Perennial problem dismantling forks for oil seal change
PostPosted: 23:45 - 21 Jan 2019    Post subject: Perennial problem dismantling forks for oil seal change Reply with quote
I keep having a problem with dismantling forks to change the oil seals.
I take the bottom bolt out, remove the damper rod, dust seals out, circlip out. I heat round the seal area with a heat gun then slide-hammer the uppers and lowers apart.
About half the time, they come apart second or third knock. The other half of the time, I spend the next three hours sweating, swearing, heating, clamping in a vice, hammering then eventually destructively removing the seal and going back online to order a new set of bushes because the inner and outer have overridden one another. Usually damaging the fork lower in the process.
What am I doing wrong? Or does everyone else have this problem too?
https://lh3.googleusercontent.com/7X2VC3_XJnV1r_OCuk6h-N-QfOSzIM1at24TNQsZojBM_k-ot5tw-KCsrxapUIMk_F7GU-AtiC6SKzgW46a4mV2PmmvpL4cx9YjDb6qW76ukPNckckymdgUX0IYiDsXmiV8l_uS7sQ=w1164-h873-no
Riejufixing
PostPosted: 00:00 - 22 Jan 2019    Post subject: Reply with quote
I am having difficulty imagining how/where you position a slide hammer.
Kawasaki Jimbo
PostPosted: 00:25 - 22 Jan 2019    Post subject: Reply with quote
Vigorously sliding the inner and outer tubes apart to drive the seal out and separate the two.
Are you missing a washer between the seal and the upper bush?
Riejufixing
PostPosted: 00:37 - 22 Jan 2019    Post subject: Reply with quote
OK so not actually using a tool. By the sound of the post, it's happening on multiple different sets of forks. I wonder whether it's down to wear on the thing the bush bears on, or whether it's a particular make. Sounds a bit doubtful, but.
Robby
Dirty Old Man
PostPosted: 10:15 - 22 Jan 2019    Post subject: Reply with quote
If it is happening on the same set of forks, then I would be looking at the area where the top bush seats. Something is stopping it from sliding out with moderate force. May be that you need to give the bush seat a rub with some fine emery paper.
Or you could just be hammering it too hard. You're meant to be gently tapping a soft bush using another soft bush. Hit it too hard and they will just jam together.
I have had a similar problem in the past, dismantling forks that have been together for 20 years. Usually it's a problem where the old seal is welded in place by a combination of rust, alloy corrosion, and very hard old rubber. Penetrating oil, tea, and patience help.
Fork seals are one of those jobs that can be a pain in the arse, no matter how experienced you are. So many little things can just be difficult for no good reason.
PostPosted: 10:34 - 22 Jan 2019    Post subject: Reply with quote
No, that was in place.
Maybe I'm just hitting it too hard. This particular one was from a CBR600 with 7,000miles on. Very clean but never turned a wheel for the last 16 years. I was changing the seals because they are pretty much garaunteed to start leaking after a few hundred miles.
Maybe just age, there was virtually no corrosion on it.
When I fit new seals, I put red rubber grease on them.
PostPosted: 10:38 - 22 Jan 2019    Post subject: Reply with quote
Having done four or five sets of forks in my time, I think it's just a PITA to be honest.
Islander
PostPosted: 11:11 - 22 Jan 2019    Post subject: Reply with quote
This is why I prefer to change the bushes at the same time as the seals. I'd suggest trying a progressive increase in force rather than getting stuck straight in - it'll at least let you know whether there's going to be a problem with the bushes. Then you can remove the seal with a suitable puller and visually inspect before you get them really stuck.
Meatybeaty
PostPosted: 12:45 - 22 Jan 2019    Post subject: Reply with quote
I've used one of these with varying degrees of success.
https://www.ebay.co.uk/itm/O-RING-SEAL-PULLER-OIL-GREASE-SEAL-HOOK-REMOVER-REMOVAL-TOOL-282610-SILVERLINE/391840051842?epid=19017007796&hash=item5b3b7cb282:g:pDkAAOSwOWdcF~Au:rk:13:pf:0
bikenut
PostPosted: 13:16 - 22 Jan 2019    Post subject: forks Reply with quote
post a link off your exact bike to cmsnl so we can see the exploded views.....
nuts about bikes
PostPosted: 16:35 - 22 Jan 2019    Post subject: Re: forks Reply with quote
It's a CBR600F4 (2000). Standard, right-way up, modern Japanese cartridge forks.
https://www.cmsnl.com/honda-cbr600f-hurricane-2000-y-england_model2383/partslist/F__0800.html#.XEc38oCnxBw
I definately haven't forgetten to remove anything because theydid come apart eventually, as you can see from the picture above.
I suppose the main thing is that any book or how-to you read/watch kind of implies slide-hammering them apart is a straightforward step, when that seems to be far from the case. Yet people make a huge fuss of removing the bottom bolt, something I find entirely straightforward as long as you remember to do it first.
From here and asking some other folks. It doesn't look like my experience is unusual.
I bet the other one flies apart first go...
The hook tool looks... err interesting. I used a small screwdriver. How does the hook work, do you just stab the hook through and lever it up?
Meatybeaty
PostPosted: 16:48 - 22 Jan 2019    Post subject: Re: forks Reply with quote
Sideways on ,hammer it into the plastic trying not to go right through, protect Stanchions with plastic card and the same for the lip of the sleeve and lever out
DrSnoosnoo
PostPosted: 17:09 - 22 Jan 2019    Post subject: Reply with quote
Just to add another bit of personal experience.
Only done it once, on a ZZR600 at about 40k miles IIRC, my mate grabbed the lower, I grabbed the upper, we pulled, leg came apart.
PostPosted: 18:11 - 22 Jan 2019    Post subject: Re: Perennial problem dismantling forks for oil seal change Reply with quote
I've never heated them and never had that problem.
Whether there's any connection is another matter.
Riejufixing
PostPosted: 19:30 - 22 Jan 2019    Post subject: Reply with quote
Could it be something to do with the angle?
Do you always do them standing up, or do you lie them down first?
Pigeon
PostPosted: 23:09 - 22 Jan 2019    Post subject: Re: Perennial problem dismantling forks for oil seal change Reply with quote
Only done a couple RWU forks. Never heated them either. Just 4-5 sharp tugs.....gigiddy.
Kentol750
PostPosted: 23:19 - 22 Jan 2019    Post subject: Reply with quote
Might have missed it earlier, but why is it a regular problem? 2nd time would've seen me get new forks. Pitted or warped forks? Or just lots of bikes you hit potholes on?
Some bikes.
Riejufixing
PostPosted: 00:39 - 23 Jan 2019    Post subject: Reply with quote
I have the impression he "does forks" and other work for ppl, although ICBW of course.
bikenut
PostPosted: 10:53 - 23 Jan 2019    Post subject: forks Reply with quote
Hi stinkwheel, thanks for posting the exploded view......
If the drain plug part number 20 ( yes it also has an other function as well ) was removed whilst the fork stanchion was still in the bike, and the circlip part number 12 and its associated upper "seal" removed then the lower fork leg could be removed via its own effective "slide hammer" and weight, once the mudguard etc is off ??
The other parts could then be removed for bench working?
nuts about bikes
PostPosted: 12:33 - 23 Jan 2019    Post subject: Reply with quote
I've never had an issue, I actually quite like doing forks, only problems I find is the mess and until I got an electric impact driver getting the lower bolt out.
sickpup
Old Timer
PostPosted: 14:54 - 23 Jan 2019    Post subject: Reply with quote
Its a normal problem and one exacerbated by not changing the bushes with the seals and cleaning out the fork leg when seals are changed.
Wear on the bushes means the bottom bush will ride up inside the upper bush expanding it and jamming it into place.
Theres a surprising amount of wear that goes on inside a fork leg. When you have less than 500ml of oil in a closed system any particulate matter will cause excess wear.
PostPosted: 16:37 - 23 Jan 2019    Post subject: Reply with quote
Perrennial as in it seems to happen every time this job comes up rather than as a job I'm doing on a particularly regular basis (although this is the second set I've done this year). These are all different bikes. Both mine and the wifes. I generally fit the new seals using red rubber grease on the seats to help with the fitting and prevent corrosion.
Just got mrs stinkwheel a CBR600 which has sat for a long time unused so I was changing the seals pre-emptively. It's only done 7k miles from new so shouldn't have much appreciable wear on the bushes. Last time was her CB500 which had started to leak from one of the forks, one fork seal jammed solid and trashed the bushes getting it out, the other popped apart second pull.
PostPosted: 16:42 - 23 Jan 2019    Post subject: Re: forks Reply with quote
That's how you do it on an old Brit bike with fork shrouds but in this instance, it would probably have been a really good way of knocking the bike over. The old brits often don't have bushings (like my bullet has no bushes but two oil seals per leg spaced about an inch apart)
The problem is with that "Slide hammer" action, it doesn't always deliver. In my experience, about half the time the fork comes apart, the other half of the time the bushings start overiding one another and you're in it for the long-haul. Even with the fork on the bench and the lower clamped in a padded vice.
sickpup
Old Timer
PostPosted: 17:11 - 23 Jan 2019    Post subject: Reply with quote
Why do you think 7000miles couldn't cause much wear?
Try changing the fluid in a set of forks, riding the bike for 5000miles and then change the fluid and see what comes out. The sparkling particles may well change your mind.
The bushes are a sacrificial part that is meant to wear which they do. All the worn off particles are held in the oil causing more wear.
PostPosted: 22:44 - 23 Jan 2019    Post subject: Reply with quote
Well, in this case, the fluid that came out was clear and colourless. So it was either changed just before it was parked up 13 years ago or it's in hell of a good nick. I'm sure nobody has had the fork tops off recently.
Anyway, as predicted, the second one came out with minimal fuss Rolling Eyes. So my 50:50 record is intact. I did heat them in the end, they didn't look like they were going to move cold, took three bashes after warming up. Although perhaps soaking them in ATF/Acetone mix loosened things up (it certainly loosened the paint I got a drip on!).
Got the new bushes and seals ready to fit and a bottle of multigrade fork oil but I'm going to give the sliders a coat of polyurethane laquer before I refit them to prevent stone chips.
The last post was made 7 years, 256 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.17 - MySQL Queries: 13 - Page Size: 132.45 Kb
