FZ6n 2008 Err3 bouncing rev counter while riding
natefz6
PostPosted: 22:22 - 05 Feb 2019    Post subject: FZ6n 2008 Err3 bouncing rev counter while riding Reply with quote
Hi all,
I was riding to work today when my bike decided to have a bit of a fit. I didn't notice any change in the control, handling or power but the controls went a bit cuckoo.
On the Digital speedo side it was reporting temp as HI (it wasn't as far as I could tell) then it had Err - 3. on the Rev counter side the rev counter looked like it kept resetting and the engine management lights and temp lights kept flashing.
I slowed down a bit concerned but after a couple more mins it seemed to clear and the readings returned to normal (temp 73 no lights correct revs)
It was fine for the rest of the journey and got me home tonight too.
Any ideas what might have caused this or am I just an extra in Stranger Things?
Cheers!
Edit: so manual say
Fault code: Er-3
Diagnostic Code: --
Symptom: Data from the ECU cannot be received correctly.
Probable cause of malfunction:
Improper connection in wiring sub lead.
Malfunction in meter.
Malfunction in ECU.
So now I just need to work out how to diagnose each of those Very Happy
"no I didn't steal it that's just the way I ride"
Pigeon
PostPosted: 01:05 - 06 Feb 2019    Post subject: Reply with quote
With the bike running, but stationary. Move the bars from lock to lock, does it cause an issue?
If so, suspect some damaged wires / short around the headstock.
If not, would be looking at corrosion around connector blocks and earth.
Tankie
PostPosted: 06:40 - 06 Feb 2019    Post subject: Reply with quote
I would also be looking at the earthing first of all, then as stated at the loom around the headstock area.
Meatybeaty
PostPosted: 06:41 - 06 Feb 2019    Post subject: Reply with quote
Think @Pigeon is spot on here, connectors and wiring
lukamon
PostPosted: 22:59 - 06 Feb 2019    Post subject: Reply with quote
similar to the problems i had - turned out to be a burned stator. check the charge voltage / ac output voltage and check if any of the 3 stator wires have contininuity with earth (frame)
killa wrote: Im an ass man myself
natefz6
PostPosted: 09:44 - 07 Feb 2019    Post subject: Reply with quote
Thanks all,
I will take a good luck at the wiring this weekend as about 5 months ago i did fit heated grips so it could be with the salty roads some water got in somewhere.
I had the Reg/Rec changed last year and at the time the guy was talking about sending the stator off to be rewound but when he checked it and it was all OK. Thats not to say it might not have gone in the mean time of course.
The problem has not reappeared since but its about time I cleaned some of the crap off and re treated with XCP anyway, so while doing that I will check the wiring carefully.
The last post was made 7 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.49 - MySQL Queries: 13 - Page Size: 47.71 Kb
