Speedo cable slack at the wheel
XT65
PostPosted: 18:27 - 07 Feb 2019    Post subject: Speedo cable slack at the wheel Reply with quote
Hello all
Just replacing the speedo cable on an XR125.
I'm not sure how to secure it at the wheel end,the screw doesn't do anything at all to hold it in place and it seems the only place to lock it in there is the positioning of the clamp that holds the cable to the fork!
It was the same on the old one too.
Surely it should be a lot more secure than just slotting it on the spine and tightening the clamp?!
Do you pack it with grease?
Maybe I pull the boot down further ?
Cheers all
All sorted now,just me being a nob...
Taking the retaining screw out completely did the trick .
The groove now slots all the way to the shoulders and the drew is now doing the job it was intended to do.
Thanks all ,its good to talk and put another sensible perspective on a job- Sometimes it's all you need.
Always helpful, nice one and stay safe ok
Nobby the Bastard
Harley Gaydar
PostPosted: 20:15 - 07 Feb 2019    Post subject: Reply with quote
Have you tried taking the screw out entirely to see if the outer wikk seat deeper in?
Twisting the top of the inner soy that it can seat correctly at the bottom?
Triumph Sprint ST 1050
Suntan Sid
PostPosted: 21:16 - 07 Feb 2019    Post subject: Reply with quote
If the XR is the same as the XL, unfortunately that's just the way it is!
The locking screw merely stops the drive cable coming out of the hub, it does not stop the whole thing wobbling around!
XT65
PostPosted: 11:29 - 08 Feb 2019    Post subject: Reply with quote
Ok Sid,I think you could be right.
What an oddshit set-up.
Should be like a plug keeping the outside of the cable flush or a screw on like the other end!
The weather gets in there easy..
Cheers man
XT65
PostPosted: 11:53 - 08 Feb 2019    Post subject: Reply with quote
You know ,to be honest I hadn't thought of doing that .
Maybe thinking it was a really sensitive piece that could lose precision or fall into the hub.
But it's really a tractor .....
I will do as you suggest once it stops pissing it down..
See if I can find a diagram of what should be n there .
Nice one!
The last post was made 7 years, 229 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 45.06 Kb
