Sidestand loose
Cookiemonster...
PostPosted: 12:49 - 20 Feb 2019    Post subject: Sidestand loose Reply with quote
I was riding the bike home and I heard a rattle and saw the sidestand dragging slightly and so I had to pull over.
Thought of using a cable tie to put up the stand and remove to put down
but this is so much effort to do every single time. I need a proper fix.
I had to ride home with my foot under the stand while staying in third gear throughout the journey.
Will an extra couple of washers for the bolt to thread through do the job do you think?
Here's a picture of my problem:
In the picture there is side play- it's been like that for a long time and it's led to this much more worrying problem where the stand won't stay up when I'm riding
rpsmith79
PostPosted: 13:01 - 20 Feb 2019    Post subject: Re: Sidestand loose Reply with quote
Is it not just the spring you are missing?
Cookiemonster...
PostPosted: 13:25 - 20 Feb 2019    Post subject: Reply with quote
where would the spring go?
Edit: No there are two springs. One for the sidestand switch and one to actually keep the sidestand back. It's still not staying up.
rpsmith79
PostPosted: 13:28 - 20 Feb 2019    Post subject: Reply with quote
If you tell us the bike, we might be able to help
Cookiemonster...
PostPosted: 13:57 - 20 Feb 2019    Post subject: Reply with quote
cbr125
rpsmith79
PostPosted: 14:02 - 20 Feb 2019    Post subject: Reply with quote
I think photos are needed them, as a quick Google search shows up CBR 125 Side Stand springs, so it must be held up by the spring (never seen a side stand that isn't held up by a spring)
So might be worth comparing what your spring looks like against a Google image search, maybe yours has stretched to the point where it isn't holding, or the clip/mounting point at either end of the spring may have broken
Freddyfruitba...
PostPosted: 14:04 - 20 Feb 2019    Post subject: Reply with quote
Does the pivot needs lubricating so the stand flips up again as it's supposed to?
Cookiemonster...
PostPosted: 14:26 - 20 Feb 2019    Post subject: Reply with quote
shit. you're right. no springs at all. not sure where the two springs have gone.
I have no idea how the springs would go on even if I had them. Looking for pictures online can't see anything. How on earth they would disappear I have no idea.
Meatybeaty
PostPosted: 14:42 - 20 Feb 2019    Post subject: Reply with quote
I get a different part to what your showing, try Fowlers,
Cookiemonster...
PostPosted: 14:46 - 20 Feb 2019    Post subject: Reply with quote
Oh yes- I realise that's the actual stand I want- I'm on Fowler's now. I just posted the pic of the stand above in my OP to demonstrate the side to side play.
TEMPORARY SOLUTION FOLKS PLEASE!
Robby
Dirty Old Man
PostPosted: 14:55 - 20 Feb 2019    Post subject: Reply with quote
Temporary solution while you wait for the spring to turn up? Rubber bands.
Freddyfruitba...
PostPosted: 15:51 - 20 Feb 2019    Post subject: Reply with quote
So, how in the world did you manage to see two non-existent springs? Just curious...
rpsmith79
PostPosted: 15:52 - 20 Feb 2019    Post subject: Reply with quote
Autism, that's how
Cookiemonster...
PostPosted: 16:32 - 20 Feb 2019    Post subject: Reply with quote
I worked on the bike before. And remembered seeing them. I didn't bother to look properly.
Anyway I went to the motorcycle shop a mile away and he put a new spring in there- it's fine now.
Sister Sledge
PostPosted: 19:10 - 20 Feb 2019    Post subject: Reply with quote
Where was it parked up?
Someone might have stolen them because they lost theirs. They just hook over lugs or through holes - pliers will remove them/put new ones on.
CCM 404 DS
The last post was made 7 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.12 - MySQL Queries: 13 - Page Size: 83.07 Kb
