Issues with used car after a month and a half
Nope.
PostPosted: 13:36 - 13 Feb 2019    Post subject: Issues with used car after a month and a half Reply with quote
Hi All,
So I thought I'd seek the advice of the BCF collective.
Approximately a month and a half ago I purchased a Range Rover from a non-franchise dealer. It's a 2011 with FSH, 4.4 TDV8, and 80k miles on the clock. I paid around £16k for the car.
After a few days it developed an oil leak from a gasket underneath the oil cooler which sits in the V. I spoke to the dealer and we agreed that I'd pay the labour and he'd pay the parts (the parts were more expensive). This was repaired.
I've put around 2k miles on the car since, and it seemed to perform fine. I was driving the car on a long distance trip (again, performing fine) and I got a "reduced performance" warning on the dash. I pulled over, shut the car off, started the car again and the warning returned. When the codes were read the error was relating to boost pressure, we assumed through a split hose. I had the car recovered to a garage local to me and they looked at it.
They started the car and the error had cleared. They drove it for 10~ miles and said it drove absolutely fine. They then plugged in their computer and looked at the raw sensor data. One MAF was showing 0, so they assumed it was a fault MAF. They swapped them over to make sure, but the other MAF also read 0 on that intake.
They then removed the air intake and put their hand over the intake while the car was revved, there was no air drawn from the intake. This would suggest a failed/seized turbo charger.
Since the car was driving fine (at least to my knowledge, it's the only one I've driven!), and hasn't changed since I bought it, I can only assume this turbo has been faulty since I bought the car, or has been slowly failing over a period of time.
Basically, I'm staring down the barrel of a £3.5k turbo replacement bill since it's basically an engine out job, and everybody seems to say you should change both.
Do I have a leg to stand on with the dealer? I've not spoken to them yet as I've not had the final diagnosis from the garage yet as they're taking it apart today to look at the turbo.
Since I am fairly convinced this issue is preexisting, is the dealer liable for the repair? I know this used to be covered by the sale of goods act but it's now the consume rights act. Does anybody have any recent experience or advice to offer?
Hawkeye1250FA
PostPosted: 14:09 - 13 Feb 2019    Post subject: Reply with quote
https://www.google.com/amp/s/www.autoexpress.co.uk/car-news/consumer-news/34744/rejecting-a-new-or-used-car-top-tips%3famp
Basically within 30 days = easy peasy
Between 30days and 6 years = still possible but you need to prove it was pre-existing.
You may need to spend some money on a garage to confirm this in writing.
However, with 80k miles on the clock, I think you will be laughed out of their showroom myself. Sold as described I think. Sorry 😣
Just unlucky.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
Riejufixing
PostPosted: 14:18 - 13 Feb 2019    Post subject: Reply with quote
No idea about the legalities. Try honestjohn.co.uk There's an "ask HJ" facility and forums where knowledgeable people read & psot.
"They then removed the air intake and put their hand over the intake while the car was revved, there was no air drawn from the intake. This would suggest a failed/seized turbo charger."
The air intake to what, the turbocharger?
"Basically, I'm staring down the barrel of a £3.5k turbo replacement bill since it's basically an engine out job, and everybody seems to say you should change both"
https://best-turbos.com/land-rover-turbo-replacement/?gclid=EAIaIQobChMIyN3kxPK44AIVCrvtCh02NwADEAAYASAAEgJnKfD_BwE
There seem to be other places too. Also, I can't see why replacing a turbo should go together with replacing the engine....
PostPosted: 14:46 - 13 Feb 2019    Post subject: Reply with quote
Hmmmmmmm.
Full service history, when was it last serviced and was it by a Range Rover dealer?
"has been slowly failing over a period of time"
Yes, cars do that.
Does the Range Rover dealer know that you're having it taken apart by some other garage?
Was the oil leak from the feed or return pipe to the turbo?
Thinking out loud, if the problem with the turbo should have been spotted when they fixed the oil leak or at the very least flagged up to you as an incoming bill, that would have been the time to fix it rather than waiting until it went failed.
Did they tell you what parts were replaced when they fixed the oil leak?
PostPosted: 14:51 - 13 Feb 2019    Post subject: Reply with quote
Needs to be as described, of satisfactory quality and fit for purpose.
In general, if you spend £16k on a car it's reasonable enough to expect the car not to go bang after just 2,000 miles.
This probably isn't going to be a straight forward one though. Sad
PostPosted: 15:21 - 13 Feb 2019    Post subject: Reply with quote
Within Six months of purchase it's down to the dealer to prove that the issue was not pre-existing, and so they should be liable.
I'm surprised more BCFers aren't aware of this...
Copypasta from Honest John's site:
WHAT CAN YOU DO IF YOUR NEW CAR OR YOUR RECENTLY PURCHASED USED CAR DEVELOPS MAJOR FAULTS?
The FAQ now gets into the much more complex aspects of the various pieces of legislation and case law.
While this gives you your legal rights based on statutory regulations and case law, it's obviously always best to attempt to negotiate first.
A dealer might try to use a lot of flannel to try to wriggle out of a claim, but as soon as you start asserting your rights by quoting the appropriate case law, in particular Clegg v Olle Andersson, he may capitulate.
The limit for claims in the Small Claims Track of the County Court was raised from £5,000 to £10,000, as from April 2013, making this service much more useful in disputes over purchases of cars.
Small Claims cases should be commenced via moneyclaim.gov.uk , which is cheaper than the Small Claims Track of the County Court. Link to Small Claims here: Small Claims Track.
PostPosted: 16:22 - 13 Feb 2019    Post subject: Reply with quote
The place I bought my Jaguar from told me any faults that weren't wear and tear items would be sorted within 6 months or 6000 miles.
Now I don't know if they were stating that because of the law or it was their own guarantee but I'm sure they wouldn't be offering that if they thought they could get away with less.
I do wonder why you didn't go back to the supplying dealer initially with your turbo fault rather than use another garage. You have just pulled a third party into the equation which initially I wouldn't think helps your case.
Triumph Trophy Launch Edition
2Hondas
PostPosted: 16:29 - 13 Feb 2019    Post subject: Reply with quote
What he said.
I returned my C-Class that presented a timing problem after a couple of months.
From what I remember they get one chance to fix the problem at their cost, after which you have a right to return it (minus a small deduction for use of the car).
https://www.moneysavingexpert.com/shopping/consumer-rights-refunds-exchange/#goods
Current - 2010 Kawasaki ER-6n - Green
Previous - 2000 Honda CB600F Hornet - Yellow
Previous - 2007 Yamaha YBR125 -Blue
Hawkeye1250FA
PostPosted: 17:50 - 13 Feb 2019    Post subject: Reply with quote
Potato potarto.
As the dealer I'd say 80k miles of wear and tear was obviously going to cause problems on something sooner or later. 80k miles advertised, therefore as described. 👍
I'd be pissed off and arguey if it was me, but I wouldn't touch an 80k car with a barge pole - especially not for 16k 😲
M.C
PostPosted: 18:54 - 13 Feb 2019    Post subject: Reply with quote
inb4 grumpyguts
TbirdX
PostPosted: 19:08 - 13 Feb 2019    Post subject: Reply with quote
So the cars drives fine, hasn't thrown another fault code and they say the turbo is bust?
You can't take these motors to any old garage and expect a cheap fix. I've had 2 Disco 3's and both threw all manner of faults that look terminal but cost nothing to fix, take it to someone who doesn't know them however, and you'll change £500 worth of sensors before they give up and can't fix it.. RR's are the same.
Find an indie RR specialist and get it looked at or get a credit card with a very high limit and a good recovery package.
VFR800X - CFMoto 450MT - TTR250
duhawkz
PostPosted: 21:10 - 13 Feb 2019    Post subject: Reply with quote
Is the car on finance/credit card or was it bought out right
If there is a finance agreement attached to it, you may be able to make a section 75 claim to the finance company
https://www.moneysavingexpert.com/shopping/section75-protect-your-purchases/
mentalboy
PostPosted: 02:07 - 14 Feb 2019    Post subject: Reply with quote
This isn't the 1970's, a modern car engine is barely run in at 80k.
Make mine a Corona.
UnknownStuntm...
PostPosted: 08:22 - 14 Feb 2019    Post subject: Reply with quote
This isn't the 1980's, manufacturers have long been dialling in a 'life expectancy' to components. 80k is low, but ... meh.
stevo as b4
PostPosted: 08:37 - 14 Feb 2019    Post subject: Reply with quote
I'm with Hawkeye on this.
Sure 80k is nothing for a modern looked after car with FSH, or it wouldn't be for something simple/sensible like a Ford Focus with a naturally aspirated Duratec engine.
But a car as complicated and well known for its reliability issues as an older Range Rover, (8years old), and with tons of equipment and electronics that will eventually go wrong is a £16k gamble.
That TDV8 engine alone is very complicated, and has twice as much to go wrong being a twin turbo V8. As someone said it's riddled with sensors and electronics, and it's not an engine you can easily convert to aftermarket management if it all goes wrong or fries an ECU.
Also your likely to have issues with common modern diesel faults such as blocked up DPF's, clogged EGR valves etc, as your unlikely to be able to drive a 4.4L V8 hard enough in daily traffic to keep it happy and allow the DPF re-gen cycle to work. Also you can bet whoever bought this car new really didn't give a fuck, and wasn't interested in under bonnet checks, or if anything went wrong they could simply trade it in and buy a new car.
Hawkeye1250FA
PostPosted: 08:39 - 14 Feb 2019    Post subject: Reply with quote
For a normal car maybe.
However https://www.osv.ltd.uk/how-reliable-are-land-rover-and-range-rover/amp/?how-reliable-are-land-rover-and-range-rover/
BTTD
PostPosted: 08:45 - 14 Feb 2019    Post subject: Reply with quote
If they did note that the oil leak was from a turbo pipe when they fixed it, I'm guessing they crossed their fingers and hoped it would last.
Has the turbo actually gone? I don't know how clever those engine management systems are, but if there's an engine fault can they disable the turbos if they're variable vane?
I'm pretty sure my old Jeep CRD did this when it went into limp mode. It would rev all the way but with f'all power, and no turbo engagement.
On a side note I applaud your bravery in buying an 8 year old RR with 80k on it. I mean, yeah, it's not high miles for the age, but RR are complicated and somewhat prone to issues.
Also, when you say engine out job, is that literally taking the engine out or does that mean taking the body off like the Discovery? F'ck that.
PostPosted: 09:20 - 14 Feb 2019    Post subject: Reply with quote
I agree with the above. You need someone who knows these cars.
I also don't think 80k is unreasonable nowadays but it took a long time for me to get the '100k is worn out' idea out of my mind.
If a dealer is willing to sell a car with 80k on it then he has to take the responsibility for at least some warranty in my eyes. If he isn;'t then he shouldn't sell it through his dealership but do it privately with the corresponding drop in price.
PostPosted: 10:34 - 14 Feb 2019    Post subject: Reply with quote
The reasoning that you should expect a Range Rover to break down doesn't hold water, because if a buyer is expected to do their research and apparently accept the risk of buying an unreliable motor then equally the seller must accept the same risk in selling one.
Failed turbo after 6 weeks and 2000miles = dealer liability IMO.
BTTD
PostPosted: 11:26 - 14 Feb 2019    Post subject: Reply with quote
I totally agree, my comment on his bravery is the fact that I would be expecting something to go wrong at some point over the next few years, and there's a good chance it'll be expensive.
With any luck everything will go wrong in the next couple of months and he'll get the dealer to sort it all! Laughing
PostPosted: 17:14 - 14 Feb 2019    Post subject: Reply with quote
Potato potarto.
Except, the law says that if an issue arises on a car sold by a dealer or trader within six months of purchase, it's down to that dealer or trader to prove it wasn't present when the car was purchased. So you should be pretty sure they'll fix it.
PostPosted: 17:36 - 14 Feb 2019    Post subject: Reply with quote
They should fix it, how straight forward that'll be is another matter entirely. Sad
It should become apparent quite quickly how willing they are to play ball, seeing as they wanted him to pay the labour when fixing the oil leak which occurred in the first few days, I wouldn't be very confident about them being willing to pay for a new turbo.
Give them one attempt to fix the fault and if they don't then you can reject the car and get a refund.
I've a horrible feeling that the fact you've had another garage working on it is going to complicate things. Sad
PostPosted: 19:20 - 14 Feb 2019    Post subject: Reply with quote
That's the bit that worries me as well. Maybe if it was a Land Rover main dealer you would have a bit of leverage but some random independent is just going to muddy the waters.
The last post was made 7 years, 3 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 135.57 Kb
