sight-glass on the engine case/block.
Some have a line etched on the glass or a reflector with a dot at the back of the glass.
Other systems use a dipstick with marks where normal/safe oil 'range' is indicated. Low-High etc.
Some need the dipstick to be removed, wiped and just sat in the hole Not Screwed back in.
As mentioned the difference in the angle of dangle is very important.
You can find the 'exact' way to check oil and other stuff in the owners handbook.
Or a google search might provide the book too.
sickpup
Old Timer
PostPosted: 03:03 - 25 Jan 2019    Post subject: Reply with quote
ER6''s do tend to use oil. They have a low capacity and run on the hot side.
If it has suddenly started using oil it may not like the particular brand so dicuss it with the shop and try something else.
Also check there is coolant in the bike, if there isn't it will run hot and burn oil.
garth
PostPosted: 13:43 - 25 Jan 2019    Post subject: Reply with quote
Both my Versys' used a drop.
But +1 on the oil brand. Through America, my XT would burn Motul, but I switched to super cheap Walmart stuff and it didn't burn a drop.
MCN
PostPosted: 15:37 - 25 Jan 2019    Post subject: Reply with quote
This is also very true.
My exs Honda diesel car used to gulp engine oil. We were usinv Tesco brand.
I swapped to Mobil 5-30 and oil consumption droped to less than 1/2 what it was before.
Maybe something in the additive package basicaly engine oil is all 'base oil' but the more shit they add the more expensive they make it.
Fuck it. I think the OP has flounced already. Shocked
PostPosted: 17:41 - 25 Jan 2019    Post subject: Reply with quote
Are you sure about that? I really cannot remember any bike I have owned that you check the oil on the side stand.
Wifies ER6 is certainly check while upright.
MCN
PostPosted: 22:01 - 25 Jan 2019    Post subject: Reply with quote
Now I'm not sure. Embarassed
I use the OEM books for this shite.
Same as torque settings and stuff too much stuff to remember and easy to get it wrong. Smile
The last post was made 7 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 102.68 Kb
