De-ionised water for coolant dilution.
Riejufixing
PostPosted: 17:52 - 16 Feb 2019    Post subject: De-ionised water for coolant dilution. Reply with quote
Euro Car Parts TRIPLE QX De-Ionised Water 5Ltr £5.39
Tesco De-Ionised Water 5L £1.80
Any difference, apart from £3.59?
Grubscrew
PostPosted: 18:22 - 16 Feb 2019    Post subject: Reply with quote
One wonders if that is really what is being paid for.....who’s to know otherwise.
Look at vodkas,gins and wine all claiming this that and the other when in fact it’s some cheapo concoction.
FJR1300/CBR1000F
Nobby the Bastard
Harley Gaydar
Tbh I'd just use tap water for coolant. The amount of minerals in a couple of pints is minimal. Its not like you change it every day.
Triumph Sprint ST 1050
Tankie
PostPosted: 18:29 - 16 Feb 2019    Post subject: Reply with quote
Buy the Tesco's one and be happy, do not use tap water
Sister Sledge
PostPosted: 22:58 - 16 Feb 2019    Post subject: Reply with quote
On a similar subject ASDA sell dot 4 brake fluid for £3 or something. Haines sell it for £7.
Surely the fact that it's to a strict standard for brakes it's just as good??
CCM 404 DS
piazza
PostPosted: 23:08 - 16 Feb 2019    Post subject: Reply with quote
Isnt boiled water left to cool de-ionised, thats what I was led to believe anyway. And Ive used the it as that, no adverse effects to report.
Tankie
PostPosted: 23:10 - 16 Feb 2019    Post subject: Reply with quote
Of course, it's to a standard so there is no problem Cool
Tankie
PostPosted: 23:18 - 16 Feb 2019    Post subject: Reply with quote
Not quite, it's re condensed steam
ThatDippyTwat
PostPosted: 23:29 - 16 Feb 2019    Post subject: Reply with quote
De-ionised water is put through filters. Distilled is steam put through a condenser. They are not the same, and have different properties which may or may not matter.
A lot of people interchange the names, though they are different processes and products.
bladerunner
PostPosted: 00:21 - 17 Feb 2019    Post subject: Reply with quote
I condense water vapour and use that. testing my local tap water its between 360ppm during last years dry summer and 128ppm at the moment after the usual winter rain fall. the end product reads 3-6 ppm so it works! Laughing Laughing
RhynoCZ
PostPosted: 00:59 - 17 Feb 2019    Post subject: Reply with quote
I used tap water before, as that's what the service manual said, mixed with ethylene glycol, of course.
There is also a theory, that deionised or distilled water (one of those at least) could be harmful to the engine. Everything in chemistry seeks equilibrium and such water could pull minerals/metals from the actual engine. Fun fact about chemistry, if you put stainless steel (reduced carbon content) right on a regular steel, the stainless steel will pull the carbon out of the regular steel and rust away.
To be honest though, it would take a lot of time for deionised or distilled water to eat away enough metal from your engine to cause a leak. The point here is though, tap water mixed with ethylene glycol is not only better for your engine, but also much cheaper.
pepperami
PostPosted: 12:56 - 17 Feb 2019    Post subject: Reply with quote
Really? You’re putting water in your radiator/expansion tank to get the coolant level up to the recommended level according to the manual.
Just get a jug of water and top it up.
If you have to top your bike coolant system up so often that you need to worry about furring up the engine/pipework, you must have one serious leak Shocked
I change my coolant on every service and on the very very few occasions I have needed to top up, I have just used tap water.
So far no engines were harmed or felt mistreated with any of the bikes I have owned.
PostPosted: 15:48 - 17 Feb 2019    Post subject: Reply with quote
I usually suggest people look in their kettle. If it's spotless, crack on and use tap water. If it's full of scale and chalk, do not.
I've stayed places that had such hard water you would have physical lumps floating in your tea if you boiled the same kettle full of water more than once. I would not put that stuff in my radiator.
Two common and free houshold sources of distilled (not de-ionised) water which will be fine to use in a radiator:
1) The condensate tank from a condensing tumble drier (the type that don't vent to outsid)e. Many are plumbed in but there's usually an option to collect the liquid in a small removable tank that needs emptying every time for if it's not situated near a drain. Usually just need to move a single push-fit hose on the back to switch between drain and tank.
2) The ice that forms on the inside of your deep freeze.
Islander
PostPosted: 18:44 - 17 Feb 2019    Post subject: Reply with quote
That would be distilled water.
Riejufixing
PostPosted: 18:54 - 17 Feb 2019    Post subject: Re: De-ionised water for coolant dilution. Reply with quote
£4.59. It was £1 for 2.5l at Tesco. Near the oil and other odds and ends.
Riejufixing
PostPosted: 19:00 - 17 Feb 2019    Post subject: Reply with quote
There are different specifications. Superbikeshop sellsl EBC, for instance, which has a lower spec. in terms of boiling points (150 deg C "wet") than does ATE SL6 (Minimum Wet Boiling Point : 175 Degrees C). Not criticising the shop, BTW.
Sister Sledge
PostPosted: 23:20 - 17 Feb 2019    Post subject: Reply with quote
Hmmm I didn't realise there were differences. Interesting that and will look into it. Thumbs Up
CCM 404 DS
andym
PostPosted: 05:19 - 18 Feb 2019    Post subject: Reply with quote
Maybe the stuff from Tescos has been..... watered down Rolling Eyes
PostPosted: 12:24 - 18 Feb 2019    Post subject: Reply with quote
If I'm happy to drink it I'd be happy to put it in my engine tbh.
Hong Kong Phooey
PostPosted: 16:53 - 18 Feb 2019    Post subject: Reply with quote
Up Norf the water is clean and pure, washing machines love it.
Darn Sarf they drink chalk straight from the taps. I would only use that out of a water cannon on some lefties.
I've filled every vehicle with tap water and anti-freeze, as already said you're not filling it all the time so no big deal.
stevo as b4
PostPosted: 19:41 - 19 Feb 2019    Post subject: Reply with quote
I'd use filtered rain water before tap water, but as Stinkwheel said in a soft water area it'd be fine. Tumble dryer condensate or water from a de-humidifier is ideal though.
Kawasaki Jimbo
PostPosted: 20:37 - 19 Feb 2019    Post subject: Reply with quote
Possibly, but homeopathy usually costs more.
I use dihydrogen monoxide. It's a modern, alternative coolant technology. Just don't get it in your lungs!
Seriously, I once used pond water in an emergency. But £1.80 for 5L? Why wouldn't you? Fools pay more to drink bottled water.
Islander
PostPosted: 22:44 - 19 Feb 2019    Post subject: Reply with quote
That stuff is old hat. The smart money is on hydrogen hydroxide these days.
The last post was made 7 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 118.09 Kb
