| stinkwheel |
 Posted: 20:49 - 04 Feb 2019 Post subject: How to bend thickish alloy bar? |
This might be a bit too much of an ask of the material but worth a try.
I want to make a rear rack for a bike. I'm too tight to blow £150 on a quick-rust rentec. The plan is for it to be really basic, two bars about 300mm long sticking out the back from the grab rail mounts with a fenestrated plate mounted on top.
I've got some 10x30mm 6082 flat bar for the job (overkill?).
Each bar will need a slight dog-leg in the middle of about 10 degrees. This will need to be in the vertical aixs. So if you're looking straight at the 30mm face of the bar, that's where you'd see the dog-leg.
I planned to heat it up in the oven for an hour or so (my fan oven will go to 250C) then clamp it firmly just before the bend, slide a long bit of pipe over and slowly-slowly apply a bending force (or just the weight of the pipe) while heating the metal on the outside of the bend radius. Then leave it to sit somewhere cool for a few days to re-harden before doing anything else with it.
Option 2 would be to half cut through it, apply the bend in a similar way to above then lumiweld the slot (any weight would be acting to close rather than open the slot).
The other option would be to cut the angles and see if I can find someone to TIG it up.
However, a bend would be nice if it's achievable.
Sketch attached, although I intend the finished article to have a more radiused finish.
Main thing is, I'm not sure if this kind of bend is possible without cracking the material, or if the heat treating to achieve one without cracking will rob so much strength it wont recover enough to be useable. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MCN |
 MCN Super Spammer
 Posted: 21:35 - 04 Feb 2019 Post subject: |
I think aluminium melting point 600-700ºC.
We used to use bar soap rubbed on the piece before heating as an indicator. It will go black or dark brown at annealing temp.
I think I seen an aluminium slab being rolled into sheet on youtube. They pre-heated the slab and then rolled in a hot mill before continuing in a cold mill.
You will be messing with any post production properties of the material if you heat an bend.
This is aircraft related. Not the same alloy but there are some temperatures in there. (In American )
They say 650F 343C So at least your bar won't melt.
https://www.tinmantech.com/education/articles/aluminum-alloys-annealing.php
You can only try. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| Riejufixing |
 Riejufixing World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 22:33 - 04 Feb 2019 Post subject: |
You're bending it the hard way by the looks of your drawing. Bending that 30mm width in T6 harness I would say you'll need a good 150mm radius bend or it'll start cracking on the outside edge.
No scientific data was harmed during this guesstimation. ____________________ a.k.a 'Geri'
| Robby |
 Robby Dirty Old Man
| MarJay |
 MarJay But it's British!
| Riejufixing |
| Pete. |
 Pete. Super Spammer
| MCN |
 MCN Super Spammer
| Grubscrew |
 Grubscrew Scooby Slapper
| ART-ADS |
 ART-ADS Nova Slayer
| ThatDippyTwat |
| kramdra |
 kramdra World Chat Champion
| ART-ADS |
 ART-ADS Nova Slayer
| virus |
 virus World Chat Champion
| ART-ADS |
This post is not being displayed because it has a low rating (Flame). Unhide this post / all posts.
 ART-ADS Nova Slayer
| virus |
 - Super Spammer
| P.addy |
 P.addy Red Rocket
| ThatDippyTwat |
The last post was made 7 years, 222 days ago. Instead of replying here, would creating a new thread be more useful? |
