Descending steep hills (with bends!)
ThunderGuts
PostPosted: 11:10 - 18 Feb 2019    Post subject: Descending steep hills (with bends!) Reply with quote
Morning all,
So I have done my background reading on this but it still feels a little counter-intuitive . . . how does everyone tackle descending steep (e.g. 10%+) roads where there are tight turns on it?
General advice seems to be to slow down as much as possible before the corner then apply positive throttle through the bend to keep the bike settled, but on really steep roads this seems crazy as to get positive throttle (and I realise it only needs to be a tiny bit) initiates very fast acceleration due to the gradient at a time that really I want to be maintaining a really slow speed. This is even more of an issue where a series of tight/hairpins are linked up with little space between them. I have tended towards using a low gear and engine braking to generally control descent speed, with a dab of front brake as needed (but obviously not on the bends themselves).
This situation is often exacerbated by the fact that mountain area roads tend to have worn/scabby surfaces which don't exactly inspire trust!
Cheers Smile
TG.
Skudd
PostPosted: 11:23 - 18 Feb 2019    Post subject: Reply with quote
I usually is engine baring in a low gear, alternate clutch to let the bike speed up, i.e. Pull in clutch bike speeds up, let out clutch bike slows down with rear brake and slight front brake. It feels right for me and my riding style.
trevor saxe-coburg-gotha
PostPosted: 11:52 - 18 Feb 2019    Post subject: Reply with quote
same
chickenstrip
PostPosted: 12:03 - 18 Feb 2019    Post subject: Reply with quote
trevor saxe-coburg-gotha wrote:
same
A new concept to me. Engine braking is useful though. Low gear.
More back brake, and only a little front - I find on the Fazer the rear brake will overheat a bit if I use it exclusively on steep downhills on a day riding the mountain passes.
Sit back in the seat a bit too, almost leaning back. As usual, relax, don't tense up.
On those mountain roads, you need to be going slow enough to pick your line carefully between the crap washed out onto the road, and be ready for anywhere it gets particularly bad, so you don't want speed.
PostPosted: 12:21 - 18 Feb 2019    Post subject: Reply with quote
Positive throttle, steady with the rear brake. There is probably some argument that positive throttle makes naff all difference at 10mph though...
ThunderGuts
PostPosted: 14:18 - 18 Feb 2019    Post subject: Reply with quote
Thanks all. The engine braking effect is really pronounced on my ER5 (in 2nd gear it comfortably held me at 20mph when I needed it to going down the Winnats Pass yesterday) so that's pretty similar to using the rear brake I guess, but without the overheating risk!
TG.
chickenstrip
PostPosted: 14:25 - 18 Feb 2019    Post subject: Reply with quote
Depending on the gradient, engine braking alone isn't always enough with my bike (IL4), so it's necessary to use a combination of the two.
Hong Kong Phooey
PostPosted: 17:11 - 18 Feb 2019    Post subject: Reply with quote
Rear brake, engine braking, would avoid front brake if possible.
Off camber? Well that's never going to inspire confidence.
A lot will depend on the bike.
Slowly, relax, eyes on the inside of the bend, repeat. The more you do it the easier it gets they say.
Too slow and you'll be wobbling though.
Sometimes it helps to follow an experienced rider on a similar bike, you get a feeling of what's possible.
PostPosted: 21:16 - 18 Feb 2019    Post subject: Reply with quote
Ghost run. All line up in a row at the top. Engines off. You are allowed three pushes with your feet then it's feet up and last one to the bottom is a sheep shagger. Kudos for first down and furthest travelled before rolling to a halt.
Do that on the Rattagan pass with half a dozen other bikes a few times and you'll learn how to descend like a madman. The look on car drivers faces as they get overtaken by multiple, totally silent sportsbikes with the riders tucked in behind the fairing is worth the effort.
More seriously, learn to use both brakes while cornering. It is not the instadeath move most people think it is. Generally people who do are taking too much weight through the bars and not enough through their legs which makes them sit the bike up when they brake.
I thought it was what bikes did for a long time myself until I got one with really long travel, very well damped suspension. It taught me that you CAN brake while leaned over without the bike sitting up providing you don't feed in adverse steering input. In fact, the braking will cause fork dive, sharpening the rake angle and causing the bike to turn in even more. Remember, legs and arse are for taking your weight, handlebars are for steering.
Obviously, don't practice this for the first time on a 10% gradient and do be aware that the more combined braking and cornering force you put through the tyre, the more likely it is to lose traction.
flearider
PostPosted: 23:46 - 18 Feb 2019    Post subject: Reply with quote
MAKE SURE YOUR BUTT PLUG IS INSTALLED AND JUST RIDE IT OUT WITH A SMILE Smile
Courier265
PostPosted: 00:51 - 19 Feb 2019    Post subject: Reply with quote
same
Ditto
ThunderGuts
PostPosted: 09:28 - 19 Feb 2019    Post subject: Reply with quote
Thanks all, appreciate the input. Thumbs Up
TG.
The last post was made 7 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.13 - MySQL Queries: 13 - Page Size: 78.16 Kb
