USB charger install
Haydl3
PostPosted: 17:24 - 17 Feb 2019    Post subject: USB charger install Reply with quote
Hi I have a Honda cbr600f 2012 and I’m looking at installing a usb charger and looking for the best way to wire it in any help please
Nobby the Bastard
Harley Gaydar
PostPosted: 17:34 - 17 Feb 2019    Post subject: Re: USB charger install Reply with quote
You could just wire it directly to the battery with a fuse to protect, but ideally you would want to stick q relay in triggered by the ignition switch.
Triumph Sprint ST 1050
Haydl3
PostPosted: 17:53 - 17 Feb 2019    Post subject: Reply with quote
Could I not wire to the ignition so it only works when the back me is running
Haydl3
PostPosted: 17:54 - 17 Feb 2019    Post subject: Reply with quote
Sorry bike
kawakid
PostPosted: 18:44 - 17 Feb 2019    Post subject: Reply with quote
Yes that's the way you should do it.
You will need a 12V relay, you will need some wire and some ends.
You will need to take a feed from the relay to your battery and you should use something sensible on the bike as trigger.
I used the rear number plate bike on my ER6 on my Z750 I used the live off the rear brake switch.
I'd put a small inline fuse in too.
I've a twin and a 4.
Haydl3
PostPosted: 21:40 - 17 Feb 2019    Post subject: Reply with quote
I’ll have to find a relay and have a go.so I can’t just tap into something that needs the ignition without using a relay
WD Forte
PostPosted: 21:49 - 17 Feb 2019    Post subject: Reply with quote
You dont have to use a relay, but a fuse is a must to protect the rest of bike electrics in case of water ingress.
I fitted one to a scoot a while back and tapped into a 10A protected circuit with a 3A fuse to the usb thing so it powers up with ignition on
It aint burst into flames yet but we live in hope............
bikers smell of wee
Haydl3
PostPosted: 21:54 - 17 Feb 2019    Post subject: Reply with quote
Is it one of these I need
Haydl3
PostPosted: 21:57 - 17 Feb 2019    Post subject: Reply with quote
I’ve put an inline fuse on it with a 5 amp fuse could I tap into the taillight
kawakid
PostPosted: 22:43 - 17 Feb 2019    Post subject: Reply with quote
A bodge is not to use a relay. Why do it, relays cost about £3 and a relay ensures the power is coming directly from the battery and not putting any extra stress on any other wires.
Haydl3
PostPosted: 22:45 - 17 Feb 2019    Post subject: Reply with quote
I’ve put a pic on of a relay is it what I’ll need please
sickpup
Old Timer
PostPosted: 12:34 - 18 Feb 2019    Post subject: Reply with quote
I'm pretty sure your bike can take a genuine Honda Averto alarm so there is already an unused plug probably at the back in amongst the rear light wiring that is blanked off. You can simply plug into this plug for a USB charger so no need to hack the wiring or even fit a relay.
Most Hondas 500cc and above from about 2006if not even earlier had this feature, the touring bikes often had this and an additional one at the front to connect a quad harness to.
Haydl3
PostPosted: 15:46 - 18 Feb 2019    Post subject: Reply with quote
It doesn’t say or show anything in the wiring diagram
Hong Kong Phooey
PostPosted: 16:59 - 18 Feb 2019    Post subject: Reply with quote
Switched relay all day. Even without a device plugged in there is parasitic draw, I fitted one direct to battery and a week later flat battery.
I tested and didn't detect any drain but my meter isn't that good.
Have a ganders at Stinkers excellent write up.
https://www.bikechatforums.com/viewtopic.php?t=192684
Haydl3
PostPosted: 18:22 - 18 Feb 2019    Post subject: Reply with quote
That’s great looks a bit complicated but I’m sure I can do it
kawakid
PostPosted: 22:53 - 18 Feb 2019    Post subject: Reply with quote
No
This
https://www.ebay.co.uk/itm/12V-40A-Auto-Automotive-Relay-Socket-40-Amp-4-Pin-Relay-Wires-UK-Seller/112982595825
Haydl3
PostPosted: 07:04 - 19 Feb 2019    Post subject: Reply with quote
Thanks I’ll get one and give it a go
Haydl3
PostPosted: 16:18 - 19 Feb 2019    Post subject: Reply with quote
Will I still need an in-line fuse on my usb device if there’s one coming from the battery to the relay
Meatybeaty
PostPosted: 16:26 - 19 Feb 2019    Post subject: Reply with quote
As @sickpup says ,it shows on the diagram as a 5 wire connector as options
A100man
PostPosted: 16:04 - 20 Feb 2019    Post subject: Reply with quote
Fuses are to protect the wiring in case the 'appliance' goes faulty. Use a fuse value somewhat below the rating of your chosen cable.
These chargers appear to be able to source up to 2A @5v so I guess only really need a 1A feed cable at 12V but sure, add some margin. Really not sure why you include any relay for this, just a switch to isolate in case there is some 'passive' current drain. Relays are mainly used to switch high loads via a low current rated switch.
Edit - OK I understand having read Stinkwheel's guide that using an switched live from the ignition to 'fire' the relay is helpful as you don't have to remember to turn off the'appliance' to save the battery.
Haydl3
PostPosted: 10:17 - 22 Feb 2019    Post subject: Reply with quote
Hi thanks for all the help and advice I’ve now installed the usb and it works a treat
The last post was made 7 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 101.11 Kb
