What to check when buying a bike?
gimpy limp
PostPosted: 21:08 - 22 Mar 2005    Post subject: What to check when buying a bike? Reply with quote
What do people on here generally check for and what don't you bother checking?
i've got very little mechanical knowledge when it comes to bikes (know plenty about cars though)
a list of what to keep an eye out for would be nice
This is what i've found out so far:
- sit on it and jump up and down, if you get catapulted off the seat rear suspension is knackered
- push down on the forks, same with those, they should be dampened and not a violent spring
- is chain wear is something to look out for? (not expensive new chains are they?)
- what about when test driving it? what sounds to listen for if any?
metally banging sounds in cars can sometimes mean conrod bearings
- Do you bother to look at the alignment of the front to rear wheel (for bent frame) by looking down the length of the bike, from well in front of the front wheel?
That lot is all i've found out so far - anyone have anything to add?
engine wise what can you check for a healthy engine that isn't on it's way out?
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
DynaMight
PostPosted: 21:18 - 22 Mar 2005    Post subject: Reply with quote
Service history, Do a HPI check, Check the tread of the tyres, Let the bike fully warm up and make sure it isnt smoking too much, Check the thing over for rusted bolts, nuts, headerpips anything that may need replacing.
Then kick the tyres, drink the tea then walk away.
instigator
PostPosted: 21:20 - 22 Mar 2005    Post subject: Reply with quote
Ask to use the toilet. Thumbs Up
That way you'll know if he actually lives there and hasn't just pushed it up outside the house. Confused
cagiva gezzer
PostPosted: 21:26 - 22 Mar 2005    Post subject: Reply with quote
Might Help
gimpy limp
PostPosted: 21:29 - 22 Mar 2005    Post subject: Reply with quote
lol
is their anything else you can check engine wise? ask when it last had an oil change, can't think of much else. That's probably the most stress and money wasted if something goes wrong with the engine?
I went to see a bike once and it would start up fine and idle fine but as soon as you put on a small amount of throttle it would cut out!! What could that mean? one person said it meant that the engine was knackered and on it's way out? he wanted too much for that anyway so I left it.
dotti
PostPosted: 22:17 - 22 Mar 2005    Post subject: Reply with quote
https://www.clarity.net/adam/buying-bike.html
I think I got this from the forum mentioned above, but am not sure. This will tell you everything you need to know. The trick is trying to memorise as much of it as possible, so you look like you really know your stuff when going to view a secondhand bike.
Dangerous traffic offences spotted on 50-minute trip: Lost count after 100. Number of traffic cops spotted: One, sitting by a speed-trap camera
Gazdaman
I did a trackday!!!
PostPosted: 22:26 - 22 Mar 2005    Post subject: Reply with quote
Depends what kind of bike you're buying and how much you're spending.
We bought a £400 XJ600 without even test riding. Just spent a few minutes playing with it, had a cup of tea and signed the V5.
I'd check wheel bearings, this needs 2 people to check. (Put it on the centre stand if there is one, and try and get lateral play in the wheels)
Check for tell tale replaced parts (gear shifters/footpegs/mirrors) for signs it's been down the road.
Steer clear of aftermarket paint jobs without a good reason for it.
Gaz
gimpy limp
PostPosted: 22:34 - 22 Mar 2005    Post subject: Reply with quote
good idea, if theirs no stand and it's not too heavy could get a mate to lift one end spin the wheels listen to the bearings for a gritty feel if there shagged
gimpy limp
PostPosted: 22:40 - 22 Mar 2005    Post subject: Reply with quote
at the moment what i'll be looking at are kawasaki EL250's (maybe a 500) until something else catches my eye (very easy for that to happen). Not been to see any yet.
The last post was made 21 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 62.38 Kb
