strange noise???
camcam
PostPosted: 10:36 - 21 Mar 2005    Post subject: strange noise??? Reply with quote
i noticed a strange noise when i stop accelerating ang shifting down gears i noticed it the other day not sure why?
any ideas?
p.s its a nsr (02) model
Flip
PostPosted: 20:25 - 22 Mar 2005    Post subject: Reply with quote
Your chain at the right tension?
PostPosted: 20:53 - 22 Mar 2005    Post subject: Reply with quote
What sort of noise? Clattering, banging, popping, whistling, clunking, chattering, screeching, rubbing, roaring, whirring, wooshing, tinkling.....?
camcam
PostPosted: 14:54 - 23 Mar 2005    Post subject: Reply with quote
not the tightest of things but no idea on how to tighten
could u tell me how please Smile
wantser
PostPosted: 15:13 - 23 Mar 2005    Post subject: Reply with quote
two nuts either side of the rearwheel. Loosen and pull wheel back until chain is tighter. Should not have more than an inch(ish) movement. Test by sticking your fingers under it and lift gently. Tighten nuts. Easy peasy really. Should take about ten minutes!
An expert is a person who has made all the mistakes that can be made in a very narrow field
kenny
PostPosted: 23:59 - 23 Mar 2005    Post subject: Reply with quote
Like flip said if your chain is to slack then when you slow down or ghange gear the chain hit the swing arm. This is what happened to mine the other month i took mine down to the garage becase i couldnt be arsed with trying to hold the bike upright while the rear whell was off the floor anyway the garage only charged me £2 for doin it they said £2 covered the cost of the chain loob they put on lol
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
kenny
PostPosted: 00:05 - 24 Mar 2005    Post subject: Reply with quote
If you do it yourself tho remember to only adjust each nut as much as the other otherwise the back wheel will not be straight and this may cause your chain to fly off when riding your bike(not a good idea) Just to be on the safe side when youve done it get down on ur front and look square at the back wheel to see if it is.
camcam
PostPosted: 18:08 - 26 Mar 2005    Post subject: Reply with quote
ALL SORTED IT WAS THE CHAIN THANKS PEEPS
The last post was made 21 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 56.72 Kb
