Kawasaki zephyr 550
Tonymontana
PostPosted: 16:48 - 17 Feb 2019    Post subject: Kawasaki zephyr 550 Reply with quote
Hi this is my first attempt at a post. Here goes, I have a 91 zephyr which I have tried to turn into a cafe racer. All is great apart from the performance of the bike. I have removed the stock air box and filter and fitted the cone type filters. The bike starts and runs but sometimes runs like it's getting too much air or fuel. I have tried the basics like taping the cones to stop to much air. I am a bit stuck to be honest. Do I have to change the jets in the carbs? If so, what size jets? Has anyone tried and succeeded.
Thx in advance
Tony Very Happy
piazza
PostPosted: 17:21 - 17 Feb 2019    Post subject: Reply with quote
How 'bout leave it as is, and enjoy the experience of a bike that runs normally. If it did indeed run to start with Laughing
Nobby the Bastard
Harley Gaydar
PostPosted: 17:59 - 17 Feb 2019    Post subject: Reply with quote
Put it back to how it was supposed to be.
See if it works.
When it runs properly because Kawasaki spent millions developing that engine/intake combination, leave it be unless you want to pay to put it on a dyno
Triumph Sprint ST 1050
Grubscrew
PostPosted: 19:42 - 17 Feb 2019    Post subject: Reply with quote
Yep, definitely put it back as to how it was.
I have spent many a week or month trying to get a modified bike to run right.
It hardly ever works.
You’ll probably only get another second off your acceleration, and less mpg.......not worth massive of time wasted getting there.
Those bikes ran well as they were, get a bigger bike if it is better speed/ acceleration you are after.
FJR1300/CBR1000F
redeem ouzzer
PostPosted: 20:23 - 17 Feb 2019    Post subject: Reply with quote
After market pod kits usually come with needles and springs, the specification of which has been arrived at after hundreds of dyno runs. You are not going to be able to set it up fannying around in your shed unless you have the patience of job and a full set of all available springs, tubes, needles and jets for that range of carbs, even then sometimes the required needles and springs are custom made. Either source a suitable jet kit (if it exists) or bang the air box back on.
Be a REAL MAN!
PostPosted: 20:47 - 17 Feb 2019    Post subject: Reply with quote
Kawasaki, famous for being well ahead of the game in the late 80's early 90's by producing accoustically tuned airboxes which could flow 110% or more of the engine capacity in air on each revolution.
Normally with retro-fitting pod filters, you'd fit a stage 3 dynojet kit and it would run. But not as well as it would with the stock airbox.
However, they don't make stage 3 kits for 550 zephyrs. So you'd be looking at lots of dyno time and lots of filddling to find a needle, jet, emulsion tube and spring combination that works.
So put the damned airbox back on.
And don't you dare angle-grind anything off the frame. If you're not a frame builder and you're not working to a design, it's not customising, it's vandalising.
And you need a front mudguard.
And a back one, this is the UK, not California ffs! It rains.
This short informative post was brought to you by a grumpy old git who is heartily fed up of seeing people ruin perfectly good motorcycles by grinding off the subframe, ditching the airbox and ripping the mudguards off. In a whole world of possabilities for customising a motorcycle, why are they ALL done the same.
I don't know... If you want to do a tasty custom zephyr, why not get a monoshock conversion done and an Eddie Lawson paint job or something?
Bhud
PostPosted: 21:28 - 17 Feb 2019    Post subject: Reply with quote
This video may help to explain why it won't run right without the airbox:
https://www.youtube.com/watch?v=Zfzuob_mBNs
ART-ADS
PostPosted: 19:40 - 22 Feb 2019    Post subject: Reply with quote
so you increased the amount of air, and didn't adjust the fuel, and now it doesn't run right.
was this a serious question?
98' RZ50, 92' H100S2, 03' VT125, 59' Jubilee 250, 05' varadero chop,
Nobby the Bastard
Harley Gaydar
PostPosted: 20:06 - 22 Feb 2019    Post subject: Re: Kawasaki zephyr 550 Reply with quote
The height of pointlessness is to put high flow air filters on and then tape them up to cut down the airflow...
temeluchus
PostPosted: 22:35 - 22 Feb 2019    Post subject: Re: Kawasaki zephyr 550 Reply with quote
Whoever advised you that this was a good idea is a person you should ignore in future.
As for jet sizes, a vague rule of thumb is try jets 25% larger to start with if you have no references. No guarantees though, but I've podded a few bikes and it was in the ballpark.
A jet kit would be far easier if you could find one.
PostPosted: 23:13 - 22 Feb 2019    Post subject: Reply with quote
OP has gone one niner on us. Crying or Very sad
The last post was made 7 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 69.24 Kb
