fitting exhaust pipe 81 cg125
speedingmotor...
PostPosted: 14:49 - 07 Feb 2019    Post subject: fitting exhaust pipe 81 cg125 Reply with quote
hello everyone
i am fitting a new exhaust pipe onto an 81 cg125. i am having trouble getting everyting to fit right, the gasket, the collets, the flange AND get the two bolts into the rear bracket. any tricks or advice?
thanks!
https://www.youtube.com/watch?v=zojEIR_SGSk
Riejufixing
PostPosted: 15:01 - 07 Feb 2019    Post subject: Re: fitting exhaust pipe 81 cg125 Reply with quote
speedingmotorcycle wrote:
i am fitting a new exhaust pipe onto an 81 cg125. i am having trouble getting everyting to fit right, the gasket, the collets, the flange AND get the two bolts into the rear bracket. any tricks or advice?!
Are you sure that the bits are the correct ones and the bracket isn't changed somehow?
Other than that, don't do anything up tight until it's all in place.
speedingmotor...
PostPosted: 12:30 - 08 Feb 2019    Post subject: Reply with quote
hi thanks for your reply
yes all the parts are correct, ordered from wemoto, it just seems tricky to get the collets and flange in place while also having the bolts go into the exhaust pipe. i dont know if there is a special order or if you have to hit it a bit with a wooden mallet Sick
thanks for any advice
The last post was made 7 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 35.67 Kb
