| chris-red |
 Posted: 13:17 - 21 Jan 2019 Post subject: Bright ideas welcome, awkward car fix needed |
My Missus' car has had a broken heater for quite a while now. I quickly diagnosed it as a mechanical break between the heater box blend flap and the motor that controls it. The fix is to rip the car apart and repair/replace the heater box, it is the first thing that goes in the car when the car is built. To get the box out, you need to drain the AC, take all the dash and the doors off. People that have done it say it takes days of work. I don't have the time, energy, or skill to do it. Obviously this is too much work to pay a garage to do. Reportedly Fiat have charged £2-3k to fix this issue.
Ben (Binge off of here) came round to service it for her and I asked him to have a look. He poked about and found that you can actually access the broken point (just about!) from the drivers footwell.
https://www.fiatforum.com/attachment.php?attachmentid=196778&d=1547995084
https://www.fiatforum.com/attachment.php?attachmentid=196779&d=1547995102
https://www.fiatforum.com/attachment.php?attachmentid=196780&d=1547995121
The peg in my hand, connects to the control motor. I need away to recreate that peg solidly enough so that the motor will turn it. Access is shit. That metal bar is about 2" away from the pivot and I'm not sure if I can remove it without ripping the car apart.
Just wondering if anyone had any bright ideas. I have a few but nothing I'm that keen on. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
WANTED:- Fujinon (Fuji) M42 (Screw on) lenses, let me know if you have anything. |
| weasley |
 weasley World Chat Champion
 Posted: 13:30 - 21 Jan 2019 Post subject: |
Sugru? ____________________
Yamaha XJ600 | Yamaha YZF600R Thundercat | KTM 990 SMT | BMW F900XR TE |
| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| Polarbear |
 Polarbear Super Spammer
 Posted: 13:33 - 21 Jan 2019 Post subject: |
Just to confirm that is hard plastic not metal of any form?
How tight is the heater flap to move?
It would be a faff but I would make a longer piece like the broken off bit out of metal or a piece of solid plastic. Drill and needle file the flap piece so a hole that fitted then aradite the new piece in.
Put it this way, if that was my wifies car, she would be demanding a fix or nicking mine in this weather.  ____________________ Victory Cross Country American tractor. |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 13:37 - 21 Jan 2019 Post subject: |
1mm pin drill, sink a couple of shallow holes in the part that's still attached, that lines up with holes in the stump that came off. Cut a couple of panel pins down to a suitable length, and use them as dowels in the aforementioned holes, shored up with epoxy.
If you're feeling lucky and there's room, try for 3 or 4 dowels. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Riejufixing |
 Riejufixing World Chat Champion
| chris-red |
 Posted: 15:12 - 21 Jan 2019 Post subject: |
I've used it before it's great but no chance it will do this, nothing to grip on.
| Freddyfruitbat wrote: | Buy wifey a new jumper.
Job jobbed. |
It broke April last year, she's done pretty well.
I bought her one of these...
https://www.amazon.co.uk/Samxu-Defroster-Automobile-Electronic-Windscreen/dp/B07K76R1CC/ref=sr_1_5?ie=UTF8&qid=1548078963&sr=8-5&keywords=car+heater
But it's like an asthmatic breathing on you.
| Polarbear wrote: | Just to confirm that is hard plastic not metal of any form?
Put it this way, if that was my wifies car, she would be demanding a fix or nicking mine in this weather.  |
It's all plastic, a metal x section length would work but would need to be like 8mm any idea where to find something like that? I'm nervous about using any kind of glue incase it jams the flap
The other thing is there isn't much material the other side of the flap.
https://www.fiatforum.com/attachment.php?attachmentid=177378&d=1487183409
https://www.fiatforum.com/attachment.php?attachmentid=177379&d=1487183409
| The Shaggy D.A. wrote: | 1mm pin drill, sink a couple of shallow holes in the part that's still attached, that lines up with holes in the stump that came off. Cut a couple of panel pins down to a suitable length, and use them as dowels in the aforementioned holes, shored up with epoxy.
If you're feeling lucky and there's room, try for 3 or 4 dowels. |
This was my top idea, except I was going to heat the pints to make the holes, again the concern of gluing the box where it moves bothered me. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Polarbear |
 Posted: 15:38 - 21 Jan 2019 Post subject: |
That's a big old lump of plastic flap for a small piece of plastic square to turn.
I take it that's someone's repaired version you have the pictures of?
Edited to add.....
https://www.ebay.co.uk/i/271907570020?chn=ps&var=570743445406
£2.79 for a piece of mild steel 8mm x 8mm x 100mm long.
or
£4.75 for a similar sized piece of aluminium. ____________________ Victory Cross Country American tractor. |
| chris-red |
 Posted: 16:00 - 21 Jan 2019 Post subject: |
| Polarbear wrote: | That's a big old lump of plastic flap for a small piece of plastic square to turn.
Edited to add.....
or
£4.75 for a similar sized piece of aluminium. |
Any tips how to cut it to shape?
That's someone who ripped the car apart, and it is obviously fucking awful design. Useless italian bastards, should stick to pizza. ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Polarbear |
 Posted: 16:43 - 21 Jan 2019 Post subject: |
| chris-red wrote: | | Polarbear wrote: | That's a big old lump of plastic flap for a small piece of plastic square to turn.
Edited to add.....
or
That's someone who ripped the car apart, and it is obviously fucking awful design. Useless italian bastards, should stick to pizza. |
I would quite happily hacksaw and file that. It doesn't have to be ulta accurate or anything. Obviously you need files, hacksaw and an engineers vice to hold it though. ____________________ Victory Cross Country American tractor. |
| Riejufixing |
| MCN |
 MCN Super Spammer
| chris-red |
| grr666 |
 grr666 Super Spammer
| MCN |
 MCN Super Spammer
| FretGrinder |
 FretGrinder World Chat Champion
| MCN |
 MCN Super Spammer
 Posted: 23:58 - 21 Jan 2019 Post subject: |
I think heating plastic is like heating metal.
It was cooked at a precise temperature to get where it is now.
Heating again to reform is a bit of a stab in the dark and you have no idea what properties will be altered in the process.
It maybe it could become very brittle or the compounds can become dissociated.
But sometimes it works.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Robby |
 Robby Dirty Old Man
| steve the grease |
 steve the grease Crazy Courier
| Pete. |
 Pete. Super Spammer
 Posted: 22:34 - 22 Jan 2019 Post subject: |
So that circular disc at the base of the bit that's snapped off is the pivot for the flap? It's outside edge is a 'bearing' so to speak?
I would re-make that broken part in aluminium with a fork at the base, drill a couple of holes into the round disc either side of the flap and glue it in with Araldite 2013. ____________________ a.k.a 'Geri'
| Riejufixing |
| chris-red |
| chris-red |
 Posted: 12:26 - 23 Jan 2019 Post subject: |
It's named after the car in her favourite film as a kid. Freddie as F.R.0.7. It is a god awful animated film with Ben Kingsley and Brian Blessed, I think it actually holds the record for being the least successfully animated film of all time.
There is also a musical number in it with roller skating SS officers and KKK members.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| chris-red |
| sickpup |
 sickpup Old Timer
 Posted: 02:47 - 25 Jan 2019 Post subject: |
The last post was made 7 years, 266 days ago. Instead of replying here, would creating a new thread be more useful? |
