Car question- removing locking wheel nuts
colin1
Captain Safety
PostPosted: 10:44 - 30 Jan 2019    Post subject: Car question- removing locking wheel nuts Reply with quote
I've bought a Vauxhall Meriva B which has locking wheel nuts but not the thing to remove them.
I understand as it's a bit like a key so buying another set wont give me the right key to remove them.
I've seen a thing on ebay which is supposed to be able to remove them.
Has anyone done this ? Should I just take them to a garage or tyre place that may already have the tool ?
PostPosted: 11:20 - 30 Jan 2019    Post subject: Reply with quote
Bought these myself to get locking wheel nuts off my eldest daughters Citroen. They worked OK. Just make sure they are the right size for your car.
https://www.amazon.co.uk/Voche-Socket-removal-Locking-Damaged/dp/B01LAYUNS8/ref=sr_1_2_sspa?ie=UTF8&qid=1548843194&sr=8-2-spons&keywords=locking+wheel+nut+remover&psc=1
I hammered them on and then used an impact driver to loosen the nuts. I found a power bar just started to chew them up.
Saying that, I took another car to a Formula 1 autocentre with 4 spare wheel nuts and they removed them when changing tyres and didn't charge me. I am a regular customer there mind.
grr666
PostPosted: 11:22 - 30 Jan 2019    Post subject: Reply with quote
I'd go to Vauxhall and just order one tbh, not like you're not going to need it again. Maybe £20 if that. If there are
different patterns, they will know which you need. Certainly wouldn't trash the nuts to save a few quid.
https://www.ebay.co.uk/itm/VAUXHALL-MERIVA-LOCKING-WHEEL-NUT-KEY-ALL-AVAILABLE-GENUINE-GM-FAST-DELIVERY-/361391076957
MCN
PostPosted: 13:22 - 30 Jan 2019    Post subject: Reply with quote
Begs the question, Why fit locks? Shocked
Smile
piazza
PostPosted: 14:16 - 30 Jan 2019    Post subject: Reply with quote
First thing I do now is take them off and bin them...after you make sure the key is there when you buy it.
Then 6 months later when you go for a puncture repair there's a locker on it Shocked The tyre guys had it off in minutes.
Monkeywrenche...
PostPosted: 14:40 - 30 Jan 2019    Post subject: Reply with quote
If they have a rotating collar on them (pretty sure vauxhall ones will) then the tool in Pbs post probably won't work, as for ordering a new one you'll need the key code...which is in the box you probably don't have . I have tools for removing the collared nuts but it's a fairly expensive tool, as are sets which include all the permutations. if you only need to remove a single set you're better off getting a new key made here...
https://www.lockingwheelnutkeys.co.uk/
Used them before, new keys from nut manufacturer just by sending a pic of the nut, and pucs of ID/V5
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
bugeye_bob
PostPosted: 14:44 - 30 Jan 2019    Post subject: Reply with quote
only downside to VX is you will need the security card, if you dont have this they used to charge you to get this, which had the key no for your car, then they charged you for the correct key.
Monkeywrenche...
PostPosted: 14:46 - 30 Jan 2019    Post subject: Reply with quote
No wheel nut numbers on that card, it's on seperate card in the plastic box the nuts and key are in. if you don't have that the information is not recorded anywhere else.
ride_to_die
PostPosted: 14:56 - 30 Jan 2019    Post subject: Reply with quote
Most tyre places will take them off for about £10 per wheel around Leicester way. A friend who had the same problem with his Honda, went to the dealers. They had 10 different keys in stock, tried a few until one worked. About £16 thinking back.
I'm not here for a long time, I'm here for a good time.
grr666
PostPosted: 15:19 - 30 Jan 2019    Post subject: Reply with quote
£10 per wheel for a 1 time removal charge or £21.50 for the proper OEM key usable forever for an additional £0.00 per use?
Okay, someone will have to explain the economics of that to me.
As for key cards... Quote as per my link.
Brand New - Replacement locking wheel nut key.
We have access to replacement locking wheel nut keys for all numbers within the range of 100-200.
Please put a note on your order telling us which number you require. This information can be found on the security card that was supplied with the locking bolt set originally.
If you do not have the key number, don't worry we can identify which key it is by simply mailing us a good quality photo of the locking bolt .
These keys are made from Hardened Steel, and are Thatcham approved.
Monkeywrenche...
PostPosted: 15:27 - 30 Jan 2019    Post subject: Reply with quote
Vauxhall has 67 keys, , but the chances of them stocking all 67 possibilities is slim to say the least, that a main dealer parts department would bring them all out and open the bags and try every one is probably less.
Monkeywrenche...
PostPosted: 15:29 - 30 Jan 2019    Post subject: Reply with quote
It's a good price, I've bookmarked that link. the guys I've linked charge 35.99 unless you want it quick.
PostPosted: 17:24 - 30 Jan 2019    Post subject: Reply with quote
Does anyone think it's even worth bothering with locking wheel nuts any more?
I haven't heard of wheels getting nicked for years. I don't live in Liverpool though. Wink
Monkeywrenche...
PostPosted: 17:30 - 30 Jan 2019    Post subject: Reply with quote
Back in the late 90's when nearly all cars came with steels it was rife, now everything has nice wheels out of the factory it's tailed right off. When I worked at renault in MK theuy would regularly steel multiple sets off the forecourt. like you I haven't heard of it for ages.
If I remove some because the tool broke or got lost then I recommend replacing with standard nuts. som uch potential for trouble while fending off such a minimal threat.
colin1
Captain Safety
PostPosted: 18:32 - 30 Jan 2019    Post subject: Reply with quote
I think for the person ordering a new car they make sense.
For me with an older car, I'd prefer to replace the locking wheel nuts with standard. The wheel looks better without an odd nut although i know nut covers are available.
andym
PostPosted: 19:52 - 30 Jan 2019    Post subject: Reply with quote
A few seconds with a hammer and thin bolster was usually enough to get through any locking wheel nut.... allegedly.
Tierbirdy
PostPosted: 20:18 - 30 Jan 2019    Post subject: Reply with quote
Had this problem with a Civic I bought, no problem I thought, Ill pop to a Honda dealership and theyll help.
They couldnt have given less of a shit. Werent interested, wouldnt tell me which one I needed, and werent willing to let me try ones that looked right to buy the key.
So I bought one of those wheel nut removal kits posted above. Utter shite, did nothing but chew up the bolts. Maybe if you had an air powered impact driver it might do something. After fucking one bolt up royally with it I just took it to a local garage who took the 3 I hadnt fucked up off in seconds with their own tool and charged a tenner total for it. But the one Id fucked up had been slightly mishapen enough by the removal tool that their one wouldnt fit over it, so they had to weld a nut onto it and get it off that way, which ended up costing far more in labour than the kit itself did.
Lesson of the story, just pay someone else to do it.
PostPosted: 23:12 - 30 Jan 2019    Post subject: Re: Car question- removing locking wheel nuts Reply with quote
If it's the type which has a kind of random wiggly line that the locking key fits into and a rotating collar I removed one of these last week for my mate. I used a heavy flat bladed screwdriver as a chisel to chop off the collar then smashed a 3/4"AF 12 point socket onto the head with a club hammer, then just undid the bolt.
The last post was made 7 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 103.36 Kb
