Derbi Senda - random bit of Kickstarter Spring?
NeilP
PostPosted: 16:24 - 17 Feb 2019    Post subject: Derbi Senda - random bit of Kickstarter Spring? Reply with quote
Trying to get the kickstart working on the 2008 Derbi Senda DRD Pro which he has just bought (no kickstart, no electric start - really usefull!). Managed to get the cover off to check out the kickstart mechanism and behind the kickstart bit is this random piece of what looks to be part of the spring. ... but both ends of the kickstart spring look and locate in their holes fine.
Any ideas - is there another spring that could have snapped...?
NeilP
PostPosted: 17:41 - 17 Feb 2019    Post subject: Reply with quote
Also (sorry, not used to 50cc bikes) when i refit (ignoring the strange bit of metal spring above) the kickstart gear engages when first fitted, disappears back into it's hole as the kickstart returns, but then doesn't re-engage .... again, any ideas?
Nobby the Bastard
Harley Gaydar
PostPosted: 17:43 - 17 Feb 2019    Post subject: Reply with quote
The rh side of it looks like something has broken off it.
Triumph Sprint ST 1050
Meatybeaty
PostPosted: 18:00 - 17 Feb 2019    Post subject: Reply with quote
Dont know if this will help, but the rear spring should be resetting kick start,
https://www.youtube.com/watch?v=lLHrcmssmRY
NeilP
PostPosted: 18:36 - 17 Feb 2019    Post subject: Reply with quote
Found out that it was the rear spring from another video, so good to get someone else to confirm it. Thanks for the video link also Meatybeaty.
Nobby - which bit do you mean? Thx
NeilP
PostPosted: 18:46 - 17 Feb 2019    Post subject: Reply with quote
I see what you mean. That's what i thought, however, i think it had just come off the back of the spline, it fits back all OK.
bikenut
PostPosted: 11:30 - 19 Feb 2019    Post subject: part 7 Reply with quote
So now you know why part 7 is there and what it does or allows to happen, the movement of the gear along the spiral splines on the kick starter shaft, making the gear mesh for kick starting movement ot the "ENGINE" and release of the gear from "mesh".
Some designs have a coil spring and "ramp" to make this meshing ( and de meshing ) happen. Its a bit like a clutch but with slip.
It works all fine now?
nuts about bikes
The last post was made 7 years, 235 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 49.73 Kb
