Heads up - Aldi compressor on sale again
Freddyfruitba...
PostPosted: 17:53 - 29 Jan 2019    Post subject: Heads up - Aldi compressor on sale again Reply with quote
in case anyone's interested (available online only):
https://www.aldi.co.uk/workzone-2-5-hp-air-compressor/p/085433223920500
M.C
PostPosted: 18:11 - 29 Jan 2019    Post subject: Reply with quote
Want even though I have absolutely no use for it.
R1stu
Shrek!
PostPosted: 18:26 - 29 Jan 2019    Post subject: Reply with quote
Tempted. but I had a 24l tank one before and it wouldn't run my impact wrench so not sure...
Been told need at least a 50l tank for air tools, however, old comp was very old, and tank did leak a bit so was almost always on when in use.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Rob Fzs
PostPosted: 18:27 - 29 Jan 2019    Post subject: Reply with quote
50L is the min you want to run a impact gun and even then its pretty soft
'00 Aprilia RS50 > '92 Honda CG > '99 Yamaha Fazer > '91 Yamaha RXS > '79 Suzuki X5 > 01' Honda Cg > 07' Honda Cg > 82' Kawasaki Z200 > suzuki gsxr 400 gk73a > honda vfr 400 NC30> Yamaha RD350 YPVS F2 > Kawasaki ZZR 600 D1 > Yamaha TZR 250 2MA >Suzuki TL1000R > Yamaha TDR250 > Honda 929 blade > Suzuki SV1000 > Honda H100
Mod 2 Passed 09/06/2011
DRZ4Hunned
PostPosted: 21:10 - 29 Jan 2019    Post subject: Reply with quote
Out of curiosity what jobs could this be used for?
DRZ400-SM
FZS600
Dave....
PostPosted: 21:48 - 29 Jan 2019    Post subject: Reply with quote
Blow? Rolling Eyes
Seriously, tyre inflation, drying off water out bike, cleaning shit out of hard to access areas etc.
Honda Africa Twin
PostPosted: 22:57 - 29 Jan 2019    Post subject: Reply with quote
I have one. It's usable for tools but not so good with the small bore lines it comes with.
I've changed my fittings out and use 1/2" bore airlines but if I needed it every day I'd change if for a bigger unit.
Saying that, most power tools I use everyday are battery so for the odd time I need an air supply it's fine.
Triumph Trophy Launch Edition
NooBish-AbbZ
PostPosted: 00:45 - 30 Jan 2019    Post subject: Reply with quote
Not interested in this but it's reminded me of the thermal base layers that they did a few years ago. Does anyone know when they're due out again? I bought one set literally 3/4 years ago and they're fucking brilliant.
SV650S - Feb '14-March '19
XJ6N- Apr '19 -Present
Suntan Sid
PostPosted: 00:53 - 30 Jan 2019    Post subject: Reply with quote
I got given one of those compressors last year.
It came with some brand new unopened spray painting kit, is it up to spray painting?
NJD
PostPosted: 00:55 - 30 Jan 2019    Post subject: Reply with quote
Sportsdirect Campri brand: 2 for £11-13 most of the time, but looks like the website is selling them off.
As in you have to buy 2 x tops for £12 or 2 x trousers for £12 (prices vary), and you can't buy a top and bottom for £12.
ThunderGuts
PostPosted: 11:22 - 30 Jan 2019    Post subject: Reply with quote
I rang Aldi the other week asking when they're next having a motorcycle specialbuy; they wouldn't (or couldn't) tell me exactly, but they did say all specialbuys work on either a 3, 6 or 12 month cycle and looking at the history, it's usually Feb or March, so I'd guess sometime in the next few months we'll see another Aldi motorcycle specialbuy.
TG.
Freddyfruitba...
PostPosted: 12:08 - 30 Jan 2019    Post subject: Reply with quote
Presumably merino wool?
Worth pointing out that Aldi flog this stuff at different times of the year under other guises too; eg for 'cycling' or 'skiing'. I have one of their merino 'golfing' tops - never played in my life but it's great for the motorbike.
tony_d123
PostPosted: 21:47 - 30 Jan 2019    Post subject: Reply with quote
It's the other way round, the XF/Euro fittings have a larger internal diameter and are a higher flow rated fitting. I've recently swapped all my old UK long style PCL fittings for XF.
It is probably the hoses and cheap fittings that are the weak link on the Aldi stuff.
Blackpool, Lancashire
tony_d123
PostPosted: 21:53 - 30 Jan 2019    Post subject: Reply with quote
p.s. both types are ¼" BSP threads, so interchangeable.
johnsmith222
PostPosted: 00:04 - 31 Jan 2019    Post subject: Reply with quote
Main thing I use my similar sized stanley one for is car and bike tyre fitting. Also use it when doing the tyre pressures on multiple cars and bike at the same time. I've got a 20 metre rubber hose so use that.
It's also been good to get a feel for owning and maintaining a compressor and getting an idea of what I might want from a larger higher end one. Mine is a second hand shitter but still look after it with changing the oil, making sure to drain the tank, replaced fittings, repaired a gauge etc.
If it's anything like mine though, you'll probably want to use hearing protection. Belt driven ones are much quieter. I got these and while pricy it's likely one of the best things I've purchased and should have bought earlier.
https://www.amazon.co.uk/PELTOR-X5A-Defenders-Headband-Black/dp/B00BBCTQK6?ref_=fsclp_pl_dp_3
Jmoan
PostPosted: 17:10 - 31 Jan 2019    Post subject: Reply with quote
Are there any soft covers for reducing the volume of these things?
Coincidentally Aldi had hearing protectors like that once or twice.
tony_d123
PostPosted: 01:16 - 05 Feb 2019    Post subject: Reply with quote
mpd72 CPT wrote:
Not sure you understand what I meant. I upgraded the fixings and hoses from the supplied to a wider bore, which was just the standard available 1/4 BSP thread stuff from Toolstation and Screwfix.
I understand, but You said the Euro fittings are narrower. The bore of the Euro fittings are noticebly bigger, hence why they are also called Hi Flow fittings.
It is not that important unless you are using some seriously powerful tools. As mentioned previously, it is probably the puny hose that is the restriction on the cheap Aldi stuff.
tony_d123
PostPosted: 01:43 - 05 Feb 2019    Post subject: Reply with quote
For German read Euro
https://www.iedepot.ie/blog/different-air-fittings-explained/
yen_powell
PostPosted: 09:09 - 05 Feb 2019    Post subject: Reply with quote
Aldi are doing WD40 chain cleaner, spray and wax on the 7th Feb.
https://www.aldi.co.uk/wd40-motorbike-chain-cleaner/p/008339252545000
https://www.aldi.co.uk/wd40-motorbike-chain-lube/p/008339266694801
https://www.aldi.co.uk/wd40-motorbike-chain-wax/p/008339266695002
XT1200Z and a DR350 in bits
ThunderGuts
PostPosted: 17:07 - 05 Feb 2019    Post subject: Reply with quote
yen_powell wrote:
Is the cleaner any good? Might be tempted by some to flush out the paraffin after a clean to help dry off the chain. Thumbs Up
TG.
kramdra
PostPosted: 17:20 - 05 Feb 2019    Post subject: Reply with quote
Its an ok price but it will be almost identical to the other brands, which with basic tools are usually sub-100. This has none, so add 15 quid.
My only use is for occasional motorbike tires, I should have got the smaller 6L or vertical one from ebay.
Cordless lipo is much better for actual tools.
The last post was made 7 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 131.5 Kb
