| Travis Bickle |
 Travis Bickle Banned
 Posted: 20:11 - 25 Jan 2019 Post subject: What chain to go for |
I'm in the middle of changing my rear sprocket from a 45t to a 49t and have discovered I need a new chain to complete the process (shock horror!).
I'm guessing going from 118 links to 120 would be sufficient?
I don't mind spending a bit of money to get the best chain for the job even if it's overkill. I think the general rule of thumb is cheap chain for 125cc and under and it's got to be a O ring chain for anything over that right? Mine is 125 but I don't mind spending a bit more on an O ring chain even if it's not necessary. Also I believe they're lower maintenance?
I've narrowed my options down to either:
1) A fairly standard O ring chain from Tsubaki for £62.11
2) A NON O ring chain (also from Tsubaki) but apparently it's a heavy duty motocross chain for offroad applications. I'm wondering if this would be the better option if I get lazy with maintenance as it's HARDER wearing or whether the O ring one would be better as it's LOWER WEARING (if that makes sense, and I think I've understood the differences correctly). £41.40
The write up that was given for the motocross one is: This high quality NON O-ring chain has been manufactured for professional motorcycle mainly motocross / off road applications. The MX Pro features eliminated kinking and seizure in abrasive and muddy conditions through special treated pins and projected - shouldered bushings. Critical components are heat treated and shot peened for greater durability. The MX Pro distinguishes itself by its gold coloured link plates.
Specific for off-road bikes
Non 'O' ring chain
Suitable for bikes up to 450cc
Heat treated & shot peened
Gold coloured link plates
DID would be my preferred brand but it doesn't look like they do any heavy duty or O ring ones in the size I need.
I'm guessing the motocross one, if lazy and not maintained, would probably wear the sprockets more whereas as the O ring would would actually require less maintenance anyway it wouldn't wear the sprockets as much if left alone?
Not planning on neglecting my chain just looking for the best option possible.
Thoughts anyone please? ____________________
Must Go Faster
1999 Yamaha FZS600 Fazer |
| Skudd |
 Skudd Super Spammer
| Travis Bickle |
 Posted: 20:44 - 25 Jan 2019 Post subject: |
Thanks. What's the difference / which is best? ____________________
Must Go Faster
| Skudd |
 Skudd Super Spammer
| MCN |
 MCN Super Spammer
 Posted: 21:59 - 25 Jan 2019 Post subject: |
o-ring chains on bikes with open chain.
Non-o-ring chains 'should' have a cover over them.
O-ring chains do not need a cover as they are more resistant to shite getting into their 'workings'.
125 split link would work but I prefer the feeling of security of a riveted pin masel.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| P.addy |
 P.addy Red Rocket
| Ste |
 Ste Not Work Safe
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| bikenut |
 bikenut World Chat Champion
| G |
 G The Voice of Reason
| Travis Bickle |
 Posted: 13:59 - 26 Jan 2019 Post subject: |
| MCN wrote: | o-ring chains on bikes with open chain.
125 split link would work but I prefer the feeling of security of a riveted pin masel.  |
Thank you. I think all the ones I was looking at were riveted anyway but you're saying as a general rule you should avoid split link chains and riveted ones are superior?
| Paddy. wrote: | On what bike... because that is a fairly sizable change.
Edit - YBR125.... I wouldn't go 'up' on the rear of a YBR. you are going to starve the shit out of it and its top speed is going to plummet. |
That's what I thought might happen when I dropped a tooth on the front sprocket and went from 14t/45t to 13t/45t (an 8% reduction in final drive ratio) but I was prepared to give it a try anyway. However the end result was a noticeable increase in acceleration with absolutely no reduction in top speed whatsoever. The reason for this - probably due to my weight! The YBR allegedly has a top speed of 70mph but I've never managed to get it above 56mph on a flat, therefore never getting anywhere near the red line in top gear. After changing the front sprocket it's got a bit closer to the red line in top gear but still a fair way off. With the original drive ratio the engine simply isn't powerful enough to get it up to 70mph on the red line in top gear with my lardy 20 stone arse sat on it. I know going up 4 teeth on the rear sounds like a massive jump but it only works out about the same as going down 1 tooth on the front. Going from 13t/45t to 13t/49t decreases the final drive ratio a further 9% so looking at a total of 17% drive ratio reduction from the original setup.
I'm very happy with the results of going from 14t to 13t on the front so am hoping for similar results on the back, but yeah I do agree the two combined might just be a bit too much overkill but I'm happy to give it a try.
If things don't work out I can always swap it back or try something in-between 45 and 49. It's trial and error. I'm well up for all that. But even if I do get a top speed reduction that's not necessarily the end of the world, considering it struggles to maintain 50mph currently it's not exactly at home on high speed A roads. That extra acceleration will come more in handy round town where the YBR is best suited.
| Ste wrote: | The fairly standard O ring chain from Tsubaki for £62.11 is what you want.
Reason for wanting +4 on the rear sprocket? |
Thank you that's what I suspected and you and MCN have kindly confirmed that for me.
| bikenut wrote: | If its under a 250 ( so not that powerful then eh !!!! bike dependant ) wemoto do a swallow chain non o ring which are quite good, also they do good sprockets as well.
How wealthy are you ? |
Wealth doesn't come into it. My spending habits are mainly driven by stupidity and impulse. ____________________
Must Go Faster
| MarJay |
 MarJay But it's British!
| Travis Bickle |
 Posted: 14:19 - 26 Jan 2019 Post subject: |
| G |
| Travis Bickle |
 Posted: 14:57 - 26 Jan 2019 Post subject: |
Reduction would be 0.83 not 0.87 so new theoretical top speed of 58.1mph but yeah I agree with your maths! Thanks I hadn't considered working it out that way ____________________
Must Go Faster
| garth |
 garth World Chat Champion
| Travis Bickle |
 Posted: 17:21 - 26 Jan 2019 Post subject: |
Yeah but DID don't do an O ring chain in the size I need (428 120). ____________________
Must Go Faster
| jaffa90 |
 jaffa90 World Chat Champion
| Travis Bickle |
 Posted: 17:23 - 26 Jan 2019 Post subject: |
Hang on that's complete crap! I've been looking on the sportsbikeshop website and couldn't find any, however a search on eBay has produced both O and X ring chains from DID in the size I need. ____________________
Must Go Faster
| garth |
 Posted: 23:01 - 26 Jan 2019 Post subject: |
| jaffa90 wrote: | | garth wrote: | Get a DID chain, don't fuck about.
My last DID o ring coupled with an oiler needed adjusting twice in three and a half months, or 13,000 miles, and half of that was off-road, loaded with camping gear.
It wore out a front sprocket before it needed adjusting. |
Wow, that`s about 40,000 a year, also what bike and tyre lasted at least 13,000 miles ?????????????? |
4PT XT600E, mefo explorer lasted 8.5k, changed to a kenda after that I think. ____________________ You ain't a has been if you never was |
| G |
| Travis Bickle |
 Posted: 18:06 - 27 Jan 2019 Post subject: |
I'd kinda been working it out the same way as you but back to front:
(14/45)/(13/49)=1.172649573 which is equally as valid a way to work it out... unfortunately the next step I took was to just subtract 0.172649573 from 1 which gave me 0.827350427 but that makes no sense. Should have divided 1 by 1.172649573 which would have given me 0.852769679 and we'd have been in agreement! LOL
So yeah, basically the new theoretical top speed after -1t on the front and +4t on the rear would be 60mph which is still more than I'm achieving at the moment anyway so I'm hoping it will give no reduction in top speed (maybe a slight increase) as well as vastly improved acceleration. ____________________
Must Go Faster
| bladerunner |
 bladerunner World Chat Champion
| Travis Bickle |
 Posted: 00:50 - 28 Jan 2019 Post subject: |
Oh really?! Ok that's interesting I hadn't considered that. Thank you. Didn't realise the O ring ones were heavier. ____________________
Must Go Faster
| Sister Sledge |
 Sister Sledge World Chat Champion
The last post was made 7 years, 238 days ago. Instead of replying here, would creating a new thread be more useful? |
