Changing speed sensor
lee8040
PostPosted: 14:18 - 31 Jan 2019    Post subject: Changing speed sensor Reply with quote
Is it easy to change on a gpz 500? Do I just need the sensor or is the seals that also need replacing?
jaffa90
PostPosted: 17:52 - 31 Jan 2019    Post subject: Reply with quote
Any pics of yours?
https://www.bikechatforums.com/viewtopic.php?t=326503
MCN
PostPosted: 10:49 - 01 Feb 2019    Post subject: Reply with quote
It is good engineering practice to replace the old seals.
It may be ok but if the seals leak then you have to do the work again.
May not leak immediately but it helps prevent phaphery.
Caveats : Unless you do not have/cannot source/can't afford new seals.
RhynoCZ
PostPosted: 11:54 - 01 Feb 2019    Post subject: Reply with quote
To what MCN says, I've got only to add that paper gaskets (unless we're talking the crankcase (gearbox), where spacing really does matter), may be fabricated for next to nothing (easy job). O rings and crush washers of all sorts are generic and you do not have to buy the motorcycle/model specific ones.
The last post was made 7 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.72 - MySQL Queries: 16 - Page Size: 40.72 Kb
