LED indicator brightness
Renzakuken
PostPosted: 22:22 - 19 Feb 2019    Post subject: LED indicator brightness Reply with quote
Hello all
Very confused here - I've fitted a new pair of mirrors with LED indicators incorporated on the rear facing side (so they face traffic towards me).
When I use my fob to activate/deactivate my datatool alarm they flash brightly.
When I either switch the ignition on or start the engine and turn on the indicators or hazards, they're really really dim. As in, I have to squint up close to see that they're even working!
They're connected to the stock indicator male/female lead as well.
Any suggestions? I've tried fitting another pair from a different vendor entirely and the problem persists, so it can't be the mirror/indicstors causing the issue. I also hooked up a volt meter and can see there's plenty of current going through.
[/b]
CBR 125 2006 STOLEN
GSX600F 2003 SOLD
GSX650F 2009 CURRENT
BTTD
PostPosted: 22:52 - 19 Feb 2019    Post subject: Reply with quote
Wild guess, when they flash through the alarm they get power through the alarm. When they flash as indicators, they get power through the indicator relay.
Is it possible that the indicator relay, or switch, is just not doing the job?
When you say that there is plenty of current going through, what voltage readings are you getting at the led indicators?
How have you wired them in? In parallel with the oe indicators? Are the oe indicators still connected? What bike - does it have some fckn canbus that cuts power to them because they're not the right resistance?
So many questions. Wink
blurredman
PostPosted: 11:19 - 20 Feb 2019    Post subject: Reply with quote
I concur with jnw. What is your relay type?
Did the bike originally come with bulbs?
The last post was made 7 years, 242 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.99 - MySQL Queries: 13 - Page Size: 37 Kb
