Storage
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
toby1
PostPosted: 11:19 - 01 Feb 2019    Post subject: Storage Reply with quote
Here's the thing. I have a few terabyte of precious music files spread over a main computer and external drives.
I want to put these in one place so I started to read about external storage. I looked at say a 4tb drive and thought a decent make like seagate would do it. However reading about drives in general there is a failure figure on new drives of almost 27% in the first year, the general lifespan is 3 to 4 years, and the concensus is that all hard drives will eventually fail - they have a finite lifespan.
So how can I save my music?. I could get paranoid and buy backup drives for backup drives in an infinitive loop? Would the cloud be a safe place - or will I eventually loose my music collection as there is no real long term solution?
doggone
PostPosted: 11:32 - 01 Feb 2019    Post subject: Reply with quote
Even cloud storage is not without risk but should be part of your solution.
I suspect anything stored on google drive should be as a safe as anywhere.
Otherwise duplicated and carefully stored external drives, ideally not kept in the same location are as good as anything. Even if it somehow would not fire up there would be a way to recover data.
I suspect the fail rates are with regular or even constant use.I've got a 'cheap' seagate portable 500Gb attached to the router so it networks, and it has been running for 5 years.
Important stuff is duplicate elsewhere, but it's a quick way to make a second copy almost immediately, or at least same day.
MCN
PostPosted: 11:40 - 01 Feb 2019    Post subject: Reply with quote
Pish.
toby1
PostPosted: 11:42 - 01 Feb 2019    Post subject: Reply with quote
I may be overthinking this - but if I archived to a disc that didn't fire up I probably could retrieve the data - but to where for permanent access ? As you stated the cloud is not 100%, neither is any form of storage - ever.
Unless data is constantly moved and restored it will eventually be lost.
linuxyeti
PostPosted: 11:47 - 01 Feb 2019    Post subject: Reply with quote
Just have 2 backup disks, and rotate backups to them..
Beware what photos you upload, or link to on here, especially if you have family members on them
Im-a-Ridah
PostPosted: 11:51 - 01 Feb 2019    Post subject: Reply with quote
Microsoft or Google are safe cloud providers but its slow to upload and there is a monthly cost.
As for drives you can protect against drive loss with data redundancy using a RAID system i.e 3 drives set up in RAID 5 to recover from one drive dying. The second issue is backups, which protects against someone robbing your house or something. For this get an external USB drive and store it at a relative's place. Cloud is another alternative as a backup and would protect against almost any threat. It all depends how much you want to spend on the protection. As a backup the main downside of cloud is that its a recurring cost for something you might never use, whereas a USB backup drive is a single fixed cost, and you keep the protection if you stop paying.
Cheap: 1 drive for local storage + 1 USB external backup
Medium: 1 drive for local storage + 1 cloud backup
Expensive: 3 drive local RAID + 1 cloud backup
PostPosted: 12:01 - 01 Feb 2019    Post subject: Reply with quote
https://vinylrecorder.com/order.html Thumbs Up
toby1
PostPosted: 12:12 - 01 Feb 2019    Post subject: Reply with quote
The wider picture. The RAID system recovering a dying drive - the drive died so why will the backup drives set to recover also not die - ad infinitum.?
External USB drives have a finite life The cloud has a backup system why can that not fail? - again even a backup system to backup a system is a system set to fail at some point in it's stated lifetime? After all isn't the whole point of a backup system there because we know the primary system may fail? and so the backup cannot be any different. If it was better it would be the primary system and so on?
Not trying to be pedantic on this, certainly storage can and will last for years, but can't forever the law of averages will mean at some point a failure will claim the data., As I said unless constantly moved and refreshed and duplicated all data will eventually be lost. Food for thought.
Riejufixing
PostPosted: 12:50 - 01 Feb 2019    Post subject: Reply with quote
8<
RAID systems don't recover data from dying drives, they have redundant drives so that if one (possibly more) fail, then the data is still available on other non-failed disk(s). The failed or failing storage is replaced, and the RAID system "resynchronises" data onto the new disk to recover redundancy. There's an obvious timing issue here, not to mention other possible issues.
RAID originally meant "Redundant Array of Inexpensive Disks". Marketing I guess corrupted that to "Redundant Array of Independent Disks", but with RAID storage the same saying still holds true: "Fast, cheap, reliable: pick any two".
Yes, data storage does have to be kept up-to-date. Think how hard it would be for instance to recover data off (say) an old '70s removable-media disk (54 megaword) drive, or old 9-track 1/2" tape. Pfffft!
Im-a-Ridah
PostPosted: 13:01 - 01 Feb 2019    Post subject: Reply with quote
Drives don't die that quickly. If you are that concerned then just use a bigger RAID with even more redundancy against 2 drive failures and multiple backups. Also the backups are very unlikely to die as they aren't in use. The data can be as safe as you want to pay for really.
MCN
PostPosted: 17:06 - 01 Feb 2019    Post subject: Reply with quote
I have Tbs and Tbs of 'valuable' shite on several external drives and sticks.
I was advised by a cool IT manager that one should be careful with storage.
Probably fine to ram (no Pun) everything on one device to be convenient but if it dies recovery is difficult.
Dropping the bastirts is usually death.
Opening them (and then separating the discs) is mental/autisic. Embarassed
The multi-disc devices have the discs VERY precisely aligned using expensive specialist equipment.
My tool at the moment is a WD - My Passport External SSD - 1 TB. It's very fast and up to now has performed flawlessly.
I spread my shit/my shit is spread over several drives.
I mainly use at work to keep history of jobs as the company system is pish.
PostPosted: 17:17 - 01 Feb 2019    Post subject: Reply with quote
Buy a Synology 2 bay NAS, set it for RAID 1.
Done and done.
Then when one drive fails you swap it for a new one, rebuild and then when the second one dies, replace it and rebuild. Rinse and repeat.
I think it's pretty sad that in the Geek zone so many people who responded with supposedly knowledgable answers actually have no clue how a RAID array works. ([Edit]with notable exceptions! I realised I basically said the same as I'm-a-Ridah Smile )
I've replaced pretty much all drives in a RAID 10 6 drive array, and the data has been fine - not all at the same time obviously but that's the point of it. It's extremely unlikely for a pair of drives to die at exactly the same moment, so you just replace one when it does. Theoretically it should mean that you keep the data forever.
However, there is an issue of a disaster such as a fire or burglary, in which case you also want off-site backups, but it really does depend on how wedded you are to the data.
It's also worth noting that I have a NAS I bought in 2006 that is still working, and one of the drives is original. I replaced the other about five years ago and that is still going too.
Riejufixing
PostPosted: 17:23 - 01 Feb 2019    Post subject: Reply with quote
Exactly what do you see as problems? That "multi-disc devices have the discs VERY precisely aligned", or something else?
PostPosted: 17:55 - 01 Feb 2019    Post subject: Reply with quote
Dunno, but that's nonsense in itself.
I wasn't going to name names, seems pointless and it should be self evident anyway.
Im-a-Ridah
PostPosted: 18:39 - 01 Feb 2019    Post subject: Re: Storage Reply with quote
Also generally when they say 5 year life they mean 5 years of operation, rather than simply 5 years after production! Think "flight hours" rather than "shelf life". If you used it at work for 8 hours a day, every day, it should be good for 15 years. I wouldn't recommend it, but in theory...
Riejufixing
PostPosted: 19:09 - 01 Feb 2019    Post subject: Reply with quote
Oh, I don't know, discussion isn't - or shouldn't be - about running anyone down, just discussing and hopefully informing.
That bit about "fire or burglary, in which case you also want off-site backups"... reminds me of a place I worked where a local computer room was run from a portakabin, and they were rigorous about backups. The tapes, in that case, were kept in the same room, which would have been fine had the large pump just outside not malfunctioned, sending part of itself through the portakabin, and burning the whole thing to ashes.... oh dear. Oh dear oh dear.
PostPosted: 21:46 - 01 Feb 2019    Post subject: Reply with quote
Ok this is the primary line that triggered my prattishness...
PostPosted: 22:11 - 01 Feb 2019    Post subject: Reply with quote
Replace the terabytes of music files with a Spotify account and you'll never have to worry about backing stuff up ever again.
"in general there is a failure figure on new drives of almost 27% in the first year"
No there isn't. Razz
Riejufixing
PostPosted: 22:17 - 01 Feb 2019    Post subject: Reply with quote
Smile Well it's sort-of right in a way, in that the drives will eventually fail; but your point is that they should be replaced as and when....
PostPosted: 22:31 - 01 Feb 2019    Post subject: Reply with quote
My point is that RAID accounts for the likelihood of failure of a drive.
Each drive type will have a mean time to failure. Some will do better than that, some will do worse but usually there is a curve and it's INCREDIBLY unlikely that two drives will fail at the same time.
As I used to tell my customers: "The RAID system is designed to monitor the performance specifications of every drive and compare it to it's peers. If any of those specifications moves out of bounds when compared with it's peers, the system will pre-emptively fail the drive. If another drive starts throwing errors, often the system will not fail this second drive until the first one is rebuilt. Drives that throw errors do not necessarily indicate a hardware failure, rather a drop off in performance. This means that you have some safety margin to swap the failed drive, but you should do so as soon as you have obtained a replacement. It is not uncommon for a replacement drive procedure to trigger a second drive failure for the reasons outlined above. This drive failure will only occur once the first drive rebuild is complete"
Most home NAS's probably have different failure thresholds to our broadcast critical playout server NAS architecture, but it will work in a similar way.
iooi
PostPosted: 22:36 - 01 Feb 2019    Post subject: Re: Storage Reply with quote
Makes great reading....
Of course any drive can fail at any point.
Better to keep running, than keep switching off and on all the time.
Pigeon
PostPosted: 22:58 - 01 Feb 2019    Post subject: Reply with quote
Agree. Redundancy limits risk.
Original + 1 copy on-site + 1 copy off-site.
Im-a-Ridah
PostPosted: 13:16 - 02 Feb 2019    Post subject: Reply with quote
Just to add, the off-site copy doesn't have to be really up to date. It's just about damage limitation. It's better to lose 1 year of data than everything.
PostPosted: 21:10 - 02 Feb 2019    Post subject: Reply with quote
Depending on your cash, M-Discs are 100+ year life. Got a few at work.
Otherwise decent NAS, few low speed drives in RAID1, not a problem.
Andy_Pagin
PostPosted: 12:09 - 03 Feb 2019    Post subject: Reply with quote
I keep all my precious stuff on a server at work, can't get any safer since it's all virtualised at a data centre. So if you're in a reasonably secure job with a company that has those facilities you could ask your IT guys nicely.
The last post was made 7 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 5.26 - MySQL Queries: 13 - Page Size: 136.65 Kb
