Looking for a welder in Croydon area
Minty
PostPosted: 14:42 - 20 Feb 2019    Post subject: Looking for a welder in Croydon area Reply with quote
Sup,
Anybody know of a good welder in the Croydon area that could repair an exhaust? Or anyone here think they could do it and maybe help me fit it as the collars on 2 of my header pipes have dissolved and I expect the studs are going to be in an equally bad way? Of course happy to pay a fair price. I emailed a place in Addington but got no response so assume they are not interested.
I got the exhaust off ebay and was meant to be in excellent condition with no previous repairs however ther is a crack on one original weld that goes 2/3 of the way round and a previous weld on the hanger looks to be blowing slightly.
Thanks in advance,
Mintah.
My fingers smell of your mum.
Shaft
PostPosted: 14:47 - 20 Feb 2019    Post subject: Reply with quote
Try Surrey Performance Exhausts in Wallington, very good, I've used them a couple of times for bespoke (car) pipes, but they always seem to have a couple of bikes hanging around.
Minty
PostPosted: 18:38 - 20 Feb 2019    Post subject: Reply with quote
That may be one for the back burner - a few hit n miss reviews for that place.
Robby
Dirty Old Man
PostPosted: 18:54 - 20 Feb 2019    Post subject: Reply with quote
You could braze it yourself. Use a mapp gas torch. You can buy brazing rods in halfords, or online.
Sister Sledge
PostPosted: 19:05 - 20 Feb 2019    Post subject: Reply with quote
I'm too far away to weld it for you but is that a stainless steel system? Looks brittle.
CCM 404 DS
Minty
PostPosted: 20:24 - 20 Feb 2019    Post subject: Reply with quote
It is stainless and looks to be the weld that has failed as opposed to the exhaust itself.
I'm loathed to lob too much money at what is essentially a free exhaust only to then find out it hasn't worked and then have to buy brand new. That's why I was hoping there may be a bcf'er willing to have go for some beer tokens.
Another option is to see if it fails the mot and then see if my garage would be willing to weld and fit it.
I am braced that ultimately I need to just buy a new system and I'd hope it'd possibly be its last one as the bike is 22 years old.
PostPosted: 16:12 - 21 Feb 2019    Post subject: Reply with quote
What bikes it for?
A100man
PostPosted: 16:22 - 21 Feb 2019    Post subject: Reply with quote
I'd pitch-up at the door of a local welders and see if they's do it on a tea-break for 'a drink'.. If you can get some bracing on there as well all to the good.
For MOT Gun-gum, bean can and jubilee clips..
Bhud
PostPosted: 10:01 - 22 Feb 2019    Post subject: Reply with quote
If Maidenhead isn't too far then I could do it for you for a 4-pack of Hobgoblin. Just the welding-up repair and not the fitting though.
bikenut
PostPosted: 11:25 - 22 Feb 2019    Post subject: Reply with quote
A map torch will not get hot enough for a good braze, oxy acetylene is the hotter and smaller more concentrated flame, tip size dependant. Carburising flame remember even with flux.
what bike is it off please?
nuts about bikes
Minty
PostPosted: 11:46 - 22 Feb 2019    Post subject: Reply with quote
Thanks for the replies, it's for a 97 Cbr900.
Full delkivic system is around £300 by the looks of it (plus fitting as I foresee stud woes).
*edit* mot is this Monday and expires march 6th.
PostPosted: 12:12 - 22 Feb 2019    Post subject: Reply with quote
I don't have any exhausts for that bike Sad sorry.
You could definitely bodge that for an MOT though, few quid max.
Minty
PostPosted: 12:20 - 22 Feb 2019    Post subject: Reply with quote
The zorst on my bike now is bodged (2 into 1 has repair tape and jubilee clips) so I'll see how that goes. It passed last year without even an advisory on the rotten header clamps as there is no gas leak and there still isn't but I'm kind of getting into the brace position that my luck has to run out at some point.
PostPosted: 13:31 - 22 Feb 2019    Post subject: Reply with quote
If only warped was were here.
Last edited by Howling TerrorOutOfOffice on 14:02 - 22 Feb 2019; edited 1 time in total
Riejufixing
PostPosted: 13:32 - 22 Feb 2019    Post subject: Reply with quote
It is quite easy to braze using a carbon arc, flux and bronze rods. I bought one of these years ago, and they're very good (they run off an ordinary AC welder).
https://www.ebay.co.uk/itm/Brazing-torch-for-arc-welder-/153388646774
That sort of torch is much more controllable than the ones with crosswise-mounted carbon rods. A welding helmet and dark welding lens, and covering up to avoid "sunburn" are vital.
Lots of uses around the home....
Minty
PostPosted: 16:15 - 22 Feb 2019    Post subject: Reply with quote
Welded whilst hanging upside down with shit covered fishfingers to within 4 thou? Thinking
PostPosted: 16:36 - 22 Feb 2019    Post subject: Reply with quote
That's your man right there. Thumbs Up
Bhud
PostPosted: 19:11 - 22 Feb 2019    Post subject: Reply with quote
Here's one I did earlier.
Lots of sticking and spatter, because it's a very thin stainless aftermarket silencer welded on to a larger diameter, much thicker, mild steel original exhaust section. A higher voltage (I used SMAW) would have blown holes in the thinner stainless section. I used a very low voltage. This isn't a leak repair but an actual exhaust reconstruction. I ground it down on one side before respraying in black later - I didn't actually mount it to the bike like this as it was unsightly.
Realistically, your split in the weld is a normal thing because of different cooling rates to the centre and sides of a weld, and it would be easier for any pro welder to fix. It's not actually putting together mismatched pieces of metal using bead over bead, or bits of scrap metal. They shouldn't charge you more than about £20. A MIG welder can be dialled in very precisely and the repair will look perfect. Tin cans, exhaust putty, etc. is a road of frustration.
davebike
PostPosted: 09:05 - 23 Feb 2019    Post subject: Reply with quote
I am a pro (mechanic that welds ) not that far from Croydon and do a few I am SE20 8JY
Looks stainless not that hard to repair with TIG and a stainless filler rod Smile)
Dave
07860 215638
Dave
NC750Xdct + others at work !
[email protected]
Tankie
PostPosted: 11:12 - 23 Feb 2019    Post subject: Reply with quote
Dave
07860 215638
No , but he has to get off his arse ! Rolling Eyes
Minty
PostPosted: 11:18 - 23 Feb 2019    Post subject: Reply with quote
Dave
07860 215638
Thanks, I may well be in touch after the test on Monday. Would rusted studs be something you have the knack of dealing with too?
davebike
PostPosted: 12:00 - 23 Feb 2019    Post subject: Reply with quote
Possibly done a good few !
DW
Dave
[email protected]
Minty
PostPosted: 14:36 - 23 Feb 2019    Post subject: Reply with quote
Thanks, I will definitely be in touch. Even if I pass the mot Monday, I need to get this sorted soon.
Sister Sledge
PostPosted: 19:34 - 23 Feb 2019    Post subject: Reply with quote
Awesome news. I'd have done it but I live hundreds of miles away.
CCM 404 DS
The last post was made 7 years, 246 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 120.44 Kb
