Rough / uneven surfaces
ThunderGuts
PostPosted: 09:40 - 24 Jan 2019    Post subject: Rough / uneven surfaces Reply with quote
I think this is probably the best place to put this query; so around here a lot of the roads are "well used" shall we say. Some have had a surface dressing treatment which has since started to flake off, resulting in high/low points. There's also the breaking up roads etc.
My question is how well does a bike deal with these sorts of surfaces when cornering; I am building confidence in corners on good surfaces, irrespective or wet or dry, but I'm still extremely wary of rough/poor surfaces and end up probably being over-cautious. I think this stems from car driving where you can quite easily feel the tyres scrabbling for grip and/or vagueness in the steering on such surfaces.
Just to clarify, I'm talking about poor but NOT loose surfaces.
Just wondering what are people's experiences? Am I over-thinking it and does a bike actually deal with such surfaces well, or am I right to be very cautious?
The bike is my ER5 on good, new rubber.
Cheers Thumbs Up
TG.
chickenstrip
PostPosted: 09:53 - 24 Jan 2019    Post subject: Reply with quote
Remain wary of poor/rough surfaces. Experience will tell you what you can and can't get away with. No miracle answers I'm afraid. Unless you want to get a dirt bike.
Hawkeye1250FA
PostPosted: 09:54 - 24 Jan 2019    Post subject: Reply with quote
Being over cautious can actually cause issues in those situations.
The bike will be fine on poor quality road surfaces (not loose chippings). Be confident but not cocky. The tyres and suspension will handle it.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
ThunderGuts
PostPosted: 09:59 - 24 Jan 2019    Post subject: Reply with quote
Thanks both. Yes that was kind of my thinking. Cheers Thumbs Up
TG.
thx1138
PostPosted: 11:38 - 24 Jan 2019    Post subject: Reply with quote
erm. I trying to think of any good road surfaces round here.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:39 - 24 Jan 2019    Post subject: Reply with quote
Shift your braking bias much more to the rear.
How the fuck you do this with linked non abs brakes is a question for the legislators.....
Triumph Sprint ST 1050
PostPosted: 19:20 - 24 Jan 2019    Post subject: Reply with quote
Look where you want to go, not at what you want to avoid. Visualise a line through the corner on the "cleanest" looking bit of road, and imagine the front tyre running along it. If you stare in horror at the bad bit, you WILL ride directly over it.
Try to avoid changing from one road surface to another mid corner because the overbanding between them can be slippery.
Corner on neutral power or under power, never while decellerating. COrnering under power will help prevent the front end washing out (the rear can but that's an order of magnitude more controllable)
M.C
PostPosted: 20:50 - 24 Jan 2019    Post subject: Re: Rough / uneven surfaces Reply with quote
It's better to be overcautious on a bike, as you normally end up sliding down the road on your backside if you get it wrong.
The last post was made 7 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 57.59 Kb
