"Oval" rear wheel (drum brake) - what is it?
ThunderGuts
PostPosted: 10:34 - 05 Feb 2019    Post subject: "Oval" rear wheel (drum brake) - what is it? Reply with quote
Morning all
So I'm going to take a look at my ER5's rear wheel this weekend as my rear brake "pulses" when applied (and has just started making a slight squeal just before I come to a stop). Now from what I can gather, a good clean up and lube of joints/pivots etc. can solve a lot of rear drum issues, but I've also heard of the infamous "oval wheel" syndrome.
Is this literally what it sounds like, i.e. the drum itself is no longer round? Or is it something else? What sort of roundness (!) can I (or should I) expect if I measure the inside of the drum? Within half a mm or something?
Cheers all. Thumbs Up
TG.
Meatybeaty
PostPosted: 11:28 - 05 Feb 2019    Post subject: Reply with quote
Maybe just an adjustment on the rear brake shoes
redeem ouzzer
PostPosted: 11:59 - 05 Feb 2019    Post subject: Reply with quote
Yep, the drum lining either has a big rusty deposit in one spot, or has warped and gone oval. There might be an ovality tolerance in the manual but any at all will be felt through the pedal.
Be a REAL MAN!
Riejufixing
PostPosted: 12:59 - 05 Feb 2019    Post subject: Re: "Oval" rear wheel (drum brake) - what is it? Reply with quote
If the drum's distorted it will feel like old-fashioned anti-lock brakes working. I don't know what maximum run-out is, but I'd guess about 0.25mm. You can measure it with a dial gauge or even check it by eye and a pointer just to see if it's out of round, after checking other possible causes of judder.
ThunderGuts
PostPosted: 13:01 - 05 Feb 2019    Post subject: Reply with quote
Thanks all. The feel is more of a gentle pulsing (clearly linked to speed though)
If there is a rusty deposit inside the drum, can it just be gently sanded down to remove it?
TG.
PostPosted: 13:20 - 05 Feb 2019    Post subject: Reply with quote
More likely cracked than oval. Does the wear indicator show that you need new shoes?
R1stu
Shrek!
PostPosted: 13:44 - 05 Feb 2019    Post subject: Reply with quote
My 350 has this, never worried about it, last 3 MOTs just been an advisory for 'Slight fluctuation of the rear brake'
Drum was clean from the powder coaters so must have been uneven wear causing it.
If it gets to point it fails, I have a spare rear wheel and more than likely cheaper than repairing.
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
ThunderGuts
PostPosted: 14:10 - 05 Feb 2019    Post subject: Reply with quote
Wear indicator looks OK, although it probably got reset (?) when the wheel came out for a tyre change. No cracks visible that I've noticed but I'll look more closely.
TG.
Riejufixing
PostPosted: 14:34 - 05 Feb 2019    Post subject: Reply with quote
Yes, do it by hand. If the inside of the drum is smooth, that's enough, you don't need to remove metal.
ThunderGuts
PostPosted: 14:37 - 05 Feb 2019    Post subject: Reply with quote
By the way, not sure if relevant, but when I first got the bike (600 miles ago) it had been stood for a long time and when the rear wheel was turned over by hand it encountered a lot of resistance once every revolution - now that resistance has virtually gone and it pretty much turns freely.
TG.
Riejufixing
Did the juddering start after the tyre change, or was it there before?
PostPosted: 15:11 - 05 Feb 2019    Post subject: Reply with quote
Bit of vital info there...
I wonder if it had a good jetwashing and some water laid in the drum to make a rust patch.
ThunderGuts
PostPosted: 15:34 - 05 Feb 2019    Post subject: Reply with quote
It was there before, I think slightly more so if anything but the tyre change was 10 miles into ownership when the old tyre decided to split open (it was intact at purchase, but obviously was perished and it took that little bit of riding to make it crack).
Possible - it was fairly clean when bought but I know it'd done about 1000 miles in the last 2 years and judging by the other things I've dealt with (gummed up carbs and fuel tap, perished tyres etc.) I think the thing had been sat for quite a while.
I've got the service manual - it doesn't look like too hard a job to dismantle the outer casing of the drum and that will presumably reveal if it's a rust patch.
TG.
MCN
PostPosted: 18:20 - 05 Feb 2019    Post subject: Reply with quote
If in doubt whip it out.
15-20mins will remove the wheel and open the drum.
YU still posting? Very Happy
kgm
PostPosted: 19:08 - 05 Feb 2019    Post subject: Reply with quote
Whip the wheel off and have a look, it's an easy job. Give the drum and shoes a light sand of there's rust patches, clean and lightly grease the cam then chuck it back together
ThunderGuts
PostPosted: 09:24 - 06 Feb 2019    Post subject: Reply with quote
Cheers all. It's a job for the weekend really! I've got some marine grease - presume this should be OK for this job as I don't think I've got any bog standard grease?
TG.
PostPosted: 11:06 - 06 Feb 2019    Post subject: Reply with quote
That will be fine just don't over-do it. You don't want the grease to end up plastered over the shoes.
ThunderGuts
PostPosted: 11:55 - 06 Feb 2019    Post subject: Reply with quote
Grease on the shoes might stop the squeaking Idea . . . joke Wink
TG.
MCN
PostPosted: 19:58 - 06 Feb 2019    Post subject: Reply with quote
It prevents the shoes wearing and improves full economy too. Dance!
ThunderGuts
PostPosted: 13:14 - 09 Feb 2019    Post subject: Reply with quote
Ok I think I’ve found the issue. Looks like the lining as lifted slightly from the wheel in one spot creating a high point. It’s clear this is where the shoes are wearing the drum the most. There is a small crack in the centre of this high point approx 8mm long.
The engineer in me tells me this is bad Sad
TG.
redeem ouzzer
PostPosted: 13:59 - 09 Feb 2019    Post subject: Reply with quote
Time for a decent 2nd hand wheel....
Be a REAL MAN!
ThunderGuts
PostPosted: 15:34 - 09 Feb 2019    Post subject: Reply with quote
Now I’ve cleaned it up I don’t think the lining has lifted at all - think that was an illusion caused by a shadow between the lining and the wheel itself. The crack seems pretty hairline....can’t feel it with a fingernail
TG.
PostPosted: 16:19 - 09 Feb 2019    Post subject: Reply with quote
No matter which way you look at it that drum liner is warped. Could be that the ally hub has oxidised under that crack and the oxidisation has pushed the liner in.
If it was a very rare wheel I'd look at finding someone with a lathe and skim that drum, but otherwise a replacement would be sought. If the juddering was bad and I absolutely had to have the bike for use I'd maybe linish off the high spots with a flap wheel whilst I spent time looking for a replacement.
ThunderGuts
PostPosted: 16:36 - 09 Feb 2019    Post subject: Reply with quote
It’s more of a gentle pulsing than juddering - I don’t really notice it that much unless I focus on it. Only really apparent at very slow speeds. I agree, it’s clearly not round though. Will it “wear in” over time?
TG.
MCN
PostPosted: 17:14 - 09 Feb 2019    Post subject: Reply with quote
If it's only on the rear brake then it's not a biggy. It's a drum brake, It's on the rear so it's effects become kind of redundant as weight shifts onto the front wheel when braking.
I forget to use the rear brake unless stopped on a hill and I want to sit upright.
The last post was made 7 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 127.76 Kb
