| vocab |
 vocab L Plate Warrior
| Robby |
 Robby Dirty Old Man
 Posted: 17:40 - 04 Feb 2019 Post subject: |
There are a few confusing things in the post, lets get them ironed out first.
1. Drum brake rotating. The brake should have two things attached to it, the torque arm (which is a fixed length) and the operating rod (which moves to work the brake).
The brake is meant to move/rotate a bit against the torque arm when you move the wheel back and forth for chain tensioning, and also when the wheel is moving up and down with the suspension.
You might need to adjust the rear brake to compensate for the wheel being further forward or back when you adjust the chain, but usually it's such a small movement that it won't make a difference.
2. Chain being "somewhat smaller". I'm assuming you mean it is shorter. Chains stretch over time so a new one will always be a little shorter, but you could also have fewer links in it. If it fits, not really a problem.
3. Clicking noise. That's not good.
To find out if it is the chain, put the bike up on the centre stand and spin the wheel in both directions, listen for clicking and find out where its coming from. Most likely problem is a loose bolt(s) on the front or rear sprocket, allowing the sprockets to move around and make noise.
Also possible that you fitted the wrong chain and sprocket kit, or that the rear wheel isn't aligned properly. Make sure the adjuster marks are clean and you've got good light to look at them, its possible to miss a mark when its covered with a layer of shit. |
| vocab |
| jaffa90 |
 jaffa90 World Chat Champion
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| vocab |
The last post was made 7 years, 243 days ago. Instead of replying here, would creating a new thread be more useful? |
